CP3 Mounting Studs Gone -- Need Help - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 05-03-2012, 06:40 PM Thread Starter
While driving the truck it started gushing fuel. After inspection we discovered the three nuts and studs that hold cp3 pump on had disappeared. The studs did not shear off, or if they did the whole stud must have worked itself out.
I guess my question is -- how did this happen? And most of all where do I find replacement studs?
2004 Cummins(235HP);63/68 over s480TWINS;DDP Nozzles;TST Powermax;Smarty;Water/Meth;ARP Main & Head Studs;ATS Trans;Coated Pistons; Raptor 150 Pump;Hamilton #110 Springs;Ported Head;Upgraded Valve Seats;18" x 9" Helo Maxx Wheels;Cooper STT
Moobesor5.9L is offline
post #2 of 12 (permalink) Old 05-03-2012, 08:38 PM
runninlean's Avatar
What was leaking fuel? Did a line break or something?
Thats pretty odd never seen a stud come loose let alone all 3.
06 (Super Diesel) Silver,sport,QC,2500,4x4
04 Sleeper White RC 2500, 2wd
Thanks to our Sponsors ATS Diesel, DRV Performance, and AirDog
runninlean is offline
post #3 of 12 (permalink) Old 05-03-2012, 09:28 PM
Innovative Diesel
DODGE74's Avatar
iTrader Score: 15 reviews
Another member not to long ago had this problem also. He actually caught them coming loose, tightened them and then checked a short time later and one or two of them were gone.
I cant remember what he did to fix the problem or where he found the studs, sorry. But it does happen.
EFILive, HPT, UDC, UDC Pro, MM3, Warp, MCC, SCT custom tuning
DODGE74 is offline
post #4 of 12 (permalink) Old 05-03-2012, 11:14 PM
Soot Sniffer
BlackSmokeWilly's Avatar
I would think if you found out the size of the hole in the front cover you could substitute bolts with a dab of locktite on them. If not, I'll bet any good Cummins shop sells the studs/nuts. Just take them your engine serial number and they should be able to get them. If ALL else fails, new front gear housing.
'07 2500 QCSB 4x4, .020" over, Hamilton Valvetrain, Motorsport fueling, Garrett air, built bottom end, Goerend Transmission.
EFI by Silver Bullet Tuning
Originally Posted by TURBOLVR View Post
IMO, the only reasons to run a big single is $$, simplicity, or stupidity.
Originally Posted by D squared View Post
I like DP...lol
BlackSmokeWilly is offline
post #5 of 12 (permalink) Old 05-04-2012, 09:07 AM Thread Starter
Due to the Cp3 shifting, the line leaked at fitting.
I've searched everywhere for replacement studs and so far nothing. Not sure just yet if the studs are threaded or pressed or molded into the gear housing. Will know today.
post #6 of 12 (permalink) Old 05-04-2012, 09:26 AM
That's crazy!! Was it the stock pump? I guess it's just something else to look at when the truck gets serviced.
03/6spd..SSR/UDC, Bosch Motorsport 100's, T&C 60% cp3, GDP MK-2+, BD Flow Max, BD Special, AFE exhaust man., Hamilton 181/210, 110 Spings, HD push rods, ARP 425's, S&B Intake, Spool Aid, TPP blanket
Walker is offline
post #7 of 12 (permalink) Old 05-04-2012, 10:28 AM
T & C Diesel Performance
TCDiesel's Avatar
Please call Todd @ 763-228-7121 ASAP..there's a reason they snapped.
TCDiesel is offline
The Following User Says Thank You to TCDiesel For This Useful Post:
Moobesor5.9L (05-04-2012)
post #8 of 12 (permalink) Old 05-04-2012, 11:38 AM
1997chevy454's Avatar
iTrader Score: 4 reviews
So is it a big secret and you can't let everyone know how to prevent it?
'05 QC3500 DRW 2wd> new motor. Hamilton Cams, s472
13.47@106.01
1997chevy454 is offline
The Following User Says Thank You to 1997chevy454 For This Useful Post:
WVcummer (05-04-2012)
post #9 of 12 (permalink) Old 05-04-2012, 12:09 PM
TCDiesel's Avatar
Chevy.. I here..the problem IS....... like other the threads the keystroke kings jump in..And I am sick of it.. beside that I need more info then thread has dispersed.
TCDiesel is offline
post #10 of 12 (permalink) Old 05-04-2012, 01:17 PM
Could you not ask the questions in here and like I said fill all of us in? Since that is what a forum is about.
13.47@106.01
post #11 of 12 (permalink) Old 05-04-2012, 05:55 PM
TCDiesel's Avatar
The OP call..the info I needed was disclosed..The engine is fresh, So it May be related to improper TQ on the studs.
TCDiesel is offline
post #12 of 12 (permalink) Old 05-04-2012, 09:17 PM
What other instances could there be where this happens?
13.47@106.01
