Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 10-12-2008, 09:45 AM   #13 (permalink)
jms_shepherd's Avatar
Originally Posted by awenthol View Post
Do you have CP3/lift pump mods?...you're probably going to have rail pressure issues...
Awenthol I said the same thing and you're right. There is no probably to it, it's GONNA happen. You're rail pressure will be to high for your injectors and that will throw codes as well. Another thing, you need to have the right cooling mods other wise you will smoke your turbo and risk blowing up your engine.
5.9 H20/Meth,ATS 5000,PDI manifold, CP3 stg III,F1 2.5 inj,springs,Banks Intercooler,plennum,Smarty TNTR,intake,Boost Fooler.BD Plate, TC & VB, Goerend Input,Output Shafts clutch kit,Tran Pan Fab,4 1/2" lift,DC1 20's 33" tires. 674.05hp #2 only
jms_shepherd is offline   Reply With Quote
Old 10-12-2008, 09:48 AM   #14 (permalink)
you also need to upgrade that stock turbo possibly. You're already dumping fuel into it and the more you dump into the stock turbo the more you're gonna waste. That turbo will only handle so much and can only deliver so much air. You already have injectors and a chip already you put another on there, you will be wasting a lot of power. More air is a must if you're gonna stack chips too. You running a boost fooler too?
Do the fuel mods, and air mods and you will be fine.
Thanks, John
Old 10-12-2008, 10:08 AM   #15 (permalink)
Thanks, John
On my truck I already have an upgraded turbo, 50hp injectors, and a 6inch exhaust turbo back. Also my truck is not chipped already so I would not be stacking chips. I have an AFE intake system on order shoud be here thursday so with that said would you still go with the smarty?? and what is a boost fooler? Thanks for the help guys
Dusty is offline   Reply With Quote
Old 10-12-2008, 10:13 AM   #16 (permalink)
Smarty is still the way to go!!! You should be about set other than maybe the lift pump...Fass 150 or air dog...you should be ready to roll...You will like the smarty
05 qcsb, 6spd, 4'' straight pipe,6" tip, silencer ring MIA, Ranchand bumper, willys whistler w, Amsoil Nano...need !
glazecummins05 is online now   Reply With Quote
Old 10-12-2008, 10:14 AM   #17 (permalink)
IPOLUTE's Avatar
Juice with attitude cause its on the fly and then stack a smarty on it
[b][color="DarkGreen"]2002 Dodge 24 valve Cummins 2500 4wd shortbed, Edge Juice w/ Attitude, Fass HPFP 150,6 Speed, Straight Piped, BHAF w/ pre-filter, Rhino Liner, HBS Level Kit, Procomp ES9000 shocks, 92,000 miles
IPOLUTE is offline   Reply With Quote
Old 10-12-2008, 11:27 AM   #18 (permalink)
I boost fooler is a cheap and easy upgrade. It's only like 60 bucks and it will give you about 10 extra psi of boost. What it does is trick your ECM into thinking it's running at a certain SAFE level of boost (according to the ECM) when in all actuality you're running a higher level. Once you hit over a certain level of boost your Computer will kick into a defueling mode and this you lose a TON of power and a code is thrown. A boost fooler will give more boost depending on fueling mods, and prevent any codes from being thrown. What turbo do you have? I know mine came with a boost fooler so if thats the case you may actually already have one. How many psi you running?
I would go with the smarty regardless. It's a great a versatile product. But still at least get a lift pump so it will provide more fuel to the CP3 thus not over push you whole system, you already have injectors too granted they are only 50hp but with the chip you will be putting more strain on the pump which will put more strain on you cp3 and injectors. You push you stock lift pump to the max and it will effect your WHOLE fuel system. If you want the smarty let me know ok bro, I know a guy out in california who can beat the competition by about 40 bucks or so on pricing. And he will hook you up with anything and everything else you wanna do ok. I am so serious, just PM ME you will be very happy with his service.
Old 10-12-2008, 11:28 AM   #19 (permalink)
I also forgot to say that the boost fooler will lower EGT's around 50 degrees on stock trucks and as much as 200 degrees on heavily modified trucks. so yeah, it's a good upgrade.
Old 10-12-2008, 12:04 PM   #20 (permalink)
awenthol's Avatar
What do you have for gauges? Stock '03 lift pump + stock cp3 + injectors = not enough fuel for Smarty....however, the only way to truely know is with fuel pressure and rail pressure gauges.
2006 Laramie QC SB 4X4 48RE
1994 Laramie RC LB 4X4 5spd
modded
awenthol is offline   Reply With Quote
Old 10-12-2008, 08:42 PM   #21 (permalink)
[quote=jms_shepherd;909200]I boost fooler is a cheap and easy upgrade. It's only like 60 bucks and it will give you about 10 extra psi of boost. What it does is trick your ECM into thinking it's running at a certain SAFE level of boost (according to the ECM) when in all actuality you're running a higher level. Once you hit over a certain level of boost your Computer will kick into a defueling mode and this you lose a TON of power and a code is thrown. A boost fooler will give more boost depending on fueling mods, and prevent any codes from being thrown. What turbo do you have? I know mine came with a boost fooler so if thats the case you may actually already have one. How many psi you running?
Ok I will order a new lift pump and a boost fooler what is a good fooler to get?? And I have no Idea what turbo my truck has I bought it that way all I know is the people that owned it b4 me had the dodge dealership in vegas where i bought the truck do the turbo and injector upgrades right when they ordered it. A good family friend works at that dealership he sold the original onwners the truck and he is the one who called and told me that this was the truck to get because it had that stuff done already. It is no speed demon but it is alot faster than a stock cummins. Thanks for all the help this cummins is going to be a fun project I can already tell!!!!
Old 10-12-2008, 08:46 PM   #22 (permalink)
Supporting Vendor
Custom&Classic's Avatar
[quote=Dusty;910311]
Along with a boost fooler you are going to also need a better wastegate actuator for it to work properly since your trucks wastegate is mechanically controlled. The quadzilla is the best boost fooler.
Authorized dealer for S&B, ICEBOX MFG. ,Devils Own Water/Meth kits, WILSON MANIFOLDS, DTT, Quadzilla, Edge, Smarty, Air Dog, Valair, South Bend Clutch, Bully Dog, Superchips, FASS, MBRP, Magnaflow, H&S Performance DPF deletes, and many more.
All tuners/chips/modules include FREE shipping.
Your one stop source for all of your performance needs.
(586) 524-9321
Buy online at customandclassicautostore
Custom&Classic is online now   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
