Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 11-10-2008, 06:55 PM   #1 (permalink)
DUKCALN's Avatar
Installed MP-8, questions on functions?
I installed the mp-8 today. Am I correct in assuming that the knob all of the way to the left is the lowest setting and the more you turn it to the right (clockwise) the more RP your surposed to see? Here is my observation. I keep it all the way to the left (counter clockwise) I see a max of 23.5k of RP (same as with out the mp-8). I turn it to the right (clockwise) I see a drop, the further I go the more it drops. All the way to the right and max is 14k of RP? WHAT IS GOING ON? Is the mp-8 working correctly and my cp-3 can't keep up or is the mp-8 not working properly? I need help!
03 SO,BD R-700 TWINS,SMARTY TNT/MP-8,QUAD RPG,ARP STUDS,BANKS COOLER,WATER/METH,CFM+,GRID DELETE,II STAGE 2,II DUAL FEED,DDP 90's,FASS,SUN COAST EXT TRANS KIT,BD FLEX,BD VB,TCS TQ,LOCK-UP, 37's 4:10's, 9/27/08 649RWHP @ LCD. http://www.youtube.com/watch?v=OecTURtRsEI
DUKCALN is offline   Reply With Quote
Old 11-10-2008, 07:08 PM   #2 (permalink)
Sounds to me like you are exceeding the limits of your stock CP3. Put an Arson2 kit on there and you should be good to go!!!
2005 QC 4x4 Goerend, AFE, ISSPRO Gauges, Smarty, GDP-392, HTT64/12, ATS Flexplate
(536HP/1019Tq Oct 11 2008) (12.76 @ 105.40 Oct 3rd 2008)
Shakinredctd is offline   Reply With Quote
Old 11-10-2008, 07:22 PM   #3 (permalink)
DUKCALN's Avatar
I have a II stage 2 pump.......... maybe it can't keep up
Old 11-10-2008, 08:19 PM   #4 (permalink)
TECH SPECIALIST
Luvnacummins's Avatar
Yep, time for duals...
06 Mega, MPI Twin Turbos, OPIE Ultimate Tranny, ARP studs, Hamilton Springs, Flux 3.4's, Snow Stage 3 Max miledge kit, Opie Bypass, Airdog, Rockstars, Recons. ETC.... Lots of coin spend on this beast...
Luvnacummins is online now   Reply With Quote
Old 11-10-2008, 08:22 PM   #5 (permalink)
straight_six's Avatar
Duklan pm me if your interested in a saweet deal for a dual cp3 kit
06 Mega, SMARTY, DTT trans, MPI twins, FASS 150, DDP 90s, 8inch single stack, ARP, Opie bypass, MP-8, 620hp 1175ft lbs ITD dyno day
straight_six is offline   Reply With Quote
Old 11-10-2008, 08:23 PM   #6 (permalink)
DUKCALN's Avatar
Is it possible to have it plugged in wrong. My quad RP gauge plugs into the map sensor too correct. Is what order will it have to be, the mp-8 first then the gauge then the factory harness or the other way. Freaking confussing, and it shouldn't be.
Old 11-10-2008, 08:26 PM   #7 (permalink)
DUKCALN's Avatar
Sent Pm to you straight six
Old 11-10-2008, 08:30 PM   #8 (permalink)
Diesel Poser
slagburn's Avatar
I would think sensor->gauge->MP8->Factory harness - otherwise the gauge will show the modified signal from the MP8.
07.5, 6.7, Auto, QC, 4x4, Lots of gauges - ISSPRO (Pyro, Boost, Trans Temp) PriCol Optix (Fuel Pressure Lift/Rail) AutoMeter (Oil Pressure) - Dynatrac Free-Spin Hub Conversion Kit - RETRAX bed cover - homebrew shaved bluetec badge - plugged up EGR - Baldwin BF1212 water separator and CAT 1R0750 fuel filter - MSD Dashhawk - Baldwin B164 Bypass Filter - BD SBS - TS MP8
If we each have an object and exchange them we still each have one object - If we each have an idea and exchange them we each now have two ideas.
slagburn is offline   Reply With Quote
Old 11-10-2008, 08:35 PM   #9 (permalink)
VanillaGorilla's Avatar
I agree... If your RP tap-in is downstream of the MP-8, you will read the "Fooled Pressure". My guess is it's working fine, when you drive with say 40% TPS and dial it up do you feel a difference? I use a PMT and since it retrieves the signal from the OBD, it reads the fooled pressure and reads lower too, but I can DEFINITELY feel a difference when it's turned up.
2005 2WD, AFE intake, HTT Pro Street 66/16, BD Intercooler, DTT intake manifold, ARP head & rocker studs, Maxspool cam, Motorsports Supply push rods, 5" exhaust, 150/200 FASS, Industrial Stage III CP3, DDP 90's, Bully Dog Fluid damper, PMT/CL, TS-MP8, Isspro boost gauge, Amsoil BMK-25, HID's, Caltracs, Billet flex plate, Goerend converter, valve body, input & Intermediate shaft, Mag-Hytec DD pan & differential cover, Ice Metal 24's with Nitto 420S 315 35's, M&H Drag Radials
VanillaGorilla is offline   Reply With Quote
Old 11-10-2008, 08:44 PM   #10 (permalink)
DUKCALN's Avatar
I think I have it like this, sensor, mp8 , RP gauge, factory harness. Looks like I need to change to, sensor, RP gauge, mp8 the factory. I will try that.
Old 11-10-2008, 08:58 PM   #11 (permalink)
awenthol's Avatar
Yep...that was my first thought. You're reading the fooled signal...
awenthol is offline   Reply With Quote
Old 11-10-2008, 09:22 PM   #12 (permalink)
DUKCALN's Avatar
Ok, plugged it in like this, sensor, gauge mp8 and factory. Went for a quick ride and turned the dial up and pressure was up to 26k. Think its working. Just need to drive longer on the road where I can get some WOT time and see how high the RP will go and will it maintain it. Need to find that happy spot. Thanks alot guys. Nice to be able to count on some good feedback. Hope it gets me 675hp on the dyno in two weeks.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
