AAM Rear Axle - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 01-25-2007, 02:36 AM Thread Starter
raptor660's Avatar
AAM Rear Axle
I have the 11.75 LSD unit in my truck, and I've had some of the same issues as others here. Ever so often it will shudder on takeoff, especially on a left turn taking off. I bought this truck with 60,000 miles on it, and the shudder has actually gone away for the most part. But since day one that I have had the truck, this differential has whined under light load/acceleration. In the summer I run with my windows down most of the time, but now in the winter the whine gets to me sometimes. After about 63 mph it isn't very noticeable, but the men in blue don't underatand this in 35 mph zones. So has anyone been able to muffle this thing, or should I take the silencer ring out of my turbo and let them battle it out?
Also, how loud is the turbo without the silencer?
'04 Laramie Quad Cab 4x4 Automatic - All stock- FP Guage - 2 cycle oil - 4" MBRP T409
raptor660 is offline
post #2 of 16 (permalink) Old 01-25-2007, 09:59 AM
PULN PWR's Avatar
I have that same axle, and was told not to put the addative in the rear end. Mine hops around the corner as well occasionally. I would consider it normal, as every single LSD I have ever had has done this. I would be interested in what others have to say about the addative being put in the rear. As for the silencer....... WOW, TAKE IT OUT! Thing sounds CraZy paired with an intake. People turn and look at me when I come down the street!
ItZ coooool
Chad
PULN PWR is offline
post #3 of 16 (permalink) Old 01-25-2007, 11:46 AM
D-Roc's Avatar
Try the simple things first-does your fluid need to be changed? Is it low, or overfilled? Wrong fluid? Then go from there.
D-Roc is offline
post #4 of 16 (permalink) Old 01-25-2007, 08:11 PM
New fliud and some posts on other sites about having to use additive.I have put additive in mine over a severe shudder after extended towing and on left turns.So far its ok but I have not towed heavy the few hundered miles it took for mine to show up.
2003 3500 dually 4x4,nv5600 4.10 geared Amsoil fliuds front to back.AFE Pro Guard 7 stage 1,Banks full 4 inch exhaust from turbo back,Westach EGT&Boost pillar mount combo gauge,Maap chrome side steps,Kirby condenser guard,Rokktech crank sensor mod.
Ketchum is offline
post #5 of 16 (permalink) Old 01-25-2007, 10:15 PM
rpainter's Avatar
I may be wrong but I think I read somewhere that dodge did a TSB on vehicle shudder at low speeds I think under 35 mph You might want to check that if under warrranty still??? The dealer has to check the driveshaft angles and maybe install a space in the carrier bearing??
rpainter is offline
The Following User Says Thank You to rpainter For This Useful Post:
tonyb337 (03-17-2016)
post #6 of 16 (permalink) Old 01-26-2007, 04:28 AM
There is a TSB on this.This is not what I had happen nor some of the others I found threads on.My shudder occurs AFTER a FEW HUNDRED miles of towing 9k and after cool down goes away.Its not a u/joint.Its the posi system binding.It also started the shudder on left turns unloaded and not towing.
Ketchum is offline
post #7 of 16 (permalink) Old 01-26-2007, 09:53 AM
PULN PWR's Avatar
Every truck that i have owned over the last 6 years has shuddered occasionally in left turns, and they have all done it.
Chad
PULN PWR is offline
post #8 of 16 (permalink) Old 01-26-2007, 09:58 AM
Mine didn't until my 800 mile trip towing 9k or so.Then it started it on left turns unloaded/non towing etc. The diff fliud had about 10k on it. I added the posi additive I bought at a auto parts store and the shudder went away.
Ketchum is offline
post #9 of 16 (permalink) Old 01-26-2007, 11:37 AM
Guys, the AAM axle is NOT a clutch type LSD that requires additive. It's a helical gear unit, much like a Torsen or TrueTrack unit. An LSD additive is used to alter the way the clutches react, and is not needed in the AAM axles, since htey have no clutches.
There are some pictures of a Torsen here:
http://www.torsen.com/files/Traction...ol_Article.pdf
I haven't tried to find pics of the Dodge AAM LSD, but they might be out there somewhere.
As far as the whine you are hearing, a lot of '03 AAM axles were replaced due to improper setup. My '03 whined BAD, and it did not have an LSD unit. With 60,000 miles on it, you probably should have taken it to the dealership, because the rear axle was covered under warranty until 70,000 miles.
'06 2500, G56, QuadCab 4x4, SWB
TornadoTJ is offline
post #10 of 16 (permalink) Old 01-26-2007, 11:49 AM Thread Starter
raptor660's Avatar
Mine only shuddered on a left take off, no load, after the truck had been driven for a few miles. I haven't towed anything in a while and the shuddering has nearly gone away. But my biggest gripe is the whine. I'm blaming the differential, because that is where the whine seems to come from, from 40mph to about 63mph. It doesn't seem to have any excess play in it, and temperature doesn't seem to affect it. One night on a trip home it was really getting on my nerves for some reason. I threatened to put sawdust in it. What happened to the good ol' days when the differential was the only thing on a vehicle you never had to work on, and never thought about?
post #11 of 16 (permalink) Old 01-26-2007, 11:49 AM
PULN PWR's Avatar
I did a diff fluid change awhile back and noticed something in the diff. I took the truck to Dodge and had them look at it to see if it was normal. It was to 3 dealerships and they all say that it is normal. If you look at the pics, it appears as though there are gears wearing through the diff carrier, but as I said, they all said it was normal machining. I even went to head office, and they replied with normal. The rear end is quiet, but hops occasionally around corners, which I consider to be normal, as every truck I have owned has done it.
Chad
P.S. This is an AAM 11.75" rear end
ID:	3359   Click image for larger version
ID:	3360   Click image for larger version
PULN PWR is offline
post #12 of 16 (permalink) Old 01-26-2007, 06:18 PM
I'm fully aware its not a clutch type differantial.But some have a severe shudder issue.
Ketchum is offline
