switched from a ford 6.0 to a cummins 5.9 mega auto 2006 with 35"tires,
that being said im new in the dodge game
ive noticed that my ford ran much lower egt's- stock filter stock exhaust no chip i could hold it to the floor all day pulling my camper and barely hit 1200degrees.
my dodge empty i can easily get 1300 egt's in OD at about 70mph just climbing a hill- seems high empty to me? no tuner is on the dodge it has a 5" exhaust and CAI, banks high ram elbow leveling kit 35" tires and no other mods.
today i hooked up to a 26' jayco humper pull camper-about 6500# and pulled it- climbing the same hill i hit 1200 on before i hit 1400 degrees- is this normal for you guys am i just too paranoid- i have a 600 mile trip to pull a camper on and just wanna make sure these numbers are normal.
also in the future i plan on an efi live tuner- will my egt's just skyrocket with the custom tunes or what? i know on my ford when i tuned it i saw much higher egt's with custom tunes from SCT.
that being said thanks for your replies guys and i am happy with my cummins so far.
I just hooked up my 30 ft 10000 lbs trailer to my truck after doing a bigger turbo and fuel pump and now my egt's are around 1100 deg on flat hyw
2006 quad cab.AFE intake horn and filter.5 in exhaust from turbo back. trans temp,pyro,boost,Fuel presure and rail presure. Built 48re all goerend internals and triple disk converter.billet input shaft and flexplate.165 Airdog.63mm screaming eagle.EFI live by CT
I think its your banks ram elbow making you hit 1300, with a programmer on mine ive never seen 1300 the best was 1240 bogged out up a bridge so if your running that hot not towing you might want to change something up
2006 Dodge 3500 Mega Cab, black, 22 gear wheels,33 toyo at,wheel spacers, 2.5 leveling kit, s&b intake, scout II, bully dog triple dog.
I've got this same problem.. I'm not really sure how this came about as well, but I know it happened after my transmission was rebuilt. Right after.
Sent from my PC36100 using Tapatalk 2
2006 laramie megacab 3500 4x4 srw auto 373's. 6inch lift with 35's, 20" fuel hostage. isspro ev gauges trans, egt, boost. s&b cai, smarty s06 pod programmer. built trans by inglewood transmission.
To the op yes stock 06's run hot you can see 1400 on a stocker, not that anyone likes it but it will do it.
Suomy every aftermarket trans I have had causes higher EGTs in certain situations. Example all of mine have locked up in a gear and don't come out unless you floor it due to increased line pressure. So when your truck would normally down shift and cool down by turning more rpm its not going to do it in the same manner. It's not a big deal you just have to realize its happening and either ride it out, or mash it to get her to downshift. Also when you lock up you are going to get far less slippage transferring more of that power to the drivetrain but also putting some more strain on your engine making her a little warmer.
06 MEGA TRE Trans, E.D. 63/68, EFI by Les @ SBT, Motorsport Diesel Pump
06 750hp Built By TRE Diesel SOLD FormerUnited States Marine. Good luck and God speed to all our troops!
Current Professional Firefighter
The Following 2 Users Say Thank You to RyeThomas For This Useful Post:
You must have something weird happening to be running that hot empty at 70mph. My 07 is pretty well the same rig as yours, all stock intake and exhaust and cruising down the highway at 70/80mph I see 800/900* flat or uphill really makes no difference. With my smarty on Revo sw5 and mashed to the floor WOT I see 1400* tops.....
2007 MegaCab Black/48RE/3:73/6''Superlift/20'' KMC MONSTER Wheels/325/60R20 Nitto Terra Grappler/BaldwinFW/RaptorRP150/Cat2mic/BaldwinPF7977/Smarty S-06 POD/IssproEV2/Jacobs Ex BRK/5"Flo-Pro TBE
Thats the difference, you have a smarty which runs cooler then stock. To the op your temps are Normal. Nothing to worry about these truck were made to run that hot. My 05 hits the same temp when stock. I've since added a GDP air boss plenum and stock my gets are around 1250. When tuned I use to peg my 1600* gauge now on extreme I only see 1400*.
2005 white auto, thanks to stoakenstine creations, 23 Diesel, bully dog td ver. 2.5.3, 5" TBE to 6" stack, bhaf, GDP air boss, full triple pod, gdp 2 mic. edge ez 517hp 990ft.lbs
The Following User Says Thank You to mstoaks For This Useful Post:
