Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 07-19-2007, 10:09 AM   #1 (permalink)
trik396's Avatar
Exclamation TST warning for June 2006 or later trucks
This is from TST website...
Important note on the PowerMaxCR for a 2006 or 2007 Dodge Ram:
- The rail pressure part of the PowerMaxCR does not currently work on Dodge trucks with a build date of June 2006 or later. TST is working on this problem and will update the program and/or harnesses at no additional cost when we get a fix. In the mean time, do not connect the TST rail pressure harness to the rail pressure sensor, leave the stock harness connected to the rail pressure sensor. - Also, the PowerMaxCR does not currently work on some Dodge trucks with a build date of June 2006 or later even with the TST rail pressure harness not hooked up. Some trucks run rough and some set a P0148 code. TST has stopped shipping PowerMaxCR units for Dodge trucks with a build date of June 2006 or later until the problems have been resolved.
From what I heard from others who have communicated with TST directly is that using this on the newer trucks can and will cause UNCONTROLLABLE egt's no matter WHAT SETTING. Even the lowest settings will destroy your engine. Crazy sky high temps that WILL MELT YOUR PISTONS QUICKLY.
I am getting this info from those who have had carnage. I DON'T have first hand info, but thought those of you who are potential users should know.
Good luck.
2005 DodgeRam2500 CTD/ 4x4/ BigHorn/ Autometer/AmsoilBypass/AemBruteforce
Trans by Goerend/ Walbro392custom fuel system/CAT2micfuelfilters/IISilver64/BanksIC
Projector HID's/DiablosportPredator/VanAaken3.2/QuadsXZT
617hp 1200+trq
KOREChasewFoxShox/Carli&FoxDualSteeringStabilizer/ NittoTerras285's
3 people can keep a secret if 2 of them are dead...
trik396 is offline   Reply With Quote
Old 07-19-2007, 11:35 AM   #2 (permalink)
Go for Broke
Graphic Man's Avatar
good Info :thumbsup
08 Mega cab is on it's way
SOLD01 4X4 Q-cab Sport Monster VP, Redline Injectors, twins 66/S480 with race cover, full billet trans etc,
Special thanks to: Redline diesel and Diesel Dr.s
Graphic Man is offline   Reply With Quote
Old 07-19-2007, 03:21 PM   #3 (permalink)
Former Staff Member
MR4WLR's Avatar
I think we'll make this a sticky :thumbsup
Do our part to make sure as many people are educated about the issue till they get it resolved.
Corey Ritter - Amity, OR
'04 Patriot Blue SRW 3500 QC 4X4 Laramie, 6spd, HO, Edge EZ, TST PowerMAXCR, Smarty, SPS 66, Rip's 4", AFE PG7 W/torque tube, FASS 150, Superlift leveling kit, Ride Rite's w/onboard air, Line-X. Torklift camper tie downs, fuel vent mod, CB, GPSmap 168, Buckstop/Warn 12,000 lb, KC Daylighters, MTL w/prolong in trans, Haisley DD, DiPricol gauges and Quad Commander. 77K
513/1043 Fast Specialties DDD 4-15-2006 TST-EZ stack, Quickest 1/4 mile ET 13.949 @ 96 MPH @ PIR
Hauls Lance "Lite" 1025 @4klbs
Wifes truck '98 Intense Blue 12V QC LB 4X4 Auto
MR4WLR is offline   Reply With Quote
Old 07-19-2007, 04:45 PM   #4 (permalink)
NADM Advisory
triton's Avatar
a little more first hand info. I talked in length to Mark at TST about this since I was sold one before they stopped selling them to people that wanted to put them on the after 6/06 build engines. Edge is also having the same problem where they don't work on the late model 07's.
The fact is, the TST does work on some trucks. It worked on mine as long as I didn't have the RP connected. I did end up frying a pistons but, that was after having the TST installed for 6 months. I am not saying the TST had anything to do with my problem as I was playing hard at the track.
Some trucks it won't work at all on, others have intermittent problems... etc. The problem is in the pressure to the injectors. When the box is turned on, it spikes along with what the ECM is already doing instead of replacing the ECM signal. Both together can cause injectors to stick open which is where the fried pistons happen.
They've really worked on trying to figure out what's happening but, without D/C's secret code to the ECM, it's been a dead end. They've also been working with Marco to figure it out since the Smarty seems to work.
People do need to STOP using them on the 6/06 and later if there are. He said, people will call there and lie saying they have a 06 model but, really have 07's just to get the box sold to them. He also says they can't control who their dealers sell to and can only hope they aren't being sold to those with the late model 07 5.9.
