5.9 Block Drain Plugs? Coolant Flush - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 12-17-2008, 10:29 PM Thread Starter
Canadian_Diesel1964's Avatar
Hey guys...I want to drain all the coolant and water out of my 04...I have 50/50 diesel specific premix to add back into it but want all the water drained after the flush...any one know the exact location(s) of the Drain Plug(s) in the block? Any help is always appreciated..Thanx from Damn Cold Canada
2004 2500 4X4 Mag-Hytec Tranny Pan, Frantz TP Filter, Coolant Filter, MBRP 4" TBE with FTE Resonator, Raptor100 with WS and 2 Mic Filter also in box, XRF Ball Joints and All 4 Tie Rods
IAFF LOCAL 142
(Professional Firefighter)
Canadian_Diesel1964 is offline
post #2 of 7 (permalink) Old 12-17-2008, 11:21 PM
parklane's Avatar
Smile
Hey,its not that cold. I live only 8 miles away from you
Pearlblack 06 QC 4x4 auto. BHAF, Home made CAI, Edge juice with attitude, 80 gal polished saddle aux fuel tank.
If you don't like the way I drive, stay off the sidewalk
parklane is offline
post #3 of 7 (permalink) Old 12-18-2008, 02:20 AM
Clinton's Avatar
Location: Timmins ON Canada. The Land of 2 Seasons: Rainy & Snowy
I looked in the shop manual, and it doesn't show one, or mention one for the cummins. The procedure in the manual is to drain from the radiator drain plug.
Clinton is offline
post #4 of 7 (permalink) Old 12-18-2008, 08:26 AM Thread Starter
Thanx for the info...and its cold when you are doing your brakes today!! St Thomas...Cool!
IAFF LOCAL 142
post #5 of 7 (permalink) Old 12-18-2008, 02:03 PM
The radiator drain plugs have a tendency to break or at least tear up the o-ring when draining. Have the parts on hand if you need the truck right away or ignore the drain plug and just remove the low radiator hose.
Moving this where it belongs.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #6 of 7 (permalink) Old 12-18-2008, 03:13 PM
If you want to drain the block, on the rigth side of the engine is couple plugs that are below the exhaust manifold. If you remove the intake off the turbo, look behind the oil filter, you will see the plugs in a row. I know they are there, have drained the block that way to install my webasto coolant heater.
han solo is offline
post #7 of 7 (permalink) Old 12-19-2008, 12:53 AM
bigcalidave's Avatar
You want to do it the right way find a shop with a coolant flush machine. It interrupts the flow on one of the radiator hoses, and when you flip the valve it fills everything with new fluid while draining the old.
Best way possible to flush it!
Truck for sale!!
Sad but has to happen!
bigcalidave is offline
