when do u know when INJECTORS ARE BAD - Dodge Cummins Diesel Forum
post #1 of 23 (permalink) Old 04-30-2009, 07:53 PM Thread Starter
Cumminsnut1328's Avatar
Exclamation when do u know when INJECTORS ARE BAD
just wonderin?? when do injectors go bad?? what are the signs i should be lookin for??? also what bout nozzles when do u know when they go out any ideas would really take some weight off my shoulders oh by the way my rig has 157,000+ THANKS
Currently running-2004 325hp 6spd 4x4 lb, fully built motor, go fast parts-smarty,quadzilla,bd super b,sb clutch,II bag of parts,custom stacks,50hpddp stixs, gauges FASS,
Cumminsnut1328 is offline
post #2 of 23 (permalink) Old 04-30-2009, 10:54 PM
Excessive Smoke
Fuel in oil
Hard starting
Crappy fuel mileage
...that's about all I can think of right now.
rocket is offline
post #3 of 23 (permalink) Old 04-30-2009, 11:06 PM
65StangBoy's Avatar
Just had two injectors replaced. This is what it looked like every morning before the repair. I also had a situation a couple weeks ago where the truck would not start. I'm assuming that one of the injectors was leaking enough to drain the rail pressure to a point where it would not fire.
http://www.youtube.com/watch?v=munF-hEWApw
2014 Ram 3500 Laramie, Megacab, 4X4, DRW, Aisin, 4.10's, Granite Crystal Metallic/Silver
65StangBoy is offline
post #4 of 23 (permalink) Old 04-30-2009, 11:10 PM
jr22's Avatar
you can also hear a slight change in the engine tone
FOR SALE- 2010 mega cab long bed 4x4 6.7 Ctd, Suncoast auto Laramie. B&W hitch. Line-x box/rockers. mag hytec front/rear, Amsoil front to back, bds 8in long arm kit afe stage 2, smarty tuner, ram air hood, road armor bumpers. Thanks to Northwoods service.
jr22 is offline
post #5 of 23 (permalink) Old 05-01-2009, 06:34 AM
04CoalDigger's Avatar
What about a louder rattle when the mp8 is turned up?
2004.5 2500 QuadCab,DTT, Smarty TNT, F1.2, HTT 62,Air Dog 150
04CoalDigger is offline
post #6 of 23 (permalink) Old 05-01-2009, 06:51 AM
youngcummins08's Avatar
huh, my 96 was like that when it was bone azz cold this winter but doesnt do it when warmer out (+5*f). is that normal for a 12 valve or should i get a set of injectors?
my rig
96 2wd reg cab 2500, 405k miles, sport conversion, K&N. Replacment airfilter, homemade 4in.
youngcummins08 is offline
post #7 of 23 (permalink) Old 05-01-2009, 08:13 AM
Cumminspa75's Avatar
Your 12valve should be fine. Every 12 valve ive ever drove made a different sound and they sound like crap when its cold out and they clean up nice once they warm up. They can be a little cold blooded tho. I think your good on the injectors tho.
2007.5 QBSB 4x4 68rfe. Laramie. Emissions equipment fell off, now tuned with EFI LIVE.
Cumminspa75 is offline
post #8 of 23 (permalink) Old 05-01-2009, 08:24 AM
Some-Sho Some-Go
H.R.D's Avatar
I have seen them make trucks idle really ruff and smoke blue/gray. You should throw a code if injector is going out.
-Jerrod-
2002 3/4 ton X-cab Short Box 4x4 5 speed, Volant CAI, Blue Chip VP44, Edge J/A*HOT*, PDR HX40, AD 100, CFM+, BD short shift, Noise Makers, Flo-Pro SS Duals...
H.R.D is offline
post #9 of 23 (permalink) Old 05-01-2009, 11:45 PM
jr22's Avatar
have had a couple trucks at work with bad injectors and no cel,
jr22 is offline
post #10 of 23 (permalink) Old 05-02-2009, 12:09 AM
Cummins Fanatic/INJECTION PUMP TECH ADVISOR
Freeride202's Avatar
Hard Starting (Hot or Cold)
Leaking diesel into you oil
Blue/White smoke at idle
Excessive Black smoke under load (Depending if Stock)
Rough running at idle
Poor fuel mileage
Injectors only have a life span of about 160,000 miles. I'm not saying they will all pack it in on this exact mileage but the nozzles and ball seats will be warn to the point at which they should be replaced. In the past truckers would change out there mechanical injector as routine maintenance to prevent engine damage and bring their mileage back up. It's only recently with electronic injectors that people only replace one at a time. A big reason for this is cost. No one wants to spend the money to replace a set of injector as preventative maintenance.
Remember computers do a very good job of compensating for bad injectors.
Freeride202 is offline
post #11 of 23 (permalink) Old 05-02-2009, 02:31 AM
ChrBro's Avatar
My 04 knocks and i was told i could have a cracked injector.
ChrBro is offline
post #12 of 23 (permalink) Old 05-02-2009, 09:58 AM
What about this rattle? Rattle with light throttle starts around 1500 rpm. Heavier throttle rattle with go away. No throttle(coasting) there is not rattle. Rattle is coming from drivers side or at least sounds like it. If I hold throttle so it rattles and turn the mp8 up the rattle will get louder. I am running out ideas so I think I will send the injectors off to get checked. Do you guys have any other ideas?
