HTT Pro Street 66 and stock sticks - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 11-13-2013, 03:43 PM Thread Starter
CumminsJeepJ20's Avatar
Was installing a CAI when I discovered the compressor wheel on my turbo has been making contact with the housing, so time for a new one, and I might as well upgrade right? Was looking into Garrets, but I was told the stage three won't get me to my goal of 650hp. I was then advised to get a HTT 64 or 66: "If I was you would probably go with an HTT turbo either a 64 or a 66 if your not towing much. If your gonna run stock injectors I would stick with the 64 but if you put a good nozzle in the 66 turbo really runs good. Also the HTT stuff is quite a bit cheaper than the powermax kits."
My question is can I run the 66 with a stock injector for a few months until I can get a set of nozzles? Or will it be a smarter decision to get the 64 for now and get the 100 horse nozzles when I can with a slightly smaller turbo?
2005 QCSB G56, South Bend DD, MBRP 5", Smarty SSR, II SB64, 100hp nozzles, studs, springs
1990 W250, built 440, NV4500 swap, D60s, coilovers
CumminsJeepJ20 is offline
post #2 of 12 (permalink) Old 11-13-2013, 05:04 PM
vvvvv Chuck's Ride vvvvvv
Chuck Norris's Avatar
If your goal is 650hp get a 63/74/.91 with race cover and billet wheel and you done!
2004 Dodge 2500:
OPTIMUS PRIME BUILD IN PROGRESS
Chuck Norris is offline
post #3 of 12 (permalink) Old 11-14-2013, 12:31 AM Thread Starter
who makes that? I got my advice from Mike Haller, the guy who built a 10 second 6.4, and has put together many Cummins. Whatever turbo I get is also going to be accompanied by a Fuelab 200gph lift pump, if that helps with anything. Once I am out of school for the summer I would get 100hp nozzles and a CP3 bag o parts as soon as I had sufficient funds...
post #4 of 12 (permalink) Old 11-14-2013, 01:37 AM
vvv SOME PEOPLE'S KIDS vvv
cummins04.5handshaker's Avatar
100hp nozzles not gonna push those numbers or a 66 and a bag of parts cp3 is garbage.
GITT SUMMMM!!!
08 mega Laramie 4wd auto.. the white wagon baby hauler. EFI & Trans tuning.
04.5 w/compounds, dual fuelers and a lot of wasted money
'99 sport...G.O.N.E.
cummins04.5handshaker is offline
post #5 of 12 (permalink) Old 11-14-2013, 09:20 AM
Brumley Farms's Avatar
Wink
I have no problems out of my htt 66, ran it with stock sticks, 100 sticks and it ran great with both!
Sold-96 12v a little fuel an a little air 826hp 1821ft/ib on #2. 04.5 More Fuel and Air than stock, 4430 John Deere 433hp at pto, Still pulls a batwing full time
Brumley Farms is offline
post #6 of 12 (permalink) Old 11-14-2013, 10:43 AM
1998dsmtalon's Avatar
Wouldnt but a HTT turbo when a box 366 can be had for much cheaper. Ive seen them recently used as low as $550. Yes you can run them on stock fuel with a solid tune. A race cover billet wheeled 63 would be a lot of fun but also gonna be some $$. A local guy here has made 596 on a 66/71 and stock 04.5 fuel (10.6 cp3 added) with only TNT-R tuning. So 650 is a very reasonable goal with a little fuel. Just make sure your cp3(s) are solid.
Also, wtf is a 2005.5?
06 QCSB 1168 HP 1799 TQ, 9.83 @140 mph
NREPerformance
1998dsmtalon is offline
post #7 of 12 (permalink) Old 11-14-2013, 10:49 AM
crf450x's Avatar
iTrader Score: 7 reviews
Fwiw that lift pump isn't gonna do anything but cost money and make racket. I also don't think a bop will hold good rp with 100s. People argue about that but more often than not, you're not gonna be able to reach commanded pressure at wot. Throw a set of duals or a stroker cp3 on there and call it a day
'06 3500 G56 EFI Live, Dual CP3s, 75% Injectors, 68/83/.90
crf450x is offline
post #8 of 12 (permalink) Old 11-14-2013, 10:50 AM
Blah
golfsnow's Avatar
The Fuel Lab 200 isn't going to help fuel your injectors without an upgraded CP3...you have a lift pump (low pressure) and an injector pump (CP3 high pressure). I would recommend spending some time reading, making a plan and then buying parts to fit your plan and use of your truck...here is a good place to start reading:Basic / Supporting Mods
07 QCSB 5.9 - SOLD
Special thanks to Lance and the crew at 4Play Off Road and Diesel Performance
golfsnow is offline
post #9 of 12 (permalink) Old 11-14-2013, 11:21 AM
3 footin' through life
Broaner's Avatar
iTrader Score: 10 reviews
If your goal is only 650 don't do the 66. Even with a spool valve and UDC mine is a dirty pig if you aren't careful below 2000 rpm's.
I agree that the HTT isn't the best option in 66 form especially if you are paying new prices. If you can get a good one used for $1400 that's a different story. I went for it because I really like the SS turbine housing. I'm planning to swap my compressor to a 64.
'05.5 6.7 Cryo & Peened NV5600 - 12.6 @ 111.6 - 811/1583 Old #'s
150%'s, LBZ/Arson pumps, MHP +1mm, ZZFab, Wagler Rods, 69/73/1.0 & s482
1350 Frontshaft, TruTrac, 315's, 64" T-Bars,TGC 1/2"+, Carli BJ's, '08.5
Street Triple, Hami 103#/Extreme Pushrods, 625's
Broaner is offline
post #10 of 12 (permalink) Old 11-14-2013, 11:39 AM
Spool valve lol
NREPerformance
post #11 of 12 (permalink) Old 11-14-2013, 12:31 PM Thread Starter
So would a 33% over cp3 be enough? And if not HTT, what else?
post #12 of 12 (permalink) Old 11-14-2013, 03:05 PM
Broaner's Avatar
33% CP3 is the same as a BOP IIRC. Most will say only go with a stroker from a place like Exergy, T/C Diesel or Motorsport Diesel. And of course more people will recommend duals over a stroker... But for 650hp duals are not required.
There are tons of turbo retailers. Lots of research to do on this topic.
Originally Posted by 1998dsmtalon View Post
Spool valve lol
Broaner is offline
