Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 10-22-2006, 10:31 AM   #1 (permalink)
Cummins600's Avatar
TST and BDDL
Well after getting a few miles on the new Goerend tranny I think I have broken it in pretty good. I decided to go ahead and download the BDDL and the use the TST. I put the BDDL on "Tow" and left the TST on HP=1/TQ=0. I started on my way to Indianapolis and noticed that every time I went up a hill with the cruise on the truck would surge when it topped out the hill. It felt like I was hitting the rev limiter. I know it was cutting back since it was going over the set cruise speed, but it did it every time over the 77 mile trip. I ended up turning the TST to 0/0 and it was better, but still occured. So I know the issues were with the BDDL. No codes or anything. I guess I am curious if any of you guys have noticed this driveability issue with this set-up.
I like the BDDL for off the line, but at times I think it is a little aggressive. I have considered trying some different modules/ programmers to see what they do. Since I drive the truck daily on the highway I use the cruise a lot, so the surge issue is a little of a concern. Any suggestions of what works great as a stack with the TST that will give me similar off the line power? MP-8, Quadzilla, Edge, Smarty, etc???
Bryan
2004.5 Cummins HO CCSB 4X4 SLT, TST PMCR, BDDL, HTB2 62/14 Turbo, Goerend Full Billet Trans w/ Triple disk converter, FASS 95 GPH, Amsoil 4090 w/ K&N intake, Magna Flow 4" SS Exhaust, MBRP 5" SS tip, Smittybuilt SS Nerf Bars, Westin SS Grille Guard, Di-Pricol Optix Boost, Trans, Pyro, and Fuel Gauges, Tuff Country 4.5" Lift, Eagle 178 18x9 rims w/ 35/12.50/18 Toyo Open Country MT's, Bushwacker Extend-a-Fender Flares :thumbsup
Cummins600 is offline   Reply With Quote
Old 10-23-2006, 08:06 AM   #2 (permalink)
Cummins600's Avatar
So do I take it that no one else has this problem with the Bullydog?
I had also heard that the Bullydog being downloaded and removed and then using another downloader can cause problems. I was looking for some sort of module suggestion you guys have tried that wake these trucks up down low, but still work well with the TST.
Bryan
Old 10-23-2006, 08:23 AM   #3 (permalink)
I dont have an answer but I've had good luck with the tst/bully dog stack.
'05 4x4 2500 Quad Yellow - HTS - GDP - F1
'03 4x4 3500 Quad DRW
Luken is offline   Reply With Quote
Old 10-23-2006, 01:40 PM   #4 (permalink)
973604x4's Avatar
I don't have an answer either but i love my TS MP8 with my Hot Juice.
08 LMM cc swb 4x4, bumpers, tint, torsions cranked, H2 wheels, 285's......95 12valve ext cab lwb 4x4 5spd, pretty much stock.....92 IDI ext lwb 2wd......SOLD: 05 cummins. 600+hp
973604x4 is offline   Reply With Quote
Old 10-23-2006, 09:04 PM   #5 (permalink)
Cummins600's Avatar
I have been thinking of the TS Performance MP-8. Maybe on a low setting I wouldn't have any problems and get a little more on the bottom end. I wonder what the Van Aiken or Edge EZ would do?
Bryan
Old 10-24-2006, 10:22 AM   #6 (permalink)
RDyson's Avatar
I have the TST/EZ stack on mine. The EZ does give me the surge with the cruise on when below 70 mph. Running 75-80 I don't notice it. Mine is an 03 with the vacuum controlled cruise control. I had not heard of the newer ones having a problem with the EZ.
Randy
03 SO/Auto, QC/4X4, TST/Smarty, Boost/Fuel/Pyro/Rail Pressure, SPS-62, Goerend, Amsoil 4510, Walbro, Arson CP3 Kit, GDP Power-Flo, Grid Eliminator, Fuel Tank Vent Mod, Donaldson 51", Flux 1's, ARP, 605/1172, 13.16@108.2
RDyson is offline   Reply With Quote
Old 10-24-2006, 11:14 AM   #7 (permalink)
Dodgezilla's Avatar
I think you can stack a VA C3.1 with it but not a C3.2. It's a duration box and the TST already does duration.
