I will be upgrading a few parts within the next month or so and am in need of some help. I have done some research but am not too sure if I am missing anything. Already have a built trans, smarty and gauges. Hoping to be around 550-600 hp but need some help from you guys on choosing the best setup for my buck. I don't tow and it is my daily driver.
-Turbo- I'm leaning towards an HTT 64. Not for sure though.
-Injectors- 90 HP? Not sure on the brand either
-Manifold
-Airdog
-And will probably make the switch to EFI Live.
I'm open to any suggestions from you guys on brands/anything else that would be needed. Thanks in advance.
__________________ SOLD: 2006 5.9
E.D 63 l Stainless Diesel l Airdog
JTT Billet Trans l EFI by Anarchy
1. airdog
2. turbo, call chris at e.d. prob like a 63/68/14 or 64/71/14
3. injectors, exergy 90s would be good
4. efi live
5. maybe cp3/arson kit
should be no prob getting to 600+
similar direction as i wanna take minus the efi, you lucky duck. i cant wait for efi.
90s are overkill for that hp range a 63/68/14 with 60s has already done 632 and only 1400 EGT max. A little more work and 60s will do 650 no worries.
06 MEGA TRE Trans, E.D. 63/68, EFI by Les @ SBT, Motorsport Diesel Pump
06 750hp Built By TRE Diesel SOLD FormerUnited States Marine. Good luck and God speed to all our troops!
Current Professional Firefighter
The Following 2 Users Say Thank You to RyeThomas For This Useful Post:
Thanks for the replies guys. Rye, how do you like the 63 you have? you notice a big difference between the 63 and the stock turbo? 63 is also a choice for me but I figured why not go 64 just a little worried about lag or something
the right 63 will flow 78lbs min vrs 81 for say a special, but the 63 can run a heck of a lot better with a heck of a lot less set up. It will also run properly tuned pretty dang close up top and overall hp. I don't need injectors to spool my 63 super quick, can't say that with a 64 like say a special or a 63/71/13.
I'll be looking into the 63/68 for sure now, so no injectors are needed to spool it up quicker? what other parts would you recommend installing along with the turbo? I wanna get everything installed at the same time
I would hold off on injectors and see what you can do with efi live. A lot of guys are running bigger turbos on stock injectors and making some clean power.
2013 2500 Mega Cab Laramie Bright white bone stock until Mini Max comes out.
Took your advice Rye and got the 63 from ED, haven't gotten a chance to install it and I've had it for over a month. HTT manifold I ordered is on back order and they have no idea when it'll be shipped. Any other manifolds you guys suggest? I'm thinking of getting the stainless diesel manifold so I can install them already. It kills me every time I see it still in the box.
