why do people idle their diesels for long periods of time? - Dodge Cummins Diesel Forum
post #1 of 146 (permalink) Old 01-10-2009, 01:00 PM Thread Starter
I always see people who just leave their trucks idling even when they are not in it. sometimes they leave them running for up to half an hour. Why is this?
I thought idling was bad for the engine.
2007.5 2500 White SLT quad cab 6.7 liter totally stock. Is the CEL supposed to stay on?
34,000 miles. 2nd stock turbo. white 3.73 rear differential ratio. J35 recall. 2 wheel drive. Plan on a DPF and EGR delete when I come up with the $$$$.
2007 cummins 6.7 liter is offline
post #2 of 146 (permalink) Old 01-10-2009, 01:03 PM
02bbcummins's Avatar
Idling in park is bad for these trucks because the trans doesnt flow fluid in park, at least the 47re doesnt. u would think that dodge would have fixed that by the time they got to ur year, i dunno. but either way if the trans isnt flowing fluid it is heating up which we all know what heat does to things. thats the only negative reason i can think of for leaving it idling. im pretty sure there really isnt anything that will happen to the motor itself if u leave it idling.
-Billy 02 QC Dually 4" SJ susp 285 BFG MT's, CFM intake manifold, S&B intake, 100hp FBD Injectors, 4" turbo back straight pipe, quad. Xzillaraider, goerend triple disk TC, Billet input shaft, Raptor 100GPH pump
02bbcummins is offline
post #3 of 146 (permalink) Old 01-10-2009, 01:04 PM
m5b6l's Avatar
most of the time i leave mine running is because im just going to do a quick in and out of a store, and sometimes you get caught up with something making me leave it running longer then i originally wanted.
14' CHEVY 2500HD LML
SOLD - 00' - 160 pump 4k gsk - DTT - 62/75 twins - SDX 7x.014 - Airdog - ARP - Hamilton 188/220
m5b6l is offline
post #4 of 146 (permalink) Old 01-10-2009, 01:07 PM
Diesel Junkie
TVtruck's Avatar
Cylinder wash is another reason to not let it idle to long.
Even if I'm just running into the post office for a few min's I set the high idle.
Tim
2010 3500 C&C 4X4 ;EBY Built Flatbed ;H&S Black Maxx; DPF/EGR Delete; S&B CAI;South Bend CAISDD3600-GK,
Ohio Coal Rollers
Cumminsforum.com
TVtruck is offline
post #5 of 146 (permalink) Old 01-10-2009, 01:10 PM
R_Zachs's Avatar
i dont have high idle or i would do that. every store i go into around here i leave the truck running. no more than 10min though
05 3500 QC LB SBC DD 3250| ISSPRO fuel/EGT/Boost| S-06 TNT-R| DDP50's| II BOP| AD100| S&B Elbow & CAI| II Silver 62| PDI 2Pc.| 5"TBE/51" Donaldson| Procomp| Hellwig| T-REX Flatbed/Steps| Thx to ALGTR PERF & DDP
R_Zachs is offline
post #6 of 146 (permalink) Old 01-10-2009, 01:13 PM Thread Starter
I have heard that it takes as much fuel to start a diesel as it does to just leave it idling for like 10 minutes.
So I can see why people leave them running when they go into a convenience store but I see people running them for hours on end. Is it hard on a diesel to start it up?
post #7 of 146 (permalink) Old 01-10-2009, 01:14 PM
smokedrail's Avatar
iTrader Score: 4 reviews
Some People think cuz it is a diesel they need to let it idle all the time.
Honestly the 12v are really the only ones that should be left at an idle for a long time
06 cummins
96 cummins
95 cummins dump
smokedrail is offline
post #8 of 146 (permalink) Old 01-10-2009, 01:15 PM
kooimanj's Avatar
High Idle is bad. Idle is worse. Unless you are trying to stay warm/cool there is no reeason to idle other than turbo cool off. Leading cause of premature head gassket failure in a caterpillar is excesive idle.
2001 Dodge Cummins Sport. Got a few goodies. Starting to gather parts for a P-Pump convert.
kooimanj is offline
post #9 of 146 (permalink) Old 01-10-2009, 01:18 PM
I forgot about wash down. i wouldnt worry a whole lot about wash down tho unless u got aftermarket injectors. stock injectors spray pattern is pretty much the best around so u will be less likely to get wash down then with any other kind.
post #10 of 146 (permalink) Old 01-10-2009, 01:21 PM
what is the difference between high idle and running down the high way at 65... now, i know u r making boost at highway speed which would be harder on the heads, but ur running higher rpms then just idling at 1500 rpms. im just not buying that idling hurts ur motor when ur stressing it less then actual driving conditions... help me understand
post #11 of 146 (permalink) Old 01-10-2009, 01:26 PM
R_Zachs's Avatar
if idling hurts why would they sell a truck that idles? i myself havent had any problems with any of my personal trucks or work trucks because of idling. i think its the way you run it. if your hard on it, it will go down. ol' lady driver will make it last longer unless there is a defective part.
R_Zachs is offline
post #12 of 146 (permalink) Old 01-10-2009, 01:28 PM
World Champs!!!
MoparProud's Avatar
How so?? Please explain...I dont see how idleing, especially high idle, will damage a head gasket...? Ive heard the cylinder wash argument, but thats what high idles for...
I idle mine all the time. Start it up, let it run a bit to let some oil run through it, hit high idle, let it warm up, and go. I always let the engine/trans warm up before I drive it. And since I have a built trans, fluid flows in Park. I dont like the thought of using full power on a cold engine; since I get on the interstate almost immediately, I use all (or much of) the available power within 30-45 seconds of leaving my place...
And I let it run filling up. Let it run if Im making a quick stop at the store. Occasionally I space it out and it runs longer (it ran for over an hour last night before I left work; got busy wrapping up from a job and forgot about it. Sure was warm when I got in it!!)
'07 3500 SRW QC/LB-EFILive w/Silverbullet Tuning-Goerend-WOP triple turbo-200% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
