3rd Gen. PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING
My truck seems to have a miss almost always with white smoke when it starts up with the engine cold. It doesn't do it every time but the majority of the time. Truck runs great and starts great warm.
Injectors are new. FCA is new and I tried a friends. Overflow valve is new, and I also tried swapping rail pressure sensors with a different truck. Fuel filter is relatively new. I've done several return test and get about 60ml of injector return and 700 pump return 1 min at idle, though I haven't checked it since doing the overflow valve. Pressure relief doesn't leak at idle or wot. No codes and about 8psi supply pressure. Also adjusted the valves fairly recently.
Any thoughts? This thing is really frustrating me.
yes it will show up on a bench test, our injectors are electronic, so it can never hurt to have them flow tested, your getting the white smoke from an injector leaking down into the bowl, and possibly the miss from one not firing, etc... check the oil see if it has been diluted thin, and smells like diesel fuel...
2011 3500, stock, 2003 QCSB 4X4 5.9 6spd, Smarty, Valair, K&N, ARP, Topgun, Autometer, 5" Stacks, Smoked Recons, KMC wheels, Cooper 35X12.50's, With enough get up and go to piss off your granny! Blacked Out And Engineered By Southern Smoke, And Dark Side Diesel!
Well if you know someone with a scantool or dodge tech that has access to a starscan you could cut out one injector at a time to see if you notice one injector is making the truck run different. Other than that you probably will have to pull them and send them to be tested. Were they new or remans? I have had several sets of remans in my old truck and never had one set turn-out right.
Oil seemed fine. I switched back to my FCA and rail sensor today and decided to have another look at the relief and sure enough it is just pouring out at idle. It didn't before though the banjo was wet the first time I looked at it(after I did the injectors) but wasn't leaking at the time. I got a new one on the way if it doesn't fix it I pulling the injectors, getting them tested and checking the compression.
So are dodges really this ****ty? I have only owned mine for 3 months and it only has 80,000kms(about 50,000miles) on it and I have spent by far more on repairs then any other vehicle I have owned. Everything but the overflow was justified. I am sick of it.
Well some of them are money pits. Just like anything else there are some bad ones. I had an 06 that was a pain in my butt and spent lots of money on it. Had three sets of injectors in it and then sold it. I bought it used with 17k on it. I am weary of used trucks now.
