Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 10-19-2006, 05:21 PM   #1 (permalink)
Doughboy21kd's Avatar
Fuel Pressure gauge Install Questions??? HELP PLEASE
I just got my Di-Pricol FP Gauge kit and i have everything i need....
Gauge
Isolater
High Pressure hose
Banjo Bolt
Nylon tubing
Needle Valve
gauge Mount
Now my question is: Does anyone have pics of where to put Banjo bolt? I was wondering if anyone knows where or has done a FP gauge install write up?
Where does banjo bolt go? how do i fill isolater? where do i fill isolater?
Is there any torque specs for Banjo bolt?
Do i need to use sealant tape or permatrex on any of the fittings? If so which ones?
THANKS
2002 Dodge 2500HD, Di-pricol pyro, boost, Fuel pressure, Jammer 2 injectors, Rip's 4" Exhaust, Raptor Lift Pump, mostly stock for now.
Doughboy21kd is offline   Reply With Quote
Old 10-19-2006, 06:06 PM   #2 (permalink)
Tech Specialist/Super Moderator
TrueValue Truck's Avatar
Follow the line from underneath the fuel filter to the CP3. The bolt on top where it feeds into the pump is where I put mine. Some guys will use the fitting on the bottom of the filter housing....you'll get the same reading , but the one on top is easier to get to.
Fill the non fuel side of the isolator with antifreeze , then what I did was "suck" the antifreeze up to the end of the hose in the cab , then connected the line to the isolator and gauge.
The only thing you need on the banjo is a new brass washer/gasket...should come with the banjo.The pipe thread fittings , use thread sealer.
Sorry , I didn't do pics...and this was on my previous truck.
Caldwellfire.com
06 3500 SRW MC ,Smarty REVO,X2 Race stack, Commander,CFM, Monster Air COI,AFE Torque tube,FASS 150 HPFP LP,Muffler delete,Tipple disc Converter and VB ,ProComp 2" leveling kit,Timbren's,Reese Class V Tow Beast
Ohio Coal Rollers
Cumminsforum.com
TrueValue Truck is offline   Reply With Quote
Old 10-19-2006, 09:32 PM   #3 (permalink)
First off THANKS....Second What happens if i dont "suck" the antifreeze up? Is it supposed to be straight 100% antifreeze? After looking at my banjo bolt it DOES NOT have the brass washer/gasket....Is that gonna be a problem? Do i need it? And what should i use for sealer? Permatrex work? Is the banjo bolt the only thing i need to put sealant on?....
THANKS i wana do this right the first time around.....:thumbsup :thumbsup
Old 10-20-2006, 07:27 AM   #4 (permalink)
Will work for BOMBs
Harley27's Avatar
The washer/gasket is on piece that goes on the threads of the banjo where you connect it to the pump. I recommend replacing it and you should be able to get it at your local Auto store. I used permatex on the pipe fittings going onto the sender and into the banjo bolt then connected it with a chunk of fuel hose and clamps. I used electric gauge so cant help with the antifreeze thing.
2006 Ram 2500 QC SB 6 Speed 4X4
Smarty, Banks High Ram intake, Silverline turbo back,
AEM Workhorse, Line-X, Auto Meter Fuel pressure, Boost, EGT,
BFG AT's , Airdog 150 and Southbend DD .
Harley27 is offline   Reply With Quote
Old 10-20-2006, 07:40 AM   #5 (permalink)
Just use streight antifreeze....you need to get all the air out of the line from the isolator to the gauge to get a good reading. I had just a small air bubble in mine , but it worked fine.You should use a new brass washer , but you might try useing the one from the facrory bolt if its not bent or smashed out to flat.
I didn't use any thread compound on the banjo bolt...only on the pipe thread fittings. That would be the fittings that go into the isolator and the one that goes into the back of the gauge...plus any reducer bushings if you had to use any.
It helps to have someone help you while filling the line with antifreeze. I had a guy hold the line in the gallon jug while I drew the antifreeze up to the cab...and yea...your cheeks will get tired...lol. As soon as the antifreeze gets to the end of the line , hold your finger over the end to keep it from draining out while your helper connects the line to the isolator.Then hook it up to your gauge.
Caldwellfire.com
Ohio Coal Rollers
Cumminsforum.com
Old 10-20-2006, 07:45 AM   #6 (permalink)
Oh yea.....DO NOT overtighten the Banjo...just make it snug. I don't recal any torque specks with the install instructions when I did mine , I just know you do not want to dammage the threads ! Check it after you fire it up and after a few hours of use.
Caldwellfire.com
Ohio Coal Rollers
Cumminsforum.com
Old 10-20-2006, 08:51 AM   #7 (permalink)
staarma's Avatar
Sorry the pics late. Maybe someone searching this thread will at least get to see it.
staarma is offline   Reply With Quote
Old 10-20-2006, 11:15 AM   #8 (permalink)
Cummins600's Avatar
Check my garage. I should have a pic in one of my folders with a diagram of the CP3 and the banjo bolt location.
Also, you should have the washers on the pump. Sometimes they stick to the metal tubing or to the factory bolt when you pull it out. They can be re-used if they look undamaged. I did get a new set after taking them out a time or two. If I recall, the banjo bolt should only be torqued to 18 ft-lbs.
Bryan
2004.5 Cummins HO CCSB 4X4 SLT, TST PMCR, BDDL, HTB2 62/14 Turbo, Goerend Full Billet Trans w/ Triple disk converter, FASS 95 GPH, Amsoil 4090 w/ K&N intake, Magna Flow 4" SS Exhaust, MBRP 5" SS tip, Smittybuilt SS Nerf Bars, Westin SS Grille Guard, Di-Pricol Optix Boost, Trans, Pyro, and Fuel Gauges, Tuff Country 4.5" Lift, Eagle 178 18x9 rims w/ 35/12.50/18 Toyo Open Country MT's, Bushwacker Extend-a-Fender Flares :thumbsup
Cummins600 is offline   Reply With Quote
Old 10-20-2006, 11:27 AM   #9 (permalink)
Cummins600's Avatar
I used a master cylinder vacuum to pull the antifreeze up on mine. It worked pretty quick that way. The more air you get out, the better. The antifreeze will be on the gauge to isolator side of the isolator. The other will be the fuel side. You should also have a bleeder screw on that one. You can turn the key on and let the fuel pump cycle a time or two then crack the bleeder to get some air out. I found that starting the truck works real well. You can crack the bleeder then and get just about all the air out. Just be careful to only crack the bleeder screw.
It is really a pretty easy install when you have all the pieces like you do. Hope it all works well. Let us know.:thumbsup
Bryan
Old 10-20-2006, 10:47 PM   #10 (permalink)
Thanks for the info....Is there any tips or tricks i should know before i do this tommorrow?
How many sealer washers do i use on the banjo bolt? Just 1 right?
I actually bought the cummins gasket sealer washers...they were a FREE-BEE
Curious cause they come in a 2 pack....THANKS
Old 10-21-2006, 01:58 PM   #11 (permalink)
Only use one..and make sure the old one isn't stuck on the top of the pump..:thumbsup
Caldwellfire.com
Ohio Coal Rollers
Cumminsforum.com
Old 10-22-2006, 08:00 AM   #12 (permalink)
Cummins600's Avatar
On my factory set-up it had one between the fuel line and the Cp3, and another between the top of the fuel line and the banjo bolt. Guess it wouldn't be totally necessary for the top one especially since the factory system is so low pressure.
Bryan
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
