Old 07-04-2009, 10:39 PM   #1 (permalink)
In Search of the Money Tree
cumminator's Avatar
Motor gettin HOT.
just picked up an 06 and it goes over 200 all the time, but it will come back down quickly. my questions are 1) is this normal. 2) is there a lower temp thermostat i can put in, and 3) if this isnt normal what could be the cause?
2006 2500 auto, tranny-everything but the shafts, Banks Intercooler, CAI, Ram Air, and Dual Exhaust, Smarty TNT, EZ, HTT 64/71, Performax Gauges, AD 150, Arson 3, Flux 2.0s
For Sale: HTT SuperDave(s480), Source Automotive Twin Piping
"Thanks to Chuck @ New Era Diesel"
cumminator is offline   Reply With Quote
Old 07-04-2009, 10:45 PM   #2 (permalink)
Bigrok's Avatar
Location: Oahu, Hawaii for now (can't wait to get back to the mainland)
Mine will get up to about 200 before the thermostat opens. It then comes down to about 180-190 normal operating temp.
2007 2500, QCSB, 4x4, 5.9L, 48RE, silencer ring MIA, torque tube baffle MIA, B&W Hitch, Smarty Jr POD, Isspro gauges (boost, trans temp, EGT), Aero Turbine 4040XL, smoked cablights
Bigrok is offline   Reply With Quote
Old 07-04-2009, 10:49 PM   #3 (permalink)
stock dodge's Avatar
If its a hot humid day mine will run 200 on the highway , does it ever run above that , and when it comes down does it go back up to 200?
03' CR, AFE Stage II, Edge Juice w/ Att., 4" Turbo Back.auto , 4:10, stage 1 nozzles
stock dodge is offline   Reply With Quote
Old 07-04-2009, 10:51 PM   #4 (permalink)
cumminator's Avatar
this one goes over 200, got on it tonight and it went further past 200 then i would ever like to see it. i just can't believe those temps are normal.
Old 07-04-2009, 10:53 PM   #5 (permalink)
Bigrok's Avatar
I would go get a new thermostat to start. Then if that doesn't fix it, take a look at the water pump.
Old 07-04-2009, 10:54 PM   #6 (permalink)
cumminator's Avatar
everday driving, it will go over 200 about the width of the needle, the drop down below 200 the same. but it does that all the time, making me think the thermostat is either not working right or is set at a temp. above 200 maybe 210?
Old 07-04-2009, 10:54 PM   #7 (permalink)
try it with the smarty back to stock , what happens
Old 07-04-2009, 10:56 PM   #8 (permalink)
Make sure the radiator and inner cooler is clean ,
Old 07-04-2009, 11:02 PM   #9 (permalink)
cumminator's Avatar
well i had to drive it 6hrs back here without the smarty and it done the same thing, after loading the smarty it doesnt get any warmer. but tonight i got a little rowdy on a back road. stopped and boosted it up a lil bit and let er rip till about 80 and looked down at the engine temp and saw it was about 3 notches over 200. so i freaked and cutting the heater on full blast LOL. where can i find new thermostats?
Old 07-04-2009, 11:08 PM   #10 (permalink)
gassernomore's Avatar
I would recommend getting a 180 degree thermostat stock is 190 i have the 180 in mine and i hardly get it over 190 i got mine at a carquest dealer i believe.
99 2500 4x4 / Edge EZ / Isspro Fuel Gauge / Turbo Timer / Raptor 150
06 2500 4X4 / Edge Attitude / Straight Piped
gassernomore is offline   Reply With Quote
Old 07-04-2009, 11:09 PM   #11 (permalink)
New Mexico Chapter President
sofakingbad's Avatar
my truck does the same....200-210 then drop to 190 or so....
05 Cummins 4x4 auto
01 cummins 2wd 6speed
06 Duramax LBZ- sold
sofakingbad is offline   Reply With Quote
Old 07-04-2009, 11:14 PM   #12 (permalink)
cumminator's Avatar
i guess im just used to my 03 never getting over 200, ill try the thermostat and maybe a radiator flush. if that dont work what is involved with a water pump?
