| 3rd Gen. Performance Parts Discussion Discussion of Performance Parts For the 3rd Gen Trucks No Advertising ...NO ADVERTISING |
#26 (permalink) | |
Bhaf
http://fleetfilter.com/airfilters.html scroll down to Wix #42790 , air filter#42790 and BHAM! Thar she blows!!
2004.5 Ram 2500, 2WD Crew Cab Long Bed Cummins 600, 373's, Bullydog with Outlook Monitor, BHAF with Outerwears pre-filter, 4" ANSA Silverline turbo back exhaust(lost the cat) with flow thru muffler, Oilguard bypass oil filter, second lift pump CARPENTERS LOCAL 1506 Build it, and they will come Last edited by bekim : 01-01-2006 at 09:06 PM. |
#27 (permalink) |
UPS hopefully will get my filter to me by Thursday. I just ordered the outerwares prefilter in red to match the letters on the valve cover. Can't wait till thurs when they get here. I bet the big after market air system companies don't want people to figure out a better and cheaper way. Thanks to whoever came up with this and did all the homework!
1999 2500 Reg Cab(Coupe) 4x4, Long bed, 4spd auto, 4:10s, straight piped, BHAF, on board battery charger, 8.5ft SUNLITE slide in camper
#28 (permalink) | |
![]() Join Date: Dec 2005
Location: IDAHO check events forum for idaho event info
that be ron [moparguy] a member here that 1st researched and came up with the bhaf and promoted it:thumbsup its worked well for many for several years
for IDAHO discusion and events check www.idahobombersforum.com Last edited by MUDDY : 01-03-2006 at 11:46 AM. |
#29 (permalink) |
outerwares part number for the Napa 2790 filter is 20-1085. I just ordered it . Bekim ###
2004.5 Ram 2500, 2WD Crew Cab Long Bed Cummins 600, 373's, Bullydog with Outlook Monitor, BHAF with Outerwears pre-filter, 4" ANSA Silverline turbo back exhaust(lost the cat) with flow thru muffler, Oilguard bypass oil filter, second lift pump CARPENTERS LOCAL 1506 Build it, and they will come |
#30 (permalink) |
Bhaf
Got the parts and installed it a couple of days ago. Seems to have a bit better throttle response. EGT's seem to run about the same as before. Mileage seems to have improved about 1 mpg so far (have only run about 150 mi) This thing is monster sized!! I'll try to post some pics today. Napa #2790 filter with Outerwears #20-1085 prefilter. Used a 4" abs long elbow and a 4" section of 4" pipe to complete the assembly. If the setup is problem free, I'll disassemble it and paint it to match. Bekim ![]() Cheers ###
#32 (permalink) |
Put it all on friday, seems to breath a little easier, looks great. Attached the filter minder to the end of the filter. Put the charger on the heat shield. I run my camper off my battery alot when out on the beach and don't want to lug the generator around. Have'nt had a dead bat yet the trickle charge is good to keep them topped off. Knew a lot off guys in MT and ND used them in conjunction with the block heater to keep the batts warm on cold nights.
#33 (permalink) |
Attachment 430 I seem to get the same mileage at 75 that I got at 65 berfore. Only about 300 miles driven so far. Attachment 431 BHAF pics ![]() Cheers Bekim ![]() ###
2004.5 Ram 2500, 2WD Crew Cab Long Bed Cummins 600, 373's, Bullydog with Outlook Monitor, BHAF with Outerwears pre-filter, 4" ANSA Silverline turbo back exhaust(lost the cat) with flow thru muffler, Oilguard bypass oil filter, second lift pump CARPENTERS LOCAL 1506 Build it, and they will come Last edited by bekim : 12-16-2006 at 05:08 PM. |
#34 (permalink) | |
Cheers Mike ###
