Quiet the Airdog down - Dodge Cummins Diesel Forum
post #1 of 34 (permalink) Old 12-12-2011, 12:33 AM Thread Starter
Moochoff's Avatar
What have guys been doing to quiet the in cab noise of lift pumps? I think if I pressed some rubber or something in the air dog mount it would quiet it done a bit. I had it sitting on the ground all hooked up and it was fairly quiet so I think its just the vibration transfering through the frame
I mounted it on the driver side frame rail right behind the front door
Moved on to smaller toys.
Moochoff is offline
post #2 of 34 (permalink) Old 12-12-2011, 01:31 AM
Innovative Diesel
DODGE74's Avatar
iTrader Score: 15 reviews
Thats about where mine is at, maybe closer to the back door but mine is very quiet. When the engine is running you cant hear it or even feel it running.
EFILive, HPT, UDC, UDC Pro, MM3, Warp, MCC, SCT custom tuning
DODGE74 is offline
post #3 of 34 (permalink) Old 12-12-2011, 01:59 AM Thread Starter
Moochoff's Avatar
Ya i figured it would only take a few minutes to take the 3 bolts off to put something between the mount. When the smarty is programming the truck it really gets annoying. Not sure if its the norm, but it kicks on and off constantly for a minute or two of the programming time...
Definitely disappears when the cummins fires up
Moochoff is offline
post #4 of 34 (permalink) Old 12-12-2011, 07:49 AM
Innovative Diesel
DODGE74's Avatar
Yeah its normal for the pump to run and cycle during programming. I always just pull the fuse to the pump before I do any flashes.
DODGE74 is offline
The Following User Says Thank You to DODGE74 For This Useful Post:
Moochoff (12-12-2011)
post #5 of 34 (permalink) Old 12-12-2011, 12:32 PM
coophdd06's Avatar
put a sump in the bottom of the tank, call Hellmann performance they will tell you all about it. so then its graity fed not drawstraw fed
2006 QCSB, Built trans/ AFE/ billet63/68 /5" /EfiLive/ ARP/ FASS150/ Stainless diesel/ Fleece/ DiPicrol/ pusher/ #110 Hamiltons
coophdd06 is offline
post #6 of 34 (permalink) Old 12-12-2011, 12:38 PM
1997chevy454's Avatar
iTrader Score: 4 reviews
That's weird because I installed one for a guy Saturday and it's extremely quiet. My raptor 150 is loud as all get out. I'm thinking about upgrading just for this reason and maybe go a little bigger.
'05 QC3500 DRW 2wd> new motor. Hamilton Cams, s472
13.47@106.01
1997chevy454 is offline
post #7 of 34 (permalink) Old 12-12-2011, 07:03 PM Thread Starter
Moochoff's Avatar
After busting my fuel return connection and stripping the nut to my fuel tank strap, there is NO way im dropping that damn tank again but I mostly got it for it the filters
Moochoff is offline
post #8 of 34 (permalink) Old 12-12-2011, 08:32 PM
That's one reason i pull the bed. Alot less working on your back
13.47@106.01
post #9 of 34 (permalink) Old 12-12-2011, 09:16 PM
nfd538's Avatar
iTrader Score: 6 reviews
Mine was loud as hell even with motor running. And I had a Hellman sump.
2005 CTD sold
2006 Jeep SRT8 sold
2012 Ram 1500
nfd538 is offline
post #10 of 34 (permalink) Old 12-12-2011, 09:28 PM
Smourj21's Avatar
You think the AD is loud, have you heard a FASS? You canhear the FASS over the motors!
02 QCSB 6 Speed|215 P-Pump 600cc 28*|64/S480|SAC 7x12|131 DVs|AD150|Colt 181|HD Push Rods & Springs|ARP/O-Ringed Head|Fluidampr|Valair Tripple Disk|.084 Lines/Tubes|Tunnel Ram|CFM+|Water/Meth|6"Miter|Dana60/80|4.88|True Trac|35" Toyo MT's|
Smourj21 is offline
post #11 of 34 (permalink) Old 12-12-2011, 09:31 PM
One part at a time
gneal02's Avatar
iTrader Score: 7 reviews
Can't really hear mine over the engine and and the radio and I also always pull the fuse when I'm programming the truck.
07 2500 Mega Cab SLT- Sold
14 2500 Mega Cab Big Horn
gneal02 is offline
post #12 of 34 (permalink) Old 12-12-2011, 11:07 PM Thread Starter
Moochoff's Avatar
I would have loved to pull the bed but I did it alone and I have a 5th wheel ball and a trailer hitch which I guess makes pulling the bed a PITA... So I dropped about 10 gallons of fuel
If I had it to redo- I would have started by taking my time and not busting the fuel return quick fitting but I would have also drained the tank close to empty with the stock lift pump into diesel jugs with the fuel line up front
Moochoff is offline
