Fans - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-07 Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 04-15-2012, 01:52 PM   #1 (permalink)
Tyler05's Avatar
Fans
Has anyone installed electric fans on the cummins. I have an 05 and I do tow some with my truck wanted to know if it is worth going to the dual electric fans instead of the stock fan
05 short bed two wheel drive 5 inch turbo back, raptor lift pump , smarty pod , 100hp nozzles, built Trans,ats arc flow intake, s&b cold air intake with scoop, 20in chrome wheels with Michelin tires , Stewart warren boost Trans temp and egt gauges over head pod
Tyler05 is offline   Reply With Quote
Old 04-15-2012, 08:03 PM   #2 (permalink)
papaduck's Avatar
You may not get enough cooling with the electrical fans when towing. The stock fan clutch is cheaper to replace. If you need the fan itself then the electrical may be cheaper.
Some think that it will give better milage with the electrical fans, but the load is only changed from the engine power to the alternator.
03 Dodge 3500 SLT, HO, 6 spd, 4x4, SRW, quad cab, gauge on lift pump-boost-EGT-engine oil pressure and rail pressure, FASS 95, water seperator and 2m filter, steering box brace, 6.7L fluid damper
papaduck is offline   Reply With Quote
The Following User Says Thank You to papaduck For This Useful Post:
Tyler05 (04-16-2012)
Old 04-15-2012, 09:14 PM   #3 (permalink)
MXer Turned Diesel Nut
DNRCUSTOMS's Avatar
I have them, Im slowly fine tuning the adjustment on them.. So far I feel the stock clutch fan cooled much better. Im pretty sure i dont have them turning on at the right temp though.
06 3500 Mega, Just enough goodies left to get job done!! 871hp 1815 trq.. Retired
SNOWFLAKE Under the Knife!!
DNRCUSTOMS is offline   Reply With Quote
The Following User Says Thank You to DNRCUSTOMS For This Useful Post:
Old 04-15-2012, 09:17 PM   #4 (permalink)
bigtexss's Avatar
iTrader Score: 9 reviews
havent noticed much difference either way; empty or loaded. if you only tow occasionally theyre no big deal. electric fans are a no-no if you haul allday everyday (i.e. construction or hotshot etc); and i wouldnt really recommend frequent cross country trips. but towing a boat or a couple of weekend toys is no problem.
I like the fact that they keep running after the truck is turned off until the engine temp goes down. Plus they sound pretty cool!
'03 2500 QCSB S06 POD, II 100HP Nozzles, Hamilton Pushrods & Springs, 15% Ceramic Tint, Morimoto HID Retrofit, 5" exhaust.
Big Thanks to the Z Man at Hamilton Cams!
bigtexss is offline   Reply With Quote
The Following User Says Thank You to bigtexss For This Useful Post:
Old 04-16-2012, 11:23 AM   #5 (permalink)
Tyler05's Avatar
Ok thanks for the info I think I will replace it with stock and maybe add an electric fan later
Old 04-16-2012, 02:47 PM   #6 (permalink)
CalebZ400's Avatar
iTrader Score: 5 reviews
I have the flex a lites and never have problems with my temps, i dont tow alot maybe 7k max but its not a problem. Would def do it again over the stock fan just for the space it makes in front of the motor
2006 3500 Megacab Laramie 4x4 G56: Efi Live by Les at SBT, HTT 64/71/13ss over s480/96 1.32 Racecover, Steedspeed, Flux 4.3s, Ats Dual Pumps, SouthBend 3600DD, Arp, Hamilton 110s, Wicked Bypass, Spool Aid, Raptor+XX+XDP sump, Isspro, 3in Thuren, Pure Performance,GDP ladder bars, Flex-a-lites, Borgeson, Bilsteins, 35in Terras, ETC. 04/12/2013 753/1315 true 836/1459 corrected- twins 09/25/2012-714/1225 true 794/1362 corr@3300ft-with 67.7+ EfiLive stock RP street tune
CalebZ400 is offline   Reply With Quote
The Following User Says Thank You to CalebZ400 For This Useful Post:
06 5.9 (04-16-2012)
