Aurora 5000?? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 11-19-2013, 08:40 PM Thread Starter
CumminsRacetruck's Avatar
Aurora 5000??
Will my truck be able to spool an Aurora 5000? Note that I don't have anything done to my truck yet but right after I get my Aurora on I'm getting a Smarty S06 with custom UDC tunes.
2004.5 Dodge Ram 2500 5.9L 24 Valve Cummins with NV56000, Valair Dual Disk #3800 Plate Load, Valair Heavy Duty Hydraulic Assembly, Smarty S06 With UDC Custom Tunes, AutoMeter C2 Series Gauges, S&B Cold Air Intake, MBRP 5" TBE, Fass Titanium 150
CumminsRacetruck is offline
post #2 of 13 (permalink) Old 11-19-2013, 08:45 PM
Blah
golfsnow's Avatar
Where do you live? Elevation will be a factor in how well it will spool
07 QCSB 5.9 - SOLD
Special thanks to Lance and the crew at 4Play Off Road and Diesel Performance
golfsnow is offline
post #3 of 13 (permalink) Old 11-19-2013, 08:46 PM Thread Starter
A few hours north of Philadelphia
post #4 of 13 (permalink) Old 11-19-2013, 08:48 PM
Pfranklin's Avatar
What do you plan on adding for fuel? To run it as a single I'd say 150's and duals or a stroker are a minimum.
06 RCLB EFI by Me Carrillo, ED ,FI, Wiseco, S&S, D&J, ARP, Goerend 9.32 at 151.41
Truck Source Diesel
Pfranklin is offline
post #5 of 13 (permalink) Old 11-19-2013, 08:49 PM
Blah
golfsnow's Avatar
Should be okay, I'm assuming you're fairly closeto sea level there plus with the manual you can drive in the RPM range you need versus an auto.
07 QCSB 5.9 - SOLD
golfsnow is offline
post #6 of 13 (permalink) Old 11-19-2013, 08:52 PM
Blah
golfsnow's Avatar
What do you use the truck for? There may be better options for you depending on your end goal power wise.
07 QCSB 5.9 - SOLD
golfsnow is offline
post #7 of 13 (permalink) Old 11-19-2013, 08:54 PM Thread Starter
It's my first diesel build and I'm gonna use it to race. Yes I understand it's a manual but I find it more fun to drive. I want to do all of the basic stuff first but just need some help with the order in which I complete the stuff.
post #8 of 13 (permalink) Old 11-19-2013, 08:56 PM
Black Diesel's Avatar
IIRC the specs on that are 71/83/.9 so should spool with some custom tuning and 120's or bigger (with the right pump(s) to support said injectors). FWIW I'd look at the FMW s467 from borg warner, cost less than the A5k and probably make the same power, or more as the A5k is based off the old K31 design.
Sent from AutoGuide.com App
'06 Mega 3500 / Altered Diesel Wurks / ProLine Tuning
5.9... for now
Black Diesel is offline
post #9 of 13 (permalink) Old 11-19-2013, 09:02 PM
Blah
golfsnow's Avatar
If you haven't found the sticks at the top of the performance section yet I would recommend checking them out. Here's a link to a good what on basics: Basic / Supporting Mods. Do some reading and set a goal, it will save you money in the long run.
07 QCSB 5.9 - SOLD
golfsnow is offline
post #10 of 13 (permalink) Old 11-19-2013, 09:05 PM Thread Starter
Thank you! That's a big help. So basically I just go down the list and make a checklist?
post #11 of 13 (permalink) Old 11-19-2013, 09:09 PM
Blah
golfsnow's Avatar
Yes once you've set a goal power wise, you will probably have other questions as well...if you use the search function you will likely find your answer if you don't ask away.
07 QCSB 5.9 - SOLD
golfsnow is offline
The Following User Says Thank You to golfsnow For This Useful Post:
CumminsRacetruck (11-19-2013)
post #12 of 13 (permalink) Old 11-19-2013, 09:10 PM Thread Starter
Thanks man I appreciate it
