Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 11-12-2008, 06:06 PM   #49 (permalink)
bigcalidave's Avatar
lol. I'll take that bet!
05 QC 2500, TST CR R49, 4" Aeroturbine, Darkforcez Intake, Darkforcez BHAF, silencer ring out. 37" MTRs No Lift
Please check out http://www.darkforcez.com My new website! Cheap 24V Intake Manifolds!
bigcalidave is offline   Reply With Quote
Old 11-24-2008, 06:03 PM   #50 (permalink)
cummins13's Avatar
Originally Posted by Shibbyutman View Post
Attachment 11628
Attachment 11629
Lets see if these attachements work......
YOU didn't cut the triangle like the relentless article. Were the holes to compesate for that? or could you cut the triangle and drill the holes?
04 CUMMINS QC LB 4X4 EDGE W/ATTITUDE, 4''(SOON TO BE 5'' W/ 7'' STACK) EXHAUST MAC INTAKE
cummins13 is offline   Reply With Quote
Old 11-24-2008, 06:21 PM   #51 (permalink)
Shibbyutman's Avatar
I wanted to get better fuel dispersion and less turbulence within that little cylinder. So I drilled the wholes all the way around the circumference to allow fuel to enter from all sides. It accomplishes the same thing, but with much more precision.
2003 Dodge Ram 2500 4X4, PDR Cobra Stage 2 Twins, Dual 7" Black Stacks with rain caps, Banks Big Hoss Bundle, Goerend Full Built Trans, Smarty REVO, DIY Fuel Control Actuator Mod, FASS 150/150 and custom big line kit.
Shibbyutman is offline   Reply With Quote
Old 11-24-2008, 06:36 PM   #52 (permalink)
kenny110482's Avatar
Shibbyutman do you remember what size bit you used. Im assuming you have to polish inside and out on the cylinder. What kind of change did you notice with your set up.
2003 Dodge 2500, 4X4, 5 speed, 6" Aussies, DXCT, AirDog 150 on the way, FP Guage, otherwise stock
kenny110482 is offline   Reply With Quote
Old 11-24-2008, 06:47 PM   #53 (permalink)
It was a number 66 drill bit. It has to be carbide as well as they harden that little cylinder after machining it. I polished it on the lathe at about 5000 RPM with some 1000 emry cloth. that was after I took the pictures. The change is a little hard to notice because the truck has to relearn some of the parameters surrounding the FCA once it is completed. I would say that took probably 150-200 miles and a few key cycles. Anyway, when I have the Six gun and the smarty turned up that is when most of the difference can be felt because it is no longer starving for fuel.
Old 11-24-2008, 06:52 PM   #54 (permalink)
SIXINAROW's Avatar
yea if you don't know when this is done the truck will go through a learning cycle make all types of noise on some trucks until the comp. figures out the new pressure.
78 John Deere 210, 1915cc VW
SIXINAROW is offline   Reply With Quote
Old 11-24-2008, 09:02 PM   #55 (permalink)
Thanks for the info guys. Sounds like im going to try this as soon as i get the Airdog installed.
Old 11-25-2008, 07:18 PM   #56 (permalink)
cummins13's Avatar
Thank you very much for the info. Im going to be doing this very soon and ill post on how it went. Thanks again
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
