Injector Troubleshoot - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 02-19-2009, 01:23 AM Thread Starter
How do you tell if an injector is bad or needs replacement? I have one shop saying they are good and another shop saying that its sending a code, but I have no check engine light. Also when the truck is at an idle it makes a click noice. Thanks (i'm updating my info) 04 HO Auto with edge/juice, and BD TC and VB.
fitz95678 is offline
post #2 of 18 (permalink) Old 02-19-2009, 01:52 AM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 12 reviews
I had atick at idle and it got worse as I let out of the clutch to take off. Are you still under warranty?
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, Old Numbers 421/946
1998 P-Pumped 24v, 4x4, NV4500 swap, Valair Dual Disk, BHAF, 4k GSK, .024 Dv's, Fass 150HPFP, Isspro, 5" exhaust, 2" Thuren Coils, Overland Shocks, 305/70r17 Nitto TG, 4th Gen Wheels, Fat Bald Asian 7x.010 Thanks Lee! VP Numbers 359/744
2005 Dually, 285/75r17 Nitto TG, Redhead, Thuren, Edge CTS, Smarty S06
98whitelightnin is offline
post #3 of 18 (permalink) Old 02-19-2009, 02:07 AM Thread Starter
No, have a 130K, but just purchased the truck
post #4 of 18 (permalink) Old 02-19-2009, 02:22 AM
On call 24/7
My CEL didnt come on either but the dealer(under warranty) new which one to replace and did it right. If you dont mind me asking, how much are they gonna charge you to replace injector(s)?
post #5 of 18 (permalink) Old 02-19-2009, 02:36 AM Thread Starter
They gave me an est of 1200 for two of them. It's just I'm not picking up an check engine error code
post #6 of 18 (permalink) Old 02-19-2009, 02:43 AM
On call 24/7
Mine never threw a check engine light either. If you could find out which 2 it was you could do it yourself. They are about $350 each.
post #7 of 18 (permalink) Old 02-19-2009, 02:45 AM Thread Starter
The shop that says I have two going out gave me which ones. But I just want to make sure that the clicking noise is the injectors. Do you think its the injectors
post #8 of 18 (permalink) Old 02-19-2009, 02:51 AM
On call 24/7
Is it more of a ticking that get louder when you take off and then nearly goes away at hwy speed?
post #9 of 18 (permalink) Old 02-19-2009, 02:53 AM Thread Starter
Its a ticking at idle, I can't hear it over the motor when giving gas.
post #10 of 18 (permalink) Old 02-19-2009, 02:56 AM
On call 24/7
Its probably injectors then. Was your truck making oil?
post #11 of 18 (permalink) Old 02-19-2009, 03:03 AM Thread Starter
I just took ownership of the truck, I had a shop check out the truck before I purchased it and they said it needed those two injectors. But since it wasn't giving a code and ran great, I figured they were just trying to sell me. So I purchased the truck at a huge discount being prepared for the injectors and the tranny work. However when I went to start it up "cold" it did the clicking sound. Now for the past two days I've been working with the "at the time" current owner and it made no clicking sounds, but it was always warm and I never got to hear it cold until I started it after the purchase was complete.
post #12 of 18 (permalink) Old 02-19-2009, 03:07 AM
On call 24/7
There all gonna rattle louder on start up when its cold out, if it does it when its at opperating temp then its probably an injector.
