| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#13 (permalink) |
On the list of aproved oils, what about Chevron Delo 400 LE 15W40 service CJ-4 oil?
04.5 Quad Cab Longbed 2WD, DR600, NV5600, 4.10 gears, with US Gear Overdrive, Valley 5th wheel hitch, Prodigy brake controller and Line_X bed liner |
#14 (permalink) |
just a hair under 7 qts of tranny fluid brought it to the top of the hash marks on the dipstick after i changed the filter and let it all drain for about an hour. this was a great thread for finding which filters and fluids to buy. i have read a ton of threads debating on what filters and fluids are better and everything you have listed sounds like what the majority of people are using.
Happiness is a Belt-fed Weapon
#15 (permalink) |
Nube dodge guy hee. I assume nv5600 adn G 56 are the same tranny? Amsoil has an automatic tranny fluid listed, and the dodge dealer says manual tranny fluid, and on here it says synchromesh manual synthetic tranny fluid. Anyone know what kind of amsoil tranny fluid to run? Also I guess only the mega cabs have the dana 60 front axle, but does it have the anti slip diff just like dana 60 rears? those need a special additive also. In addition to that, amsoil recomends 80w90 for the dana, would severe gear 75w110 work better? I just bought this truck, and I want to get these things right, Also amsoil site recomends 5w40 synthetic formulated for the newer 6.7's for my 5.9, is this correct, or what amsoil should I run? 15w40? Thanks for your help. |
#16 (permalink) |
NV5600 = Synthetic Manual Synchromesh Transmission Fluid (MTF) G-56 = ATF+4 Someone chime in here if I am wrong . All the 3rd gen axles are AAM and not Dana ? I think most guys are using the Amsoil SAE 15W-40 Heavy-Duty Diesel and Marine Motor Oil.
2006 CTD QC 4X4 Big Horn Muffler delete. Tekonsha Prodigy brake controller |
#17 (permalink) |
Super Administrator
![]() Join Date: Jan 2006
I run 15w40. And yes, I believe AAM is correct.
![]() 03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph) July 2009 Cummins Forum ROTM Winner 95 1500 Sport 2wd Cummins Drag Truck under construction. "In search of the Magic Dyno"
#18 (permalink) | |
#19 (permalink) |
I just updated the First post with more info and a picture to help better recognize the G-56 versus the NV5600. Anybody have the fluid capacity and drain/fill plug torque specs for the G-56 ?
#20 (permalink) |
TECH SPECIALIST
![]() Join Date: Jan 2008
MANUAL TRANSMISSION DIESEL ENGINE - G56 5.6 L (12 pts.) TORQUE SPECIFICATIONS Fill Plug 42 Ft. Lbs. Drain Plug 42Ft. Lbs.
John - 03 QC/LB 4x4 5sp Visit the Hoosier Truck Club FTE Diesel FASS giveaway Click here!!!
#21 (permalink) |
Thanks little by little we will get all the info someone might need.
#23 (permalink) | |
#24 (permalink) |
Yep that would make it a G-56. If you drain it to do the service you will identify that familiar ATF smell.