I have just the TST on my truck right now and don't like it at all. Since installing the new turbo it takes a lot of throttle before the TST starts fueling. Once it kicks in it is brutal and the RPMs shoot up to redline in an instant. I hit 3500rpm yesterday and I was only on level 2/2!!!! I'm going to put my MP8 back on and hopefully that will give me my bottom end back and make it so I don't need so much pedal to make this thing move. I had both boxes on before the turbo install and the only issue then was lack of fuel. I'll be needing a better LP soon if I plan on running both boxes......
SOLD!!! 08 Ram 2500 Mega 4x4,68RE,6.7,Loaded Laramie,SRT10 hood,Sunroof,DVD,Nitto 285s,Polished Alloys,Fogzilla,Rear Spoiler,MOPAR Grill Guard,H&S StageII,AFE Drop-In
Looking for my next truck. Do you have it?
Dodgezilla is offline   Reply With Quote
Old 10-24-2006, 12:37 PM   #8 (permalink)
If you want some real low end power, get a Smarty:thumbsup
2005 Dodge 4x4 dually G56
AEM intake, Quadzilla boostfooler
Smarty, Edge EZ, Roktek sensor
Autometer gauges, BD low FP light w/Autometer warning light
Stainless steel fuel system W/ FASS 150, and Big Fuel kit 2 micron. waiting..............
c'MON clutch....
Here come the twins....
GOT SMOKE???
http://cumminsforum.vidiac.com/video...5200d341f1.htm
Heres a quick video of my "mud drag truck"600+hp:thumbsup
https://xch.performancetruck.com/exc...66010c680c.htm
"Show truck"
2000 Dodge 2500 4x4
8" lift 35" Boggers Mopar Crate perf 360 balcd/blue prt
port polish/ shaved heads MSD, Borla, Edelbrock, Jet, Hypertech, DVD, Xbox, PS2, air bag suspension.
Custom trans by John Gobel w/2200 stall
Flames, ect ect ect
BodieArmstrong is offline   Reply With Quote
Old 10-24-2006, 10:03 PM   #9 (permalink)
Dunks Performance
for drivability I would use a flash pack. I did a lot of towing with fp on performance and tst on timing only. This worked awesome with no smoke and great low end power even with my 66. The BD I feel is gaining about 30hp but i give up a lot of drivability and the damn thing smokes like a dirty bastard.
New Ride 2007 CTD Mega Cab Laramie, electric blue with a 5.9. 7" DP Motorsports lift, 37" toyo's, 22" KMC Hoss, 5" magnaflow ss exhaust, Smarty, AFE II, 14.11 @ 96 PIR
Dunks Performance is offline   Reply With Quote
Old 10-25-2006, 06:44 AM   #10 (permalink)
Farmboy's Diesel
farmboysdiesel's Avatar
Several guys around here are running the MP8 and the Smarty stacked with the TST and have had great results and they've got some really good running trucks. It's very impressive what the MP8 and the Smarty do as far as smoothing the TST out. No experience with the Bully Dog/TST stack though.
Farmboy's Diesel Performance
FBD BUDGET EXHAUST
Products By: FBD, AirDog, Blue Chip, DDP, Smarty, TS, MaxSpool, HaloMax Springs, Grand Rock, Fluidampr, AFE, Edge, TST, MBRP, Industrial Injection, ARP, Auto Meter and More
704-290-2289
1999 Dodge 2500 4x4 II 66/FBD2 TWINS, 7in Stack, HTS/FBD Tranny, DDP Inj's, FBD Trik 3VP, HaloMax Springs, MaxSpool, NX SD2, Fluidampr, DragTST
Check out www.farmboysdiesel.com
farmboysdiesel is offline   Reply With Quote
Old 10-25-2006, 05:39 PM   #11 (permalink)
Cummins600's Avatar
Well, when looking around the MP-8 is less of an expense....so I might just run that one and keep it on low settings (except if I want to play) since it is supposedly fuel pressure. I know that some guys have even run a BDDL, TST, and MP-8 stack...but I don't think the factory turbo would llike that at all. Thanks for all the replies and I will let you all know what I decide and how it works. Any other suggestions...throw them at me!!
Bryan
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
