Does idling in park for long periods of time overheat the transmission? - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 03-22-2009, 07:27 PM Thread Starter
I heard on here somewhere that our automatic transmissions don't circulate the fluid through the cooler when idling in park and it can cause the fluid to burn. It only circulates in neutral. Is this true? Will my tranny burn the fluid if idled in park too long? Will the truck still log idle time if I leave it in neutral?
2007.5 2500 White SLT quad cab 6.7 liter totally stock. Is the CEL supposed to stay on?
34,000 miles. 2nd stock turbo. white 3.73 rear differential ratio. J35 recall. 2 wheel drive. Plan on a DPF and EGR delete when I come up with the $$$$.
2007 cummins 6.7 liter is offline
post #2 of 22 (permalink) Old 03-22-2009, 07:56 PM
WYSIWYG's Avatar
I put my truck in neutral and firmly set the parking brake whenever I let it idle for any extended time.
2006 Blue 4x4 2500 SLT Quad cab Short bed . INNOVATE OT-2 , Chrome valve stem caps!
WYSIWYG is offline
post #3 of 22 (permalink) Old 03-22-2009, 08:15 PM Thread Starter
Do I really need to put it in neutral or is this just a bunch of BS.
post #4 of 22 (permalink) Old 03-22-2009, 08:18 PM
I am on the fourth transmission now and the transmission shop told me that is part of the problem. Prolonged idleing in park. There are two replacement releif valves that will allow fluid to flow when in park.
blondedog is offline
post #5 of 22 (permalink) Old 03-22-2009, 08:24 PM
ynots57's Avatar
idling your truck isn't good for it anyway, on the 5.9 you can get cylinder wash, more than likely it applies to all ctd common rails. there are fast idle features available if not factory equipped.
i wouldnt worry about your tranny building heat because your idling in park. when towing heavy or working truck hard i idle to cool turbo with tranny in nuetral so it circulates and cools before shutting down.
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline
post #6 of 22 (permalink) Old 03-22-2009, 09:24 PM
Ryan_m83's Avatar
Yes it will overheat. I notice my tranny even gets hot in stop/go traffic(I hate driving it in the city). A gauge is a good idea, drop it in neutral and it will slowly kool off.
2001 24V CTD 4x4 QC- Edge Drag Comp, hx40 turbo, Built Tranny, FASS, AFE intake, Mag-Hytec, 4" exhaust, autometer gauges, ISSPRO FP gauge, Red head Steering box, 08+ steering upgrade, 390rwhp & 817tq
Ryan_m83 is offline
post #7 of 22 (permalink) Old 03-23-2009, 07:53 AM
SRXtreme's Avatar
The tranny doesn't circulate any oil at all in park. Any extended idleing should be done in nuetral. Or get your tranny worked over so it pumps all the time. Dodge has done this since day just about one and it's the worst thing for a tranny..............SRXtreme
03 RAM 3500 6 speed 4X4 Edge J/A hot beta,Smarty tnt-r,Custom Magnaflow exhaust, K&N filter. SB 3600. Autometer FP/RP.Carter GP4601HP, rail plug, 2 mic fuel, BMS100, 6.7 dampner Yamahauler more to come atd dual cp3,arp425,hamilton springs. fmw364?over fmw484?
SRXtreme is offline
post #8 of 22 (permalink) Old 03-23-2009, 09:17 AM
cumminspower2's Avatar
what about warming up (when starting) and cooling down (when shutting off)?
do you guys just idle in N for 3-5 mins? And is this O.K.? Cause thats what I've been doing since i got my license exactly 3 weeks ago .
2009 3500 4x4 G56-6: Fully deleted, EFI Live tuning, 33" BF Goodrich M/T's
cumminspower2 is offline
post #9 of 22 (permalink) Old 03-23-2009, 02:13 PM
Ryan_m83's Avatar
When warming it up for a few minutes leaving it in park is fine, same with cooling it off. After a good drive I'll let it idle down maybe a minute or so, or until my egts hit about 300dg, park is fine for this too as your not idling it down for an extended period of time(this would just be wasting fuel)
Ryan_m83 is offline
post #10 of 22 (permalink) Old 03-23-2009, 02:18 PM
Banned
I have never noticed this to be an issue at all. I do have an HTS Valvebody, maybe it makes a difference? I have a tranny gauge and my tranny never goes above 210 even when snowplowing...... On Amsoil fluids, I'm not worried about those temps at all.
JDiepstra is offline
post #11 of 22 (permalink) Old 03-23-2009, 05:19 PM
cerberusiam's Avatar
Yes, a stock trans does NOT circulate fluid in park. There is less than a pint of fluid in the pump gears and that is all the the lube and cooling the pump and TC hub has in park. Needless to say a long time idling is going to cuase issues there. So, no its a load of BS.
Yes, the truck will log idle time as long as the rpm's are under 1100.
Circulating in park can be achieved either wih a shift kit, or the swapping of one valve in the VB. Pretty cheap insurance either way you go.
cerberusiam is offline
post #12 of 22 (permalink) Old 04-11-2009, 11:32 PM
sleeper7's Avatar
what is considered long ilding and if you and a shift kit or swap a valve body iam guessing no factory warranty i just bought my 1st diesel and its still under warranty
07 2500 5.9 4x4 QCSB,
Thanks to all the punks that want to steal I have no Programmer.
sleeper7 is offline
