Milling off intake - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 04-07-2011, 11:33 AM Thread Starter
Andrew Allen's Avatar
Milling off intake
Hey guys, im gonna take my junk head to the mill for practice of milling off the factory intake manifold, then on the new head ill do it again and put something better on. there anything anyone wants to toss in? how far to go? etc
after its off i will mill and put together an intake manifold, id like to do a custom equal length intake plentum but im struggeling to find high pressure line so i can move the rail, so if anyone knows where i can get 35,000 PSI plus rated line ill take that input as well!
feel free to toss in any info you want (PS im going to be doing it at school on our CNC Mill for free)
: 2003 Dodge 6 Speed, "THE DUALLY" Smarty TNT/MP-8, Stage 1 CP3, FASS 150/150, 295/75/17 Terra Grapplers, 2nd Gen Manifold, Triple Gauges(Oil Temp, Boost, EGT), BUMPS under the back seat! 135 MPH TESTED! SBC Iron Giant II!
Andrew Allen is offline
post #2 of 15 (permalink) Old 04-09-2011, 06:39 PM
You could probably use a dual feed cp3 line...it'd be flexible and is rated for the high pressure.
rocket is offline
post #3 of 15 (permalink) Old 04-09-2011, 06:43 PM
Mudbuster87's Avatar
We have a local shop called hose house in my area, they could custom make you one but I don't know how much they would charge if you are interested I will try to get you their number.
Sent from my DROIDX
06 Mega 2500 4x4, G56, 12" custom lift, bodyguard front and rear bumpers, 20" Novakanes with 41" Michelin XL's, AFE Mega Cannon, Smarty S-06 POD, Edge CTS Insight monitoring, 5" Flo Pro exhaust, and CFM+ Intake manifold.
Mudbuster87 is offline
post #4 of 15 (permalink) Old 04-09-2011, 11:05 PM Thread Starter
I never thought of the flexible dual CP3 line... that could just possibly work! may not look the cleanest but it would work!
post #5 of 15 (permalink) Old 04-14-2011, 08:46 AM
B_Schutz's Avatar
Ive been thinking about a equal length intake too. But, I am Starting to think of a tank intake to divide the air, then run it out in individual runners? As close as the ports are on a 24v this may be almost imposible to weld. I know this zz isnt a intake to use on a 24v, but this is what I am throwing around.
Cant get the pic to load(Sheetmetal intake)
2004.5 HO325 QCLB, 4x4, DRW, Goerend, smarty, 3.73s, 5" MBRP, studs, honed Bosch 150s, AD150, 64/71/14ss over S480ss twins
B_Schutz is offline
post #6 of 15 (permalink) Old 04-14-2011, 09:18 AM
cgmorgan06's Avatar
iTrader Score: 61 reviews
this might help you out:
ZZ Custom Fabrication
Grant
'06 black mega laramie 3500 srw 4x4, fully loaded, 6" superlift, 37" trail graps/22" M81s, AMP steps, true 5" custom duals w/7" tips, Autometers, ATS Stage 6 48re, II 85%, JL 150's, 62/480, HD push rods/springs, Spool Aid/GDP Air Boss/Grid Delete/ATS Arcflow, Airdog II, Amsoil bypass, Wicked coolant bypass, GDP Ladder Bars, Viair dual 480C, Nathan K3LA, Kenwood DNX 9140, JL 10's
560hp/1268tq 4/30/11
cgmorgan06 is offline
post #7 of 15 (permalink) Old 04-14-2011, 09:21 AM
Dont Upset The Hulk....
1badRam06's Avatar
Sent from my DROIDX
They make custom fuel lines, for Common Rails?
2006 Ram 2500 QC, SB, Fun Truck, Far From Stock
2016 Ram 2500 CC, SB Sport Laramie All Show and No Go....
'06 Built for MJC 1984-2009
1badRam06 is offline
post #8 of 15 (permalink) Old 04-14-2011, 10:25 AM Thread Starter
"custom fuel lines" is a general term... I just need the line itself so i can move/mount my rail then plum to the injectors from there, but as far as someone making a kit to say move your rail from factory location to another specific location(like the side of the block for example) im guessing not, never heard of anyone else moving or wanting to move their rail
post #9 of 15 (permalink) Old 04-14-2011, 10:33 AM Thread Starter
That does help!! THANKS!
post #10 of 15 (permalink) Old 04-14-2011, 10:38 AM
ATS Diesel Performance
RAN '07@ATSDiesel's Avatar
If you move the rail, you gotta move all the lines. B&B tooling is up in your neck of the woods. You might wanna contact them. Here is a pick of mine:
07.5 mcsb, Crower rods, Stage 4 68rfe, B&B side mount intake, ported head, II 120% CP3, Exergy injectors..........turbo too be decided soon
ATSDiesel 866-209-3695 ext. 160
Aron@ATS Diesel.com
Sponsored by:Blacks Diesel Performance, Rollin Smoke Diesel, All American Diesel Performance, Draconian Diesel, and Isspro
RAN '07@ATSDiesel is offline
post #11 of 15 (permalink) Old 04-14-2011, 10:43 AM Thread Starter
looks good, did you move your rail or is that factory location with that side intake? also do you know if the 6.7 rails are bigger/flow better than a 5.9 rail? also thinking possibly a rail off of an 8.9
post #12 of 15 (permalink) Old 04-14-2011, 10:57 AM
Only in a HEMI
BBRam's Avatar
iTrader Score: 13 reviews
This will show you the difference between the 5.9 and 6.7L rail.
6.7L Plenum Cover Swap In Progress
2012 Ram 2500 5.7L HEMI
2012 Dodge Challenger SRT8 6.4L HEMI
2015 Hellcat, and ya, it's got a HEMI
BBRam is offline
