homemade air intake - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 11-26-2007, 07:27 PM Thread Starter
mike415's Avatar
homemade air intake
i was reading awhile back on here and someone had made an air intake out if pvc pipe they had a parts list of everything you needed to build it can yall help me out thanks
07 qaud cab 5.9 six speed 4x4 Sold
2011 Mega cab Laramie 4x4 6 spd leveled with 305/55/20's.
mike415 is offline
post #2 of 11 (permalink) Old 11-26-2007, 07:59 PM
josterbauer's Avatar
Yeah, I can help with that. I wrote one a while back, it is in the tech articles. I will try and find the link for ya. Here is the one that I wrote up Custom intake w/Eaau 4090 amsoil filter - A
06 Mega Cab 4X4 Auto
04.5 ctd cc, auto, 4x4
Sold - 2001 qc, auto, 4x4 lb
josterbauer is offline
post #3 of 11 (permalink) Old 11-26-2007, 09:15 PM Thread Starter
mike415's Avatar
search no more this was the one i was looking for thanks alot by the way how much does it make that turbo whistle :thumbsup
mike415 is offline
post #4 of 11 (permalink) Old 11-27-2007, 07:20 AM
It will get a lot louder. I built this one, and could not believe how much it made the trubo sing.
post #5 of 11 (permalink) Old 11-27-2007, 02:32 PM
homemade intake
This may sound silly but is there any advantage to make the pvc intake tube but leave the stock box? I have the amsoil drop in filter and really don't want to spend the extra $$$ right now on buying the cone filter. Give me your thoughts. Thanks
2007 Mega Cab Laramie 5.9 Cummins, Smarty Jr. Jake Brake, 5" MBRP Stainless Exhaust, 48re, Amsoil fluids and oil bypass, Nano filter, Toyo Open Country AT 285/75/17, AMP research power steps
mmac4u2 is offline
post #6 of 11 (permalink) Old 11-27-2007, 03:08 PM
08ag's Avatar
the only benefit from doing the tube is more singin' (intake baffle removal) and possibly increased air flow if you go with bigger tube. i went with 4" inside diameter pvc and a 4091 filter. you shouldnt see much if any performance increase...
'03 QC LB, 6 inches in, 5 inches out
POWERED BY 6 HOLES OF HELL
08ag is offline
post #7 of 11 (permalink) Old 11-27-2007, 04:01 PM
12vRuss's Avatar
Is there any problem with having the filter right in the open like that? Could something like the IceBox work with this setup if I wanted to get one later?
Cool idea, BTW.
96 12v 2500 SLT CCLB 4x4 Auto - KDP killed, 5" straight pipe, 30" FTE Diesel Resonator, AMSOIL 4510, Silencer ring MIA, Driver's door/tailgate hinges rebuilt, Driveshaft rebuilt, Bogus wiring deleted
12vRuss is offline
post #8 of 11 (permalink) Old 11-27-2007, 06:36 PM
I have had mine on like that for over a year. I have had zero problems with it. I do some harcore snow goose hunting in muddy fields with this as well.
post #9 of 11 (permalink) Old 11-27-2007, 09:40 PM
06MegaCab's Avatar
I have a similar setup and dont really have any problems, I also went through the painstaking process of making a heat shield for mine-took all friggin day
16' Ram 2500 CCLB G56 Bright White
06' MegaCab 4X4 48RE-sold
14' Can Am Maverick 1000R
06MegaCab is offline
post #10 of 11 (permalink) Old 12-08-2007, 05:02 PM
4x4daddy's Avatar
Here's what I built using PVC pipe and existing True Flow Canister/filter
4X4daddy - 04 Ram 2500 4x4 CTD//4 Spd Auto//3:73//315 70 17 BFG Tires
Van Aaken 3.1//TruFlow XDI Extreme Air Intake// 4" homemade TorqueTube
5" FSP Exhaust//Boost Elbow//Silencer Ring Delete//Grid Heater Delete
4x4daddy is offline
post #11 of 11 (permalink) Old 12-10-2007, 12:34 AM
hump's Avatar
Thumbs up Mine is homemade.....$55.00 total
I don't use PVC, but I did use an old piece of 4" exhaust pipe......
2007 Megacab, Automatic built by TRE Diesel, Cooper ST Maxx 275/70/18, Raceline Wheels, 2" HBS Leveling Kit, 5" Exhaust with 6" Tip, 5" Cold Air Intake, Pusher Intake, Smarty, Quadzilla Boost Fooler, Phantom Gauges
hump is offline
