Purolator Fuel Filters - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 07-23-2009, 04:00 PM Thread Starter
katana1150's Avatar
As I mentioned in another post the local autoparts stores all seem to push the Fram filters. Wakefield Sperling does sell Purolator and WIX but they don't stock WIX filters, anyway.........
I bought a purolator oil and fuel filter for my 3500 but I have since found out that there is a Auklands Grainger store near me that sells Baldwin filters as well as a Peterbuilt dealership not far away. So should I throw away the purolator filters and get the baldwin or just use the filters I have and at the next change get the baldwin filters?
I know some of you will swear by baldwin or fleetguard but since I have already spent the money I would like to use the purolator filters but not if they will damage the engine. Like many of the members have stated "Stay Away From Fram Filters" cause they have had some history of comming apart and damaging the engine, That ofcourse is the last thing I would want to happen.
Any thoughts?
2004 Ram 3500 Quad Cab SLT DRW,305/555 6 speed manual 4X4/Banks Ram Air
Give a man a gun, and he can rob a bank!. Give a man a bank and he can rob the world!!.
katana1150 is offline
post #2 of 16 (permalink) Old 07-23-2009, 04:14 PM
How much are new oil and fuel filters? How much is a new engine?
From what I understand, the Purolator fuel filter does not meet Cummins specs for filtration and water separation. I'd change that one at least. If you ever have engine trouble and the dealer sees a non-spec fuel filter, they'll likely void your warranty. Fuel filtration is something you don't want to skimp out on when dealing with a diesel -- too many expensive parts.
'08 3/4 Mega Cab Laramie 4x4, 6.7L automatic.
305/65/17 BFG T/A-KO on stock suspension.
Extang Solid Fold tonneau cover, Line-X, plus other minor improvements.
Dan V is offline
The Following 2 Users Say Thank You to Dan V For This Useful Post:
katana1150 (07-23-2009), SmokinTheHippies (07-23-2009)
post #3 of 16 (permalink) Old 07-23-2009, 05:11 PM Thread Starter
katana1150's Avatar
Good point Dan
the truck is long out of warranty so the dealer will never see this truck.
I couldn't find any specs on the purolator fuel filter so I was hoping someone would chime in with suggestions.
Looks like it maybe a good idea to use a baldwin fuel filter instead.
post #4 of 16 (permalink) Old 07-23-2009, 05:27 PM
I would change out the Purolator, if you have an extra Purolator keep it as a spare for emergency situation. The three best filters, that I would use are Baldwin, Fleetguard, and ACdelco. You are close to Cummins and they have deals all the time on service packs. Freightliner is open 24 hours a day, peterbuilt all on 96 th avenue.
JP 3 :Licenced HD mechanic for 35 years. RETIRED!
worked on engines all my life. Spent last 19 HAPPY years at Freightliner:
jpringle3@hotmail.com is offline
post #5 of 16 (permalink) Old 07-23-2009, 05:46 PM
Dodgezilla's Avatar
iTrader Score: 18 reviews
I can tell you that on my 07 dually I had I put a Purolator filter on out of necessity. The truck ran fine but my fuel pressure went up 1 point. That leads me to believe that it was not filtering as well as the factory ones. I get mine from Genos whenever I can....
04 Ram 2500,Green/Silver-305/555HO,48RE,3:73s, QC,LB,4x4,Roadwire Leather,Laramie Interior,Infinity, HE351 Turbo,Magnaflow 4" Exhaust,VA C3.2,Westach gauges,Torque Tube,BeCool Fan,Fogzilla,TRM,4th Gen 20" Rims w/ 265/60 tires,118,000 miles
Dodgezilla is offline
post #6 of 16 (permalink) Old 07-23-2009, 08:04 PM Thread Starter
katana1150's Avatar
Thanks for the advice, I haven't installed the purolator fuel filter yet, I'll take your advice and keep it as an emergency spare. I'll go and get a baldwin from peterbuilt or acklands.
I also just found out the purolator oil filter L45335 is recomended for the cummins 5.9 ref:TSB 09-004-01
post #7 of 16 (permalink) Old 07-24-2009, 04:43 AM
Before you use any fuel filter, find out it's filtration and F/W separation specs.
If it doesn't filter down to 7 microns or less (absolute, not nominal) and remove 95% of free and emulsified water, don't use it.
'05 2500 4x4, G56, BDTD CL, AEM Brute Force, High Ram, Monster Exhaust, AD 100, and some other stuff.......
Thanks to John @ Holland Court Diesel
mattingly is offline
post #8 of 16 (permalink) Old 07-26-2009, 09:32 PM Thread Starter
katana1150's Avatar
Has anyone got a Baldwin Part# that is recomended for this truck?
post #9 of 16 (permalink) Old 07-26-2009, 09:36 PM
milldog's Avatar
Would like to know this as well
milldog is offline
post #10 of 16 (permalink) Old 07-26-2009, 10:10 PM
Wredneck Dually's Avatar
Baldwin PF7977 fuel filter.
2005 Black/Long Dually, Banks exhaust, Bully Dog RFI, maghytec tranny cover, HyperTech Max Energy programmer,
28' RC fifth wheel enclosed car hauler
Wredneck Dually is offline
The Following User Says Thank You to Wredneck Dually For This Useful Post:
katana1150 (07-27-2009)
post #11 of 16 (permalink) Old 07-27-2009, 10:49 AM
According to Dodge
Puralator is on the list and a good filter
The only approved oil filters for Dodge's diesel engine are as follows:
Part # Manufactuer
5083285AA Mopar
LF16035 Fleetguard Stratapore
LF3894 Fleetguard Stratapore
LF3972 Fleetguard Cellulose
LF3552 Fleetguard Microglas
LF3959 Fleetguard Cellulose
3937695 Cummins Cellulose
FL896 MotorCraft Cellulose
L45335 Purolator Cellulose
PF1070 AC Delco Cellulose
Note: To maintain your warranty please be sure you use one of the above filters when servicing your truck.
Pete
2004 Laramie, 4x4, QC, 48RE, 3.73, SRS, Molten Red, BFG 285s, xfer and fuel tank skid plates, Frontier back bumper, Cool Blue (removed), Moog greasables, Defiant sector plate, FASS-150, billet TC and performance VB w/Sonnex, Yaesu 2M and CB radios, Nav 1, Rokk sens.
xploretx is offline
post #12 of 16 (permalink) Old 07-27-2009, 11:06 AM
Good list, BUT the only three filters I have ever personally seen, that had failures are motorcraft, purolator, and Cat made by Donaldson. Motorcraft filters, are the worst, no paper, if you ever have a low oil pressure problem, and you have a Motorcraft filter on it change the filter and problem is solved. Purolator the cans crack, seen that multiple times. Cat filters the secondaries have a tendency to twist internally, and plug off. Fram I try to avoid. Wix I will use. My top three are Baldwin, Fleet guard and ACDelco. You go with what you trust, and learn from experience.