They have covered themselves legally and are only responsible for any damage to their box. This is understandable because they are not putting a gun to anyones head to use their product. This sentiment is heard throughout the performance world so, if you play.... YOU pay
This is not to discredit TST or say they have a bad product, on the contrary. The box is a great product and works great on everything but, the newer Can-Bus ECM. This was only to point out the issues on the after 6/06 model 5.9L. They're in the works on something for the 6.7L
www.BlackPatchDiesel.com
Garmon Diesel / Airwerks / High Tech Turbo
AirDog / Glacier Diesel / NADM / XSPower
triton is offline   Reply With Quote
Old 07-19-2007, 05:05 PM   #5 (permalink)
Super Administrator
BBRam's Avatar
Great Post Triton. :thumbsup
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 07-19-2007, 06:47 PM   #6 (permalink)
Super Moderator
rbmchief's Avatar
sorry to hear about your truck triton.
02 2500 slt 4x4,auto,icebox cai,silencer ring mia, Quad xzt+,jhook, Pinnacle 4" turbo back exhaust,westach elec fuel guage, isspro transtemp,boost,egt guages in pillar, line x in bed, runnin stanadyne. [url]
http://www.cumminsforum.com/forum/wyoming/
rbmchief is offline   Reply With Quote
Old 07-19-2007, 07:01 PM   #7 (permalink)
NADM Advisory
triton's Avatar
Thank you sir but... it's really ok. I'm well aware that mods and playing will cost money. I planned to build the engine but, not so soon. I figured I woould have problems going to the track but, not a toasted piston. It should be done in a few weeks. It's at Scheids being built from the ground up
sorry, didn't mean for a sticky post to be about my truck :fist:
Old 07-19-2007, 11:02 PM   #8 (permalink)
Dodgezilla's Avatar
I ran my old TST from my 03 on my 07 truck for a while and other than throwing that P0148 code on occasion I had no other issues with it other than it was slipping my clutch something terrible. So, I think you may be safe with an older unit, just not the newer ones....
04 Ram 2500 305/555 HO,48RE,4x4,3:73s,QC,LB,Infinity sound,MOPAR DVD,Green /Silver,PW Wheels,4"exh w/ 6.7l+BullyDog mufflers,Timbrens,Bilsteins,VA C3.2,DS Predator,Westachs,Fumoto,BHAF,2nd gen intake,HE351,ImitationTrainHorn,TRM, 16" pusher fan
Dodgezilla is offline   Reply With Quote
Old 07-19-2007, 11:47 PM   #9 (permalink)
does anyone have marks number? I can't access there website right now and I have a couple questions about my tst concerning this issue
06 Slt 2500 6-speed,muffler, cat, silencer MIA,5 in stacks,isspro guages,go ind. headache rack,gooseneck hitch, TST, DD 3600 SBC, AEM Workhorse, GDP Big line kit, 35x12.5 hankook mt's
ramfreak01 is offline   Reply With Quote
Old 07-20-2007, 01:01 AM   #10 (permalink)
Former Staff Member
MR4WLR's Avatar
NOTICE TO CALLERS- OUR PHONE SYSTEM IS NOT WORKING PROPERLY, WE ARE WORKING TO GET THIS FIXED ASAP, WHEN CALLING IN CALLS MAY BE DROPPED, SORRY FOR ANY INCONVENIENCE.
812-342-6741
Fax: 812-342-4880
Old 07-20-2007, 01:12 AM   #11 (permalink)
pro99's Avatar
So if they have a call that someone wants to buy something then it works fine but if they someone calling in with a concern then click
Just joking love TST stuff and ran it myself on my old motor and still would If I had a 24 valve motor:thumbsup
I went to seen Mark about a few things and we talked for a while. He took me around the shop to show me what they were working on. Mark is a OK guy in my book!!
pro99 is offline   Reply With Quote
Old 07-20-2007, 02:02 PM   #12 (permalink)
Diesel Addict
lakelife79's Avatar
For you guys that are running the TST in the affected trucks do you notice your EGT's going out of control? It kind of makes me worry a little even though I have a 12/05 build motor. But on the other hand I havent seen my EGT's go above 1350 for more than a few seconds. I hope they can figure out what the issue is.
07 3500 DRW Mega Laramie, S300 over S400, BD Intercooler, Goerend Tranny with Billet Flexplate & Shafts, Smarty, FASS 150/150, C2 Gauges, Flux 2's, Stock CP3, Coolant Bypass, T&C Diesel Modded Rail, Hamilton Cam, Pushrods, Springs, and ARP Studs. Dyno 2/21/09 - 676hp 1445tq
lakelife79 is offline   Reply With Quote
