| 3rd Gen. Performance Parts Discussion Discussion of Performance Parts For the 3rd Gen Trucks No Advertising ...NO ADVERTISING |
#14 (permalink) |
Ummm... This isn't computer software. It's a drill bit. There is a high probability that people reading the info will still decide they won't do it themselves, then there are the additional customers who weren't going to buy a kit, but damage their stock components trying the DIY and buy one anyways... I actually don't care what their specs are, the original instructions come from a shop that does the mods and was willing to share. We know the max restrictions in the system can't be changed. I'm actually just interested to see the quality of their modifications. As I can see from the first part posted, the one with the fuel inlet, they are just drilling out a stock new part. Am I confused? I thought I wasn't reading the other forums anymore? lol.
05 QC 2500, TST CR R49, 4" Aeroturbine, Darkforcez Intake, Darkforcez BHAF, silencer ring out. 37" MTRs No Lift Please check out http://www.darkforcez.com My new website! Cheap 24V Intake Manifolds! |
#15 (permalink) |
I modded my FCA with a drill bit an and indexing collet on a mill. I drilled 6 additional holes around the diameter at the wide base of the triangles to increase flow. Let me first start off by saying that unless you have carbide drills that small, don't even try. The material that little cylinder is made out of is some real hard steel. Also, even though it isn't pointed out there it is pretty crutial to get that little dounut piece pressed back in to the exact same depth as it came out or else the preload on the spring is changed and won't run the best. If you have any questions about the process I will be happy to elaborate
2003 Dodge Ram 2500 4X4, PDR Cobra Stage 2 Twins, Dual 7" Black Stacks with rain caps, Banks Big Hoss Bundle, Goerend Full Built Trans, Smarty REVO, DIY Fuel Control Actuator Mod, FASS 150/150 and custom big line kit. |
#16 (permalink) |
im gonna give it a try, shibbyutman did you do everythikng that was in that write up, and how does your work? i like people that think outside the box
2006 cummins 3500 laramie murdered out,48re,9'' lift, 40'' baja claws/rockstar wheels,full kicker/pioneer sound system,HID's,PPE xcel. with power puck stack,nitrous,boost fooler,FASS,5'' mbrp,intake,autometer gauges need to install 66/71/14
#17 (permalink) |
I didn't do it like the write up, same theory, better execution. Have you ever seen what happens to a piece of stock when it gets grabbed by a cutoff wheel on a dremel? Yeah me too, and I didn't want something that has a line to line fit with no seals having that kind of gouges in the side of it. I took a small carbide drill bit and drilled radially into the center at 45 degree increments around the circumference. I say same theory, bucause the area calculations that they used are the same way I decided how many and what size holes to make. I may have pictures around here somewhere of what I did if you would like them.
#18 (permalink) |
oh, forgot to mention that mine works sweet. I polished it on a high speed lathe when I was done, mirror surface finish and no problems with sticking at all.
#19 (permalink) |
Awesome thanks for the advice! Did you mod the other two parts as well?
#20 (permalink) |
shibbyutman, i would like pics if you can find them
#21 (permalink) | |
You say that it's "just a drill bit". But it really isn't. What happens when someone else gets the specs that Wicked uses for their kits. Then they market them as their own Arson kit..... If the "other guys" post how to do it, follow their instructions. Don't ask for how other shops do the mod, especially if they don't post the info to the public! Oh and look up reverse engineering. Just because we live in the computer age, doesn't mean that's all it applies too.
06 Silver Quad Cab 4x4 Automatic -4" Rancho Lift w/Superlift Traction Bars & Defiant Steering Support, 315 MTZ's on H2's -Smarty, AFE Intake, Muffler Delete, Airdog100/Liberty Setup, ISSPRO Gauges, Amsoil BMK-11 |
#22 (permalink) |
Pushing the limits
You guys wanting the easy way out...their isn't one. Spend your time, and figure it out. Blow up some CP3's, damage some FCA's, try some things and fail, then try it again. Then once you do all that, make it even better. Or just copy what someone else has already worked HARD to accomplish, if you do that, have some respect for what went into it.
02 2500 Sport SB 3850, DRAG COMP, 2 TURBOS, BIG STIX, BIG PUMP, STUDS, SPRINGS, CAM, WATER INJ, ARB AIR LOCKERS, O RINGS, LIFT 35'S 05 2500 Sport 2 TURBOS, CAM, SPRINGS, STUDS, BIG STICKS, DRAGONSLAYER CP3, C5 MP8 AND PROGRAMMER, BILLET TRANNY, LIFT 37'S Last edited by rufushusky : 11-10-2008 at 10:00 PM. |
#23 (permalink) | |
I was thinking about pulling the little gear pump off the back some time soon to try that out as well, the FCA was the worst restriction, so I did that first. The only thing keeping me from doing the pump housing is the fact that my CP3 has 120000 miles on it so i am unsure of the condition of the profile seals in it. They seal fine how they are, but there is no doubt in my mind they have taken a pretty bad compression set and I haven't been to cummins to see if they sell those seals separate.
#24 (permalink) | |
2003 Dodge Ram 2500 4X4, PDR Cobra Stage 2 Twins, Dual 7" Black Stacks with rain caps, Banks Big Hoss Bundle, Goerend Full Built Trans, Smarty REVO, DIY Fuel Control Actuator Mod, FASS 150/150 and custom big line kit. Last edited by rufushusky : 11-10-2008 at 10:01 PM. |
