HELP!!! Need Fan belt routing diagram!! - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 02-20-2007, 11:27 AM Thread Starter
wildchild's Avatar
I broke my tensioner pulley yesterday and broke the belt....Can't seem to figure out how it goes on? Anyone with pics would be appreciated!!! Also when it came off it ripped some wires and i can't figure out where they go.... The wires are right in front of the steering rack on the bottom left hand side....there is a plug that goes up to the fuel pump it looks like....these wires come back and go in a peice of tubing from there I can't tell where they go from there because they are so mangled.....Thanks again for any help
Silver 2005 4 door Dual Wheel Cummins, ATS Stage 4 Tranny, Edge Juice with attitude, Bully Dog Triple Dog with Crazy Larry upgrade, Aurora 3000 turbo, custom air intake, muffler MIA, Isspro pyro, tranny temp, boost, & fuel psi, gauges..........headlight & tail light covers.......265/70/17 Timberline MT's
wildchild is offline
post #2 of 9 (permalink) Old 02-20-2007, 12:05 PM
MATRIX's Avatar
:thumbsup
2005 Laramie 4X4, 4:10 gears. 48RE
MATRIX is offline
post #3 of 9 (permalink) Old 02-21-2007, 06:19 AM Thread Starter
wildchild's Avatar
Thanks for the pics YFZBOB......got the belt on but can't figure out the wires still......runs fine and everything works???
post #4 of 9 (permalink) Old 02-21-2007, 07:33 PM
MATRIX's Avatar
Can you take a picture of the wires and post it? What colors are they?
MATRIX is offline
post #5 of 9 (permalink) Old 02-21-2007, 10:58 PM Thread Starter
wildchild's Avatar
yeah i may be able to borrow my g/fs camera and take a few.....im not sure of the colors....I will post some pics tommarow...
post #6 of 9 (permalink) Old 08-06-2008, 01:05 AM
luckyhat12's Avatar
What do the numbers stand for? I am looking at this picture and I still can't figure out the route.
Maybe I am just dumb tonight
--Chris-- 2012 3500MC 4x4 - stock at the moment
SOLD* - * 07 Silver QC LB 3500 5.9 4X4 G56 w/ SBC DD, BD Ex. Brake - no longer a Full Time RV'er-
luckyhat12 is offline
post #7 of 9 (permalink) Old 08-06-2008, 01:23 AM
Former Staff Member
MR4WLR's Avatar
1 - GENERATOR PULLEY
2 - WATER PUMP PULLEY
3 - IDLER PULLEY
4 - POWER STEERING PUMP PULLEY
5 - RADIATOR FAN PULLEY
6 - CRANKSHAFT PULLEY
7 - AUTOMATIC TENSIONER
8 - A/C COMPRESSOR PUMP PULLEY
Attached PDF shows routing for both AC and non AC routing
Corey Ritter - Amity, OR
2016 Blue Streak SRW QCLB Laramie. Buckstop/Warn 12,000 lb, WeatherTech vent shades, DeeZee tailgate assist, DeeZee tool/fuel combo with GPI pump
SOLD '04 Patriot Blue SRW 3500 QC 4X4 Laramie, 6spd 151K
MR4WLR is offline
The Following User Says Thank You to MR4WLR For This Useful Post:
BikerTrashW (12-05-2009)
post #8 of 9 (permalink) Old 08-06-2008, 01:48 AM
Tech Specialist
sounds like you ripped off the fan clutch wires - look in front of the fan blade and see if they are there, between the fan and radiator. common problem. good luck.
Ramtech is offline
post #9 of 9 (permalink) Old 08-06-2008, 02:35 AM
luckyhat12's Avatar
I found it just before you posted that. I really appreciate you putting it in this thread though. Man I just couldn't see what was what until I saw the numbers. I was close but no cigar.
I had to take the whole freaking fan assembly off to get my harmonic balancer off and install the fluidampr. It was rediculous. The bolts were tight as they could be and I had to work to get them loose. After that I completely forgot the routing of the belt.
Thanks again for posting that up.
Chris
