Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 10-10-2008, 09:34 AM   #1 (permalink)
Aftermarket Fuel Pumps
I want to get rid of the Dodge retro-fit in-tank pump on my 04 Cummins. I ordered a ProComp (Holley Clone) fuel pump to install on my truck. It's rated at 130gpm and the pressure is set to 14#. Do I need a regulator? What should my maximum fuel pressure be for this truck?
2004 (early) Cummins 2500 2wd Quadcab, 5" FBD exhaust, BHAF with heat shield, ISSPRO gauges, Holley Black fuel pump with 1/2" lines and dual Filters, 1.5" front coil levelers, HTS valve body, Diablosport Predator
dbshelton is offline   Reply With Quote
Old 10-10-2008, 10:06 AM   #2 (permalink)
SteveinAK's Avatar
I don't know the "max", but I've been running 20psi for a couple of years now with no CP3 problems.
-Steve 2003 SO CTD 3500 SLT QC SRW 4x4, NV4500 5-speed w/ Fast Coolers, Donaldson muffler, Commander w/ Xzillaraider, S&B Intake, Kore leveling, BD E-Brake, Hellwig Sway-Bar, ATS Arc-Flow, ATS exhaust manifold, HE351 turbo and Glacier GFS-392.
SteveinAK is offline   Reply With Quote
Old 10-10-2008, 11:25 AM   #3 (permalink)
130GPM???
I hope you meant GPH. ALthough 7800GPH would definitely supply plenty of fuel.
AND is that rated at 130GPH AT 14psi?
2007 2500 QC 4x4 5.9L,48RE w/ Goerend TC, VB and some billet thingies,DTT Shift Enhanser,Smarty, Edge EZ, AFE Stage II w/Pro Dry-S, FBD 5" Turbo Back,Amp Research PowerSteps, Superglide Hitch, Tekonsha p3 brake controller...much more to come!
Twoforme2 is offline   Reply With Quote
Old 10-10-2008, 11:30 AM   #4 (permalink)
Super Administrator
BBRam's Avatar
Max fuel pressure is not to big of an issue, the CP3 will return what it doesn't use. I see 50-60psi at WOT.
03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph)
Old 10-12-2008, 02:02 PM   #5 (permalink)
Originally Posted by Twoforme2 View Post
130GPM???
My fumble fingers! Maybe those are "Dog Minutes?"
That 130gph is free flow.
Thanks for the info.
Old 10-12-2008, 04:02 PM   #6 (permalink)
dirty454's Avatar
subscribing
07 5.9 6 speed, 5in tough country, 37 toyo M/T's on 20" diamo's silencer ring MIA, 5" Expandit turbo back, Autometer gauges, SMARTY, EDGE EZ stack, Need a clutch!
When your only tool in life is a hammer you gotta treat everything like a nail!
dirty454 is online now   Reply With Quote
Old 10-12-2008, 05:00 PM   #7 (permalink)
Super Moderator
rufushusky's Avatar
In fact modded cp3s like to see higher fuel pressures. 14 is not high at all. What I have heard is the max fuel pressure will handle is about 100psi...not that I would recommend pressures that high.
Dennis
04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, TS Ramifier, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust, Cat 2 micron fuel filter, Amsoil Bypass
Check out: Rig of the Month!
http://www.cumminsforum.com/forum/rig-month/
rufushusky is offline   Reply With Quote
Old 10-23-2008, 05:15 AM   #8 (permalink)
Finished my install of fuel pump, draw straw II, tank vent mod, new larger filter and separate water separator, 1/2" lines all the way to the injector pump. I haven't driven it yet, but my truck starts even quicker and it also idles smoothly. (It used to take 10-15 seconds to smooth out) My fuel pressure gauge should get here today. I left the stock filter inline for now too.
Old 10-23-2008, 08:40 AM   #9 (permalink)
anwfarms's Avatar
i got a blue and at stand alone (without stocker) i would get about 13-15 psi consistenly without a reg. i removed the fuel plunger on the pump and stretched the spring and now seeing 20-22 psi. been running the blue for about a year now.
2003 QC DRW HO 6 spd 4x4 myspace.com/anwfarms.............BIG STIXX DIESEL PERFORMANCE
anwfarms is offline   Reply With Quote
Old 10-25-2008, 09:33 PM   #10 (permalink)
I installed a fuel pressure gauge at the stock filter canister and at idle, it's reading about 40 to 50#. Is this too high?
Old 10-25-2008, 10:09 PM   #11 (permalink)
Super Moderator
rufushusky's Avatar
The CP3 should be fine but that does seem like a lot for a holley pump...are the lines between the canister and cp3 stock?
Dennis
Old 10-26-2008, 06:29 AM   #12 (permalink)
I changed all of the lines. Went from a 1/2" Draw Straw II in the tank to 1/2" lines to the CP3. They only reduce at the fuel pump and the stock filter canister.
I think maybe I'll disconnect the line at the CP3 and see just what kind of free flow I get into a bucket. Maybe I should add a regulator with a return?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
