| 3rd Gen. Performance Parts Discussion Discussion of Performance Parts For the 3rd Gen Trucks No Advertising ...NO ADVERTISING |
EZ Pressures??
Can someone with a rail pressure gauge tell me how much pressure an EZ runs on each level. I'd like to know pressure at idle, cruising at 70 mph and WOT. Mine is an 03 if that makes a difference. I'd like to turn it up from level 1 to help with the bottom end. But I don't want to put too much strain on the injectors and cause a problem. Thanks, Randy
03 SO/Auto, QC/4X4, TST/Smarty, Boost/Fuel/Pyro/Rail Pressure, SPS-62, Goerend, Amsoil 4510, Walbro, Arson CP3 Kit, GDP Power-Flo, Grid Eliminator, Fuel Tank Vent Mod, Donaldson 51", Flux 1's, ARP, 605/1172, 13.16@108.2 |
#2 (permalink) |
Tech Specialist
This could be rather interesting. I have never measured the rail with an EZ myself. Hopefully someone has or can for us.
03, 4X4, QUAD, LWB, Standard Output, 47RE, 3.73, ATS TC/VB, DTT Trans/Billet, Flex Plate, TorqLoc, RAD, Twins, Snow, Hot Cp3, Injectors, Cam, 315s, 8,200 lbs wet. 12.32 @ 109 Videos: Vid 1 & Vid 2 Add yourself to the Cummins Forum Map. :thumbsup |
#3 (permalink) |
Can't help you with the rail guage but you should be OK up to level 3. I ran my 03 on level 4 or 5 for a couple years with no apparent problems. When I sent my injectors to Formula1 he said that one of them showed a little damage from the pressure. He said NEVER go above level 3.....
SOLD!!! 08 Ram 2500 Mega 4x4,68RE,6.7,Loaded Laramie,SRT10 hood,Sunroof,DVD,Nitto 285s,Polished Alloys,Fogzilla,Rear Spoiler,MOPAR Grill Guard,H&S StageII,AFE Drop-In Looking for my next truck. Do you have it? |
#5 (permalink) |
OK, I'll be waiting for the results. Randy
#6 (permalink) |
Moderator
Don M told me at one time that 50hp from pressure is all that would be good due to long term wear on the tips... I would be able to hook my EZ back up even with my new TST and see what level 3 does to the RP... If I can get a free moment I will let you know...
Tomeygun - St. Louis, MO Truck: '03 3500 QC, S.O. Cummins Fuel: PMCR by TST, F1 Flux 2's, GDP WALBRO Kit, Floor-It CP3 Air: Sledpuller 66 by HTT Trans: SBC DD3600(sprung), SRT-10 Shifter row'n the gears $$Wants$$: F1 Hellfire's, TireGate, GDP Ladder Bars 604 hp DYNO Run Help Support CumminsForum.com by upgrading to Premium Membership |
#7 (permalink) |
Moderator
On level 3 I see 19k VERY EASY... The roads were wet at lunch today so I did not get a max RP reading - I will see what I can do on the way home One note - A RP gauge is a must have IMO (after using one for a week or so)
#8 (permalink) |
Administrator
Just cruising down the highway at 70 without the EZ on I see 20-22k psi I can'y really see a change in pressures with it on or off, readings vary greatly depending on any little bit of load
Corey Ritter - Amity, OR '04 Patriot Blue SRW 3500 QC 4X4 Laramie, 6spd, HO, Edge EZ, TST PowerMAXCR, Smarty, SPS 66, Rip's 4", AFE PG7 W/torque tube, FASS 150, Superlift leveling kit, Ride Rite's w/onboard air, Line-X. Torklift camper tie downs, fuel vent mod, CB, GPSmap 168, Buckstop/Warn 12,000 lb, KC Daylighters, MTL w/prolong in trans, Haisley DD, DiPricol gauges and Quad Commander. 77K 513/1043 Fast Specialties DDD 4-15-2006 TST-EZ stack, Quickest 1/4 mile ET 13.949 @ 96 MPH @ PIR Hauls Lance "Lite" 1025 @4klbs Wifes truck '98 Intense Blue 12V QC LB 4X4 Auto Last edited by MR4WLR : 10-12-2006 at 01:18 PM. |
#9 (permalink) |
Tech Specialist
Wow. Cruising at 70mph with no pressure box nets me mid 14K rail pressure.
#10 (permalink) |
Moderator
I also notice after I dip in the throttle and hold - when the truck eases up on load and the truck moving - My RP stays arounf 17-19k... I would expect it to fall off but it does not
#11 (permalink) |
Thanks for the info. I turned my EZ up to level 3. Seems to have quite a bit more timing rattle. I may hit level 2 and see if there is a difference. AK and Tomey, You have injectors. How does that effect rail pressure? Will you have less than my stockers? Thanks, Randy
#12 (permalink) |
Tech Specialist
Just realized that you two are both sticks. You guys are geared higher and your RPMs are probably over 2K at a 70mph cruise huh? I'm a hair below 1800RPMs at 70mph. That makes a big difference in rail pressure.
