Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
View Poll Results: With a Rokktech sensor, I have seen...
An improvement in power and mileage 11 55.00%
An improvement in power 4 20.00%
An improvement in mileage 0 0%
No improvement, the Rokktech is a waste of money 5 25.00%
Voters: 20. You may not vote on this poll
Old 10-17-2006, 07:54 PM   #1 (permalink)
SteveinAK's Avatar
Poll for Rokktech owners
Since installing your RokkTech sensor, have you:
1- Seen an improvement in mileage and power
2- Seen only a power gain
3- Seen only a mileage gain
4- Seen neither and it's a waste of money!
Just curious whether they're worth my time and $?
Thanks!
-Steve 2003 SO CTD 3500 SLT QC SRW 4x4, NV4500 5-speed w/ Fast Coolers, Donaldson muffler, Commander w/ Xzillaraider, S&B Intake, Kore leveling, BD E-Brake, Hellwig Sway-Bar, ATS Arc-Flow, ATS exhaust manifold, HE351 turbo and Glacier GFS-392.
SteveinAK is offline   Reply With Quote
Old 10-17-2006, 07:59 PM   #2 (permalink)
Dodgezilla's Avatar
I did the tone ring mod to my 03 which essentially does the same as the Rokktech but for free. That truck saw a 1 mpg increase immediately and also got a bunch of extra "Off the Line" power. That mod was well worth the time Until I went to a fueling box with timing. Then I had to choose between the two and the top end power of the box won....
SOLD!!! 08 Ram 2500 Mega 4x4,68RE,6.7,Loaded Laramie,SRT10 hood,Sunroof,DVD,Nitto 285s,Polished Alloys,Fogzilla,Rear Spoiler,MOPAR Grill Guard,H&S StageII,AFE Drop-In
Looking for my next truck. Do you have it?
Dodgezilla is offline   Reply With Quote
Old 10-18-2006, 01:08 PM   #3 (permalink)
installed mine the other day and noticed a little increase in power on the low end...truck also idles smoother. Just took a trip from Tulsa ok, to Dallas tx. cruising with the cruise set @ 70 down and back, and a day of driving in dallas traffic, made it down and back without filling up. 581 miles it took 29.5 gallons for a total of 19.69 mpg. It never has gotten better than 18.5 so it helped my mpg.
2006 Big Horn Ram, Quad Cab, 4x4, S&b intake with amsoil filter, banks monster exhaust.
Lrdchaos is offline   Reply With Quote
Old 10-18-2006, 01:58 PM   #4 (permalink)
I also did the Tone Ring mod (free) and that helped both fuel and power. I then later purchased the RokkTech sensor and changed the Tone Ring back to stock. I feel that the RokkTech helped also in both departments. I then advanced the Tone Ring again and noticed a little power but not much and no fuel difference.
So done both, own 2 t-shirts.
Scott
2005 2500, Auto, TC lockup switch, RokkTech sensor, RokkTech muffler, Gutted chrome torque tube, Ram Snorkel on air box, Mopar cold weather kit. Pro Comp Extreme A/T 35's.
Nuttymopar is offline   Reply With Quote
Old 10-18-2006, 07:39 PM   #5 (permalink)
Listening to Learn
Hawg Hunter's Avatar
Really hard to comment on the mileage. I also installed a van Aken C3.1 at the same time to increase the rail pressure.
Do notice more snap in the low end. Might be that the van Aken is boost fooling in the low end also. Can't be sure but satisfied that the combination allows for better acceleration when pulling the camper from a dead stop.
Bobby
2003, 2500 SLT, 5.9L 24V ISB 250 SO, TST PMCR37, SMARTY TNT-NR, Wicked Eliminator LP, A-Pillar Autometer Pyro - Boost - Fuel Pressure Gages, Quadzilla Rail Pressure Gage, 4" Straight w/5" Tip, 4 SPD 48RE Auto Trans w/Goerend Triple Disk & Valve Body, Billit Input Shaft & Flex Plate, 3.73 Ratio 4X4, Crew Cab, LWB, Prodigy Brake Controler
Hawg Hunter is offline   Reply With Quote
Old 10-19-2006, 11:21 AM   #6 (permalink)
Guest
Posts: n/a
Thanks!
I saw about 0.5 to 0.75 mpg gain...definately not the 1.5 mpg they claim...
Got a lot of off idle grunt...the "govenor" seems to work better...you can dump the clutch at an idle and the truck will not stall...
It also made the truck noisier.
You can look at it this way too, you always have the other sensor as a backup...just in case.
I will also add that it seems to help they 04.5+ 600CTD trucks more than the 03/04s...third injection event??
steved
Old 10-19-2006, 12:46 PM   #7 (permalink)
I new steved would reply to this one i was just waiting to reply so i could say "yea what he said the same goes for my truck" thanks bud. i think it is money well spent.
brad
2006 CTD crew cab 4x4 dually 6 speed 56,000 miles and ticking RokTek sensor, Amsoil EAAU 4090 filter with afe torq tube, B&W turnover ball, Quad Commander, FASS, Amsoil by-pass oil filter, straight piped, nasta s.s. nerf bars, Quad XZT, high idle
brad06ctd is offline   Reply With Quote
Old 10-19-2006, 01:37 PM   #8 (permalink)
I decided to do the sensor because it was easier to install over the tone ring mod AND easier to remove and return to stock. Saw a little better bottom end and a little better fuel economy. Money well spent.
CD
2006 Dodge 3500 SLT MC, 6-spd, 3.73 L/S, 4x4, SRW. ISSPRO-FP-Boost-EGT,DiPricol-RP,Ice Box,Blue Hose,GDP intake horn,PacBrake,ME. Amsoil BMK-11, GDP 2-micron-big lines. KORE Leveling, DefiantSS,H2's/BFG315's,MagHytek-F/R. RanchHand-Grille Guard-HeadacheRack-Rear Bumper. RideRites-PopUp GN-Prodigy-CobraCB.
CD in NM is offline   Reply With Quote
Old 10-20-2006, 07:03 PM   #9 (permalink)
SteveinAK's Avatar
Thanks for all the replies! I think I'll get the Rokktech. It's a pretty safe gamble at $70 or so bucks. I'm a little wary of the tone ring mod, since once I grind on the hole on the TR, it's there forever. If I ever had to take the truck to the dealer, I could just pull the RokkTech out and put the original back in.
Old 10-21-2006, 04:14 AM   #10 (permalink)
Dodgezilla's Avatar
Well, just FYI, you can just loosen the dampner bolts and spin the tone ring back to it's stock position. Probably just as easy to do if not easier. The dealer would never even know you touched the tone ring....
Old 10-22-2006, 03:27 PM   #11 (permalink)
Guest
Posts: n/a
What he said...you could simply spin it back...
steved
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
