any one know what this code means. truck runs fine but just threw this code. P2509 ECM/PCM Power Input Signal Intermittent???
I sprung the U0141, U0100 and the C2202 but cleared them and they didn't come back. I only have the P2509 now..This same thing just happened to me 2 days ago, have you had any luck figuring it out? The shop its at tells me its the PCM, everyone on here is telling me to check the grounds first, which I'm gonna do as soon as it stops raining. It threw a bunch of codes, but they gave me 4 which are:
U0141- LOST COMMUNICATION WITH IPM-FMCM-TIPM
UU100- LOST COMMUNICATION WITH PCM/TCM
C2202- ORIGINAL VIN MISMATCHING/ MISSING
C2206- VEHICLE CONFIGURATION MISMATCH
The other ones all had to do with the TIPM and PCM he said. The tech said the only module he couldn't talk to though was the PCM.
If you have ascertained that the batteries are good. You have a bad ground.There are two grounds on the engine block one each side. There is one on the drivers side under the hood on top of the inside fender. This is a ground connection with several straps going to it. Make sure these are clean. They may look mclean ,but remove them and make sure.I also got the same code, but my truck wont start unless it is jumped off with another vehicle.
