Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 10-25-2006, 06:55 AM   #1 (permalink)
i need help please
hey guys, first off let me say i love the web sight. I do not post much I just like to read but I have a problem and I know that someone on here will be able to help.
My truck is an 06 auto w/6 k miles. I bought an edge w/attude and when i installed it I felt no performance gains, talked with edge and they said it worked correctly. So I uninstalled it and bought a quadzilla and still i cannot feel a performance gain, i can see more smoke but I cannot feel a difference unless I am on the high way, but even then the gain is no much.
Sence the purches of the quad i have sold the edge to a guy w/ an 06 auto and he loves the thing, he says he can smoke the tires. The only way i can break them loose is if i stand on the brake.
I feel like the trans is slipping but I am not for sure.
my mods are 5" exhaust no cat no muffler, quadzilla intake, quad race, no silencer ring, 5" lift and 35" tires
What could be the problem? Please help
silversvt is offline   Reply With Quote
Old 10-25-2006, 07:28 AM   #2 (permalink)
trik396's Avatar
You should feel something... not necesarily smoking the tires, but definate seat of the pants improvements. It is like night and day, so something is causing you to not get the power to the ground. Maybe it is your trans. I can tell you from experience that those big 35" tires kill your performance and mileage. But you should still feel the power. Depending on your future endeavors, a VB and Converter should be considered, at the least... Good luck...
2005 DodgeRam2500 CTD/ 4x4/ BigHorn/ Autometer/AmsoilBypass/AemBruteforce
Trans by Goerend/ Walbro392custom fuel system/CAT2micfuelfilters/IISilver64/BanksIC
Projector HID's/DiablosportPredator/VanAaken3.2/QuadsXZT
617hp 1200+trq
KOREChasewFoxShox/Carli&FoxDualSteeringStabilizer/ NittoTerras285's
3 people can keep a secret if 2 of them are dead...
trik396 is offline   Reply With Quote
Old 10-25-2006, 01:40 PM   #3 (permalink)
i had the programers on before the lift, when I had stock tries.
do you guys think i need a pusher pump, or converter first
Old 10-25-2006, 02:53 PM   #4 (permalink)
Upstate Diesel Performance
Diesel Dummy's Avatar
do the 06's tap yhe wire or no...
If you need it we sell it! if you think you need it, we sell it! Even if you don't think you need it, but want it, we sell it! Thats it.
Upstate Bombers Site
Diesel Dummy is offline   Reply With Quote
Old 10-25-2006, 03:42 PM   #5 (permalink)
trik396's Avatar
If your not feeling any power from a box or programmer then something is wrong. I don't know if anyone knows how to check if the trans is slipping that badly, but I'd get it checked out somehow. And a better fuel pump couldn't hurt, and would only help in the future.
617hp 1200+trq
Old 10-25-2006, 04:15 PM   #6 (permalink)
Dodgezilla's Avatar
Even if the trans was slipping you would still feel the power. Are you absolutely sure that you are connecting them right? If I turn my TST on 1/0 which is just a bit of timing I can feel a difference in power.
SOLD!!! 08 Ram 2500 Mega 4x4,68RE,6.7,Loaded Laramie,SRT10 hood,Sunroof,DVD,Nitto 285s,Polished Alloys,Fogzilla,Rear Spoiler,MOPAR Grill Guard,H&S StageII,AFE Drop-In
Looking for my next truck. Do you have it?
Dodgezilla is offline   Reply With Quote
Old 10-25-2006, 04:29 PM   #7 (permalink)
Tech Specialist/Super Moderator
TrueValue Truck's Avatar
Something is wrong.......I have the Xzillaraider 100hp box....yours is 130hp.
It's like night and day with the 60hp and 100hp setting. Sounds like the box isn't communicating with the truck...be it a bad connection or hooked up wrong...mabe even a problem with the truck map sensor wireing.....mabe quad can jump in here with some suggestions.
Caldwellfire.com
06 3500 SRW MC ,Smarty REVO,X2 Race stack, Commander,CFM, Monster Air COI,AFE Torque tube,FASS 150 HPFP LP,Muffler delete,Tipple disc Converter and VB ,ProComp 2" leveling kit,Timbren's,Reese Class V Tow Beast
Ohio Coal Rollers
Cumminsforum.com
TrueValue Truck is offline   Reply With Quote
Old 10-25-2006, 04:59 PM   #8 (permalink)
i live close to the quad shop went up there, had him look at it and he said it was working correctly. I think my converter is slipping bad, let me tell you why, at a stop if I floor it the boost jumps to 38# egt jumps to 700 and rpm's shoot up to 3000- 3100 and stay there unitll my trucks speed catches up enough to shift gears, once the tranns shifts into 2 nd rmps drop to around 2200 and then fly to 3100 and stay there untill my truck speed catches up........so on and so forth
Old 10-25-2006, 05:01 PM   #9 (permalink)
COAL CRACKER
CTD610's Avatar
Sounds like converter problems to me. Probably way over due for some beef ups.
2006 RAM 2500 QC SLT 4X4 - THUNDER ROAD PKG - CTD - 6spd - AEM Brute Force CAI-HURST T Handle
Old Truck: 2001 Silverado 2500 HD 4X4 Duramax/Allison
IBEW 1600
CTD610 is offline   Reply With Quote
Old 10-25-2006, 05:10 PM   #10 (permalink)
Dodgezilla's Avatar
6000 miles????? I'd pull any box off that truck and get it to the dealer if that's the problem.
Old 10-25-2006, 07:17 PM   #11 (permalink)
trik396's Avatar
Thats what I'm thinking... Plus earlier he said he was making smoke, so he's getting the extra fueling from the box, but the power is not making it to the ground.... Tranny time...
617hp 1200+trq
Old 10-26-2006, 06:58 AM   #12 (permalink)
Or tap the #7 wire on the ROUND plug for the tranny (if the same for 06), run it to a switch and then to a 33 ohm resistor and then to ground. That will lock up the TC at the push of the button. That would get the power to the ground if you thought it was slipping.
BUT, if it is slipping, not sure how long that game would last as you would probably cook your TC.
Pull the box, head to dealer to have checked out.
Scott
2005 2500, Auto, TC lockup switch, RokkTech sensor, RokkTech muffler, Gutted chrome torque tube, Ram Snorkel on air box, Mopar cold weather kit. Pro Comp Extreme A/T 35's.
Nuttymopar is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
