Twin Turbo DIY - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 12-27-2011, 03:13 PM Thread Starter
jordylee18's Avatar
Twin Turbo DIY
I'm looking into building a set of twins for my truck since I can't afford a big name set.
I'm wanting to use my 64/71 over an s480 along with a SteedSpeed manifold.
I don't know anything about routing the piping. If I get a steedspeed manifold, do I need a t6 flange or T4? 45 angle on the manifold or straight? Does the big turbo bolt directly up to the manifold or does the little one. My 64/71 is wastegated, is that the only one I need or do I need to get an external one?
Where does the piping go? On the cold side starting from the filter, would it go into the little one first and then the big one or the other way around? Same question on the hot side, into the big turbo and then wastegate it into the little turbo?
From what little reading i did it looks like people use 3 inch schedule 40 pipe. And the big turbo is the primary and the little one call the atmospheric turbo? Also it looks like the big turbo usually has a T6 flange.
I can probably make my own piping for the most part.
I'm wanting between 700-800 hp, I can't afford more than that. 700-750 would be perfect. As far as fueling I suppose my 100's are too small, maybe 120-150's?? And Todd at tc diesels 60% over cp3. I'm gonna rebuild the transmission myself with DTT's kit. I wanted to pull the truck originally, but decided not to mess with it. It's a daily driver.
Thanks for input!!!!
06 Cummins, 4*4, qcsb, a little fuel and a little air, a little TLC and I'll be halfway there
jordylee18 is offline
post #2 of 5 (permalink) Old 12-27-2011, 05:35 PM
estrada5.9's Avatar
Do your self a favor and search.
From your post you seem in a bit over your head.
Twin piping can be had for around 1200 bucks.
1998 QCLB
2003 QCSB
2010 QCSB
estrada5.9 is offline
post #3 of 5 (permalink) Old 12-27-2011, 05:39 PM
CantStopCummins's Avatar
I agree with estrada, you need to research quite a bit more. Building your own twins piping is a very daunting task that I have only seen a select few guys do.
2005 QCSB | MTD Built 48RE | Smarty UDC | Edge Insight CTS | AFE stg 2 | Muffler Delete | GDP 2MK Big Line | 2.5" level | Gauges | Bushwackers | Nitto Trail Grapplers 35x12.5 | MTD Traction Bars | CD Steering Box Brace | Maxx Links
CantStopCummins is offline
post #4 of 5 (permalink) Old 12-27-2011, 07:16 PM
Bubbles
oldsmokey's Avatar
^^^ Its not difficult at all expecially if you have a block and head to moc everything up on. You will want a t4 manifold for the s300 based secondary. Here are a few pictures from the last set I built
07 Mega Cab 946/1546 SOLD
14 Mega Cab Longhorn
oldsmokey is offline
post #5 of 5 (permalink) Old 12-27-2011, 07:18 PM
Bubbles
oldsmokey's Avatar
Finished product
