What can a EDGE CTS see stock? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 01-18-2012, 12:19 PM Thread Starter
dieselninja's Avatar
So besides all of the power upgrades and being able to read codes, what can an EDGE monitor? I want to use it as a set of gauges, but I was wondering what it can do without drilling into and splicing a bunch of wires.
Can I see all of these parameters without tapping into anything?
- Backdown %
- Engine Load %
- RPM
- Speed MPH
- Throttle position
- Transmission Lock
- Transmission Slip
- Intake Temperature
- Boost
I know that the - EGT needs a hole drilled and a thermocouple installed
Can I add a Tranny Temp as well? I didnt see that option on their web site.
2004.5 QuadCab Shorty, 48RE, 6" Superlift, 5100's, 37" Disco Muds, Edge-EZ, Edge Insight CTS, 4"MBRP TBE, 2nd Gen Manifold, AFE prodry Filter, n-Fabs, Leer 100xl, Yakima Racks, Front hitch, V-LED HID's, DuraFlaps, Bushwacker Flares, Custom Dents...
dieselninja is offline
post #2 of 13 (permalink) Old 01-18-2012, 12:32 PM
I'm curios if it'll read actual oil pressure?
Believe they read fuel rail pressure, correct? On an '07 anyways?
2007 2500 Quad Cab 5.9
cal74 is offline
post #3 of 13 (permalink) Old 01-18-2012, 12:33 PM
MO chapter Vice President
danb359's Avatar
Yes! Along with coolent temp, and barametric pressure. Edge does NOT require the splicing of any wires. But my older additude moonitor will not read oil press , rail press, trans temp, or do any code reading.
Sent from my LS670 using AutoGuide App
05',4x4,slt,EDGE hot,SNOW mpg/max,ATS;intercooler:ex.manifold:billit trans:flexplate:5-star converter,BANKS;high ram:monster exaust,Kat mia,Keystone"ram air"hood,AFE stage II,AIRDOG 165,TOP GUNZ leveled,MAXX links,NITTO 295's,mystery switch,HTT 62/65/12,
danb359 is offline
post #4 of 13 (permalink) Old 01-18-2012, 01:11 PM
Meyer's Avatar
The parameters below are what the Edge CTS Insight is capable of monitoring.
Barometric Pressure, Battery Voltage (Insight Only), Boost, Calculated Load, Corrected Speed, Engine Coolant Temp, Engine Speed, Fuel Level (Insight Only), Fuel Rail Pressure, Gear with TCL, Intake Air Temp, Manifold Air Pressure, Mileage Coach, MPG Instant, MPG Average, Throttle Position, Time 0-60, Time 1/4 mile, Trans Temp, Vehicle Speed
Meyer is offline
post #5 of 13 (permalink) Old 01-18-2012, 02:40 PM Thread Starter
OK so it will read Fuel Rail Pressure, coolent temp, and barametric pressure without drilling and tapping into anything... anything else?
I would of imagined that RPM's and Speed would not have needed a special sensor or probe...
What is engine load and backdown?
post #6 of 13 (permalink) Old 01-18-2012, 02:48 PM
Pursuing the Great Commission
JWH_03_Dodge's Avatar
it can see your boost, IAT, transmission lock you are asking about in your original post.
I know on the 68RFE transmissions it will read trans temp, I'll have to check what else it says for other parameters
John
Before you post, ask yourself if this is going to add to the value of the thread?
04 F350 CCLB Cummins swap in progress
SOLD-08 Megacab longbed dually
SOLD-03 QC/LB 4x4 5sp
Originally Posted by Winkles View Post
The problem is that common sense isn't so common anymore...
JWH_03_Dodge is offline
post #7 of 13 (permalink) Old 01-19-2012, 11:45 AM
danb359's Avatar
Call EDGE thier #is 1-888-360-3343
danb359 is offline
post #8 of 13 (permalink) Old 01-19-2012, 04:36 PM
STONR's Avatar
On mine it will also read trans temp.
Backdown % will not be used on your truck unless you have the Juice as well. When running a power level above stock, when you have the backdown set up (boost and EGTs), the Juice will detune itself 'back to stock' as it approaches your set points. 50% backdown would mean that power output is ~ half of whatever level you have selected; 100% backdown is no additional power and you are back to stock output. It is good for keeping EGTs in check while towing a hill.
Engine load is some equation it uses to determine power output of the engine. 100% engine load would be the engine making all the power it can. I displayed this PID for a little bit right after I got the truck; it showed 47% load when I climbed a steep hill runnin 75 while empty. It was useless to me so I pulled up something else.
The CTS CAN display oil pressure BUT you will need another part from EDGE to do it. I looked in to it but determined that running an analog gauge was the cheaper route.
2005 2500 QCLB, BigHorn, 48RE/3.73, Edge Juice w/ CTS + Turbo Timer, TransGo Shift Kit, GDP 20/2 fuel filter on the frame, ISSPro EV2 Oil and LP Pressure in the cubby hole, Custom Diesel Steering Box Brace
STONR is offline
post #9 of 13 (permalink) Old 01-20-2012, 08:58 PM Thread Starter
No probe needed?
Here is the list as of now of what can be monitored simply by plugging into the OBD2
-Fuel Rail Pressure
-Coolant temp
-RPM's
-Speed
-Boost
-Intake Air temp
-transmission lock
So all I would really need is to drill and tap for my EGT's... I like it.
post #10 of 13 (permalink) Old 01-20-2012, 09:21 PM
bkteater's Avatar
Originally Posted by dieselninja View Post
No probe needed?
-Fuel Rail Pressure
-Coolant temp
-RPM's
-Speed
-Boost
-Intake Air temp
-transmission lock
Yes all You would need to do is drill and tap that. you can also get other sensors so the possibility's are pretty much endless. but i do have 3 other gauges in a pillar, sometimes the ECM can lie depending on what kind of tuning you have, for example i can get up to about 45lbs boost but the CTS will max out at 38 because that's all the ECM sees.. Be sure to get the expandable EGT probe so you can expand if you want to.
2014 Crew cab C/C Laramie\
2006 CTD Mega Cab Auto>G56 Swap/Valair/Bags/B&W/5in tb/Smarty
bkteater is offline
post #11 of 13 (permalink) Old 01-20-2012, 09:39 PM
Your Delightfully Ginger Kentucky President
Woosley's Avatar
CTS does a great monitoring job, I wished it offerd fuel psi.
2005 2500 SLT "Great White Buffalo"
2012 Laramie Mega Cab 3500 "Babe the Blue Ox"
Thanks to:Firepunk Diesel, D&J Precision Machine, Alligator Performance, Exergy
Woosley is offline
post #12 of 13 (permalink) Old 01-21-2012, 12:57 PM
STONR's Avatar
No probe needed?
Nope, no probe needed. The computer already can read the trans temp so you are just pulling that info from the OBD2 port!!!
As in my previous post, you can add on extra sensors (pressures, temps, ect) look on the EDGE website for there add-on plug in deal (Compatible with optional Edge Accessory System (EAS) to allow users to connect multiple, additional accessories).
So, you could monitor LP or oil pressure, differential temp, ect.
STONR is offline
The Following User Says Thank You to STONR For This Useful Post:
Dodge_trucks12 (03-24-2012)
