Old 03-22-2009, 04:38 AM   #25 (permalink)
crazycatman's Avatar
Excellent info. I put one in mine earlier today. I did use the resistor and put it on the ground side. It works great.
I did some other work and ended up with a P0073 code. According to my cheat sheat that is for ambient temp so I don't know what's up. I did clean the air filter. I checked the connector etc and all seems fine.
Anyway to clear my code? disconnet batteries? or do i have to go see someone?
04.5 Qd CB 4X4 AT, Super "B" Special, 'Pusher' int horn, PacBrake, Edge w/Att, S&B Cool air, 4" MBRP, 35 Toyo MT's, air bags, spr hitch, B&W gooseneck hitch, BD Trani parts, guages, lock up switch, smoke switch, horn blstrs
crazycatman is offline   Reply With Quote
Old 03-22-2009, 05:29 AM   #26 (permalink)
New Mexico Chapter President
sofakingbad's Avatar
i gotta do this one of these days.....nice write up man
05 Cummins 4x4 auto
01 cummins 2wd 6speed
06 Duramax LBZ- sold
sofakingbad is offline   Reply With Quote
Old 03-22-2009, 09:52 AM   #27 (permalink)
Tech Specialist
wildcat's Avatar
A Smarty will clear the code if you know someone that has one. Also you can take it to an Auto parts store and have them clear it for you.
Bill Mish
2007 Dodge 3500 4X4/5.9L/48RE, KORE, SRT-10 hood, Recon, Isspro, ICEBOX/Amsoil, Walbro, SMARTY, FBD CFM+, FBD HGD, FBD 5" exhaust. FBD TC & VB 458hp/1005tq
ACDC
wildcat is offline   Reply With Quote
Old 03-23-2009, 03:33 AM   #28 (permalink)
Originally Posted by cumminalong View Post
If you don't use the resistor, you need to pull the tranny relay (#59) on the earlier 3rd Gen trucks. If you use the resistor, you don't need to jump the relay.
You can install the switch without the resistor by jumping post 30 to 87 on that relay.
So on a 2003, I have the option of using the resistor or putting a jumper on the relay?
The resistor seems like the cleaner way to install it.
Anyone know where to find a momentary on foot switch?
RPMWFO is offline   Reply With Quote
Old 03-27-2009, 10:09 PM   #29 (permalink)
CumminsBeast's Avatar
Basically this mod allows you use your tranny as a stick.
The only time the TC locks normally is in 4th gear. In T/H mode, it will lock in 3rd.
This will allow you to pick a gear and lock the TC in 1st or 2nd.
It's a GREAT mod for exhaust brake use if yo udon't have one of the stand alone controllers.
Have you ever ran at the track in T/H mode? I would think it would yield better times.
Thanks for the info on the 3rd gear lockup! I had been wondering about this.
'06 5.9 Reg Cab/48RE/ED 64-71-14/Smarty TNT/Quad X2/5" STR8/AFE Stg II/FASS 150/25hp DDPs/Snow MPG Max/ARPs/ATS Elbow/A.M. Trans & Fuel guages/ATS Stage VI/35"Toyo MTs/20" MKWs/4.5" lift/13.59@102http://s41.photobucket.com/albums/pp241/nfgibs2/
CumminsBeast is offline   Reply With Quote
Old 04-06-2009, 11:32 PM   #30 (permalink)
Originally Posted by Neel View Post
some other thread told me to put the 33 ohm resistor on the ground side? no wonder it never worked.
My truck is a 06 and it dose not work or lockup with a 33OHM resistor. I endup using a 10 ohm.
fulano456 is offline   Reply With Quote
Old 04-28-2009, 10:42 PM   #31 (permalink)
can you get a switch with a light on it so you know when it is locked? like light on when the locked and no light when off? what kind of switch?
2005 Dodge Ram 3500 SRW 4x4 - Hell bent 2" leveling blocks, 35x12.50x17 Toyo open country MT, Heavy Hauler race trans, Smarty, FBD 5",ADII,Arson III,F1 injectors
Revolution is offline   Reply With Quote
Old 04-28-2009, 11:04 PM   #32 (permalink)
yes u have 2 wire in a relay since u r dealin with ground so the relay will power the switch.
one of they guys made a diagram and poste it some where. i'll try to find it and post it for you!
it is on this thread. i couldn't figure out hoe to link it.
peace
Does anyone know how to wire a TC lockup switch "On" light?
Old 04-28-2009, 11:05 PM   #33 (permalink)
Mkoegel's Avatar
subscribed
06 2500 4x4, Banks Big Hoss, 6 gun, silencer gone, exaust dump, train horns, blacked out lights 37" Nitto Grapplers. Goerend full built, maybe soon to come.....Turbo, Injectors, and fuel system. then no more haha
Mkoegel is offline   Reply With Quote
Old 04-28-2009, 11:40 PM   #34 (permalink)
Robear's Avatar
I'm kinda new to the cummins world so take it easy on me. I've heard a lot about the cummins lock up switch, but I'm not sure what its for. I know it's for lock up, but how is it useful? towing? racing? Also doesn't the torque converter have to unlock for it to shift. Seems like a lot of trouble to go screwing around and messing up the tranny.
2003 3500 CR, Single rear wheel, bully dog outlook monitor, SMARTY on the way!!!, 4" exhaust, 4" lift, Bilsteins, 35" dunlop mud rovers, BIG plans in the works.
Robear is offline   Reply With Quote
Old 04-28-2009, 11:55 PM   #35 (permalink)
Thats why you need billet shafts and a good torque converter.
06 Mega SRW. Where did that silencer ring go?
dfcfu342 is offline   Reply With Quote
Old 04-29-2009, 02:04 AM   #36 (permalink)
cbtoyz's Avatar
Yeah, I have a late model '06 ('07) I had to use a 10ohm resistor also. It works great! I wired it up to a push on/ push off switch.
Colin-'06 QC, SB, 4x4- 853hp/1467 & 11.30@122mph. Thanks, Brad and everybody at Ponci's Diesel Center, Dave Goerend and everyone who helped along the way!
cbtoyz is offline   Reply With Quote
