Cummins oil change - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 09-17-2005, 06:20 PM
Guest
Guest
Posts: n/a
Cummins oil change
Hi! I'm about to do my own oil change for the first time on my 04 cummins.
I thought I read that I have to fill the filter with oil beforeI install it,is this true?
post #2 of 8 (permalink) Old 09-18-2005, 05:12 PM
dieselgearhead's Avatar
You should at least fill the filter 3/4 full before installing. The oil flow through the filter goes to the turbo and then back to the engine. Filling the filter will eliminate a dry start for the turbo. Hope this helps (my $.02)
dieselgearhead is offline
post #3 of 8 (permalink) Old 09-19-2005, 11:59 PM
Guest
Guest
Posts: n/a
Hey mister diesel gearhead thanks for your (.02 ) worth.It was much appreciated.Now I feel more comfortable doing my own oil change
post #4 of 8 (permalink) Old 10-02-2005, 09:31 PM
What will really make it easier is a Fumoto oil valve. No more oil all over your hands.
red rattler is offline
post #5 of 8 (permalink) Old 10-02-2005, 09:38 PM
Should have givin the website. www.fumotovalve.com
The Following 2 Users Say Thank You to red rattler For This Useful Post:
flyboy86q (08-20-2014), frstdsl (08-20-2016)
post #6 of 8 (permalink) Old 10-27-2005, 11:13 PM
Guest
Guest
Posts: n/a
First time I changed the oil on the 04.5 it was a bit tougher than my 01 because you couldent get to the filter so easy, I since purchased a filter wrench that fits the fluted bottom of the filter, just use an extention on the ratchet and reach up there and twist it off easy now, Also another trick I always use is to wrap the filter with a plastic bag first so when you twist it off the oil will spill into the baggie, I have also purchased a drain plug from www.genosgarage.com like this so now all I have to do is to scew the hose fitting onto the plug and it drains out, just a tip if you get one of these the darn hose is a seperate order , its a great product and make my job alot funner, no mess either.
Cheers, Kevin
post #7 of 8 (permalink) Old 11-23-2005, 07:23 PM
woodsrat's Avatar
good tip whitmore i just ordered the same thing guess i better call back and get the hose.
woodsrat is offline
post #8 of 8 (permalink) Old 11-23-2005, 07:38 PM
Guest
Guest
Posts: n/a
Whats really cool about this is I also orderd a drain valve for my wifes 04.5 and the screw on hose/drain attachment fits it too so I only need the one hose, I highly recommend a drain valve of some kind so a guy dont take a chance of strippin threads and stuff like that..................it happens alot more than what a person realizes.
Cheers, Kevin
