2003 vs 2005 cummins manual... Differences? One better? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 10-31-2010, 01:21 AM Thread Starter
BadBowtie03's Avatar
hey guys I have 2 trucks that I am looking at... a 2003 and a 2005 cummins manual. there is about a 3500 price difference for the newer one...
Im curious is the 2005 a lot better or faster? or does it have a better transmission or turbo? more reliable? is the 2005 easier to make faster? I've heard the 2003 will get better mileage? is that true is it a lot better? I want to know if it is worth spending more money...
if they are about the same I will probably go with the 2003 to save money... the trucks are basically identical.
BadBowtie03 is offline
post #2 of 13 (permalink) Old 10-31-2010, 01:22 AM Thread Starter
Both trucks are 6 speeds.
post #3 of 13 (permalink) Old 10-31-2010, 01:49 AM
Do u know what engine is in the 03? There were 2 diesels offered that year. The SO had 250 hp and the HO had 305. If it's an HO I would buy the 2003. I had an 05 that I liked very much, but I believe the 03 models didnt have the third injection event and got better mileage.
mpw8679 is offline
post #4 of 13 (permalink) Old 10-31-2010, 01:56 AM
im no 3rd gen guru but i can help to answer some of your questions, others chime in and correct me if im wrong here.
the 2005 will have a little more power stock compared to the 2003. the 2005 will have 325 and the 2003 will have 305.
the 2005 will be easier to make power initially, but the 2005 will eventually hit a wall when it comes to building power because the 3rd injection event gets in the way, and the 2003 will not hit that wall.
the 2003 will get better mileage because it only has 2 injection events per powerstroke and the 2005 has 3, in turn using more fuel. (not a major difference in fuel mileage) the 2003 also has an 8 hole injector compared to the 5 hole injector in the 2005.
the 2003 will have a smaller turbo (he341) the 2005 will have the better turbo (he351)
im not positive on this but i think the 2003 will have the nv5600 and the 2005 will have the g56. i hear the nv5600 is the better one?
if i had the choice i would probably get the 2003, but really its a toss up. both will be great trucks and leave you satisfied. just make sure to add better fuel filtration as soon as you get it to help prevent injector bodies from wearing out.
hope this helped a little.
good luck
1999 3500 extended cab long bed 4x4. isspro fuel pressure, egt, and boost gauges. arp head studs. 150 injectors. kool-vue tow mirrors.
6-in-a-row is offline
post #5 of 13 (permalink) Old 10-31-2010, 01:59 AM
i thought all the 6 speeds had the HO engine at 305?
except for those stinkin california trucks...
post #6 of 13 (permalink) Old 10-31-2010, 02:34 AM
blackbeast06's Avatar
I had a 2005 that I absolutely loved and it was bone stock! people have different opinions but like 6 says the 03 will be a better build but the 05 has more stock horsepower. . I like the g56 trans personally because reverse is hidden! nobody can drive it if they don't know anything about it. . But both trucks will be everything you want and more same outer make-up just a few mechanical differences . . All depends on what YOU want!
2006 QCSB 6 Speed/ SBDD 3600/ Diablo/ Boost-Pyro Z-Series/ AFE Stg II/ 20" XD Hoss/ Nitto Terra's/ Wants: Turbo & Injectors!
blackbeast06 is offline
post #7 of 13 (permalink) Old 10-31-2010, 02:38 AM
oleblue5's Avatar
My truck is a 2005 and its a nv5600, 4th tends to go on the g56 if you beat on it alot.
2005/6spd. sb dd, airdog 150, silver 62, dual fuel line kit, k&n, mp-8, Smarty revo tnt, straight 5inch, arson 3 kit,.DDP 90 tips.
10/23/10 dyno 497hp/927lftlbs stock cp3 & injectors
SOLD
oleblue5 is offline
post #8 of 13 (permalink) Old 10-31-2010, 02:46 AM
My 5th and 6th syncs are going out now
post #9 of 13 (permalink) Old 10-31-2010, 04:08 AM
No matter what u buy save some money for a little known CR secret called the smarty.
mpw8679 is offline
post #10 of 13 (permalink) Old 10-31-2010, 04:08 AM
World Champs!!!
MoparProud's Avatar
good luck
This pretty much sums it up. 6 speed was only available behind the HO (305/555) in 03. Theres a possibility the 05 has an NV. Reverse all the way right and up is NV, to the left and down is G.
Only available with NV4500 5 speed. Cali/SO were 5, HO 6spd
'07 3500 SRW QC/LB-EFILive w/Silverbullet Tuning-Goerend-WOP triple turbo-200% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
post #11 of 13 (permalink) Old 10-31-2010, 05:55 AM
vvv SOME PEOPLE'S KIDS vvv
cummins04.5handshaker's Avatar
NV5600's were made up to 05 and the 05.5 was when the G56 was introduced. The G56 will hold less power and parts seem to let go alot sooner on them while the NV5600 will hold up a bit longer. The G56 has smoother shifts vs the NV5600. Now on the motors the 05 will make alot more power with just a programmer, intake and exhaust while the 03-04 take a little more work with stacking various programmers then the lift pump issue with the 03-05 have block mounted pumps versus the tank pump in the 05.5's. If it were me again I'd go with 03 just b/c they can take bigger nozzles and seem to make more power if your goin all out with a build. But just driving with programer, intake and exhaust go 05. Just my .02
GITT SUMMMM!!!
08 mega Laramie 4wd auto.. the white wagon baby hauler. EFI & Trans tuning.
04.5 w/compounds, dual fuelers and a lot of wasted money
'99 sport...G.O.N.E.
cummins04.5handshaker is offline
post #12 of 13 (permalink) Old 12-12-2010, 08:17 PM
big-c's Avatar
03 hands down i love mine and like said you can build it to be a bull.
:2003 3500 ctd 4+4 6 sp tran bd td ppe programmer turbo elbow afe air new exhaust golden eye 4' turbo back free flow stainless
2009 polaris rzr
big-c is offline
