Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 11-26-2005, 09:20 AM   #1 (permalink)
BHAF help
Ok its me again, and I do not understand the BHAF. I got that it stands for but can it be as simple as adding a 50 dollar air filter versus a 300 dollar kit (AFE stage 2). Help
2006 CTD 2500 4x4 Quad Cab, issipro tranny, boost and egt guages in the a-pillar. Rail and Fuel Pressure above the mirror. Homemade ram air with intake. 4 inch out, with only an aero. Stock 48RE, hopefully not for long
pluguglyinhere is offline   Reply With Quote
Old 11-26-2005, 09:33 AM   #2 (permalink)
Guest
Posts: n/a
yes it is and its less then $30 here
www.fleetfilter.com
and heres some info ofr ya'
http://www.dodgedieseldatabase.com/toppage2.htm
DM
Old 11-26-2005, 01:32 PM   #3 (permalink)
Wyoming
's prints for the heat guard work pretty well. I had to shave a little more out of the notch on the back for the AC line and the bolt holes had to be adjusted just a bit as well. Overall it looks great. You do need a short piece of 4" pipe to support the filter where the hose clamps down. I went without at first thinking it was strong enough, but it kept slipping loose.
'98 12 valve QC SB 5 speed Laramie SLT 4x4. custom plate, 3k GSK, 4" Pac Brake, SBC, II Phat Shaft 62/80, Rip's 4" exh. timing at 16.5
TPCDrafting is offline   Reply With Quote
Old 11-26-2005, 10:32 PM   #4 (permalink)
Ok so just so I understand this corectly. I can go buy one of the BHAF that you all listed out and remove my air box and connect this, make a nice heat shield and have the same benifit as the kits? Also, are these filters cleanable also?
Old 11-26-2005, 11:38 PM   #5 (permalink)
Guest
Posts: n/a
Click this....
Yes...yes and no you cant clean it you get an outerwares to prolong its life ...info on link
Its the way to go IMO
DM
Old 11-28-2005, 01:01 AM   #6 (permalink)
Moderator
Monster Truck's Avatar
K I just ordered the bhaf I paid 41 with shipping good price? And you got a good site for the outer ware? Cheap!!!!! price?
95 Ext Cab SLT, Loaded, built 5spd with hurst, 3.54s, Leveled 4'' Lift 35'' Toyos, optima redtops, 4'' Straight into a 5'' bed kit with 6'' Mitres, Protech, Super B 57/66/14, Stage 2 Sticks, 3GSK, #60 Valve Springs, Stage 2 clutch, BHAF, Plateless, Boost and EGT on the pillar fuel pressure on the colum.
Monster Truck is offline   Reply With Quote
Old 11-28-2005, 01:20 AM   #7 (permalink)
Guest
Posts: n/a
The outerware IMHO is a must to help keep any moisture out, I washed my motor one time and purposly hit the outerware a couple time to see how it would do, I pulled it off and the BHAF was dry, that is key where I live
Old 11-28-2005, 05:53 AM   #8 (permalink)
Guest
Posts: n/a
the link to the outerwares is on the database link posted on this thread
DM
Old 11-28-2005, 12:43 PM   #9 (permalink)
Moderator
yeah but they dont let you order off that site.
Old 11-28-2005, 12:50 PM   #10 (permalink)
Guest
Posts: n/a
Click down at the bottom on purchase, or dealers, distributors, it said somthing like that
Old 11-28-2005, 01:49 PM   #11 (permalink)
Tech Specialist
Gary - K7GLD's Avatar
Here's some pictoral info on mine:
http://www.turbodieselregister.com/f...d.php?t=120212
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
Gary - K7GLD is offline   Reply With Quote
Old 11-28-2005, 05:45 PM   #12 (permalink)
Moderator
Hey I still cant find a site to get it off of and I want to do it on line. Where did you guys get yours?
