Wicked's Stocker/S474 + 120's = Good Setup??? - Page 5 - Dodge Cummins Diesel Forum
post #49 of 58 (permalink) Old 04-20-2010, 08:35 AM Thread Starter
Originally Posted by PatrickCj View Post
nice! How long did it take for the install?
Well it took us 8hrs, but that's only because Murphy's Law was in full effect I'm pretty sure that we misplaced every bolt and every tool in the garage at least five times I tore an O-ring on the second drain line while placing it in the block and had to go to the hardware store to get another one.....that alone took an hour. We just made a bunch of stupid little mistakes that we wouldn't make the next time around. I'm confident that the next time we could have everyting together in about 5hrs.
I just want to make clear that all the mistakes were on my end. Like I said before, all the parts in Shane's kit fit exactly where they were supposed to fit
Originally Posted by jsf350 View Post
SOOOOO glad everything worked out good---
It's also good to hear some people listen to advice........... i'm glad you did.. you willl be smiling for a long, long time.
Yeah Joel, I pretty much decided on this compound kit because of all the great things you had to say about it. I want to thank you for the great advice and taking the time to answer my questions as well
2005 4X4 NV5600
Mumau Diesel, MPI 62/475, HPTuners by ATP, ATS Dual Cp3, 75% EH nozzles, GDP Fuel Boss, SouthBend DD 3250, Hamilton 110# springs, ARP. 668hp/1205tq (6-26-10)
GhostRider7 is offline
post #50 of 58 (permalink) Old 04-20-2010, 09:02 AM Thread Starter
here are some pictures
I sent my stock turbo to Shane and he worked his magic on it
Here's a couple pictures of the S474
Side by Side of both turbos
Finished Product
2005 4X4 NV5600
post #51 of 58 (permalink) Old 04-20-2010, 10:44 AM
Motorsport Diesel's Avatar
Alot of guys like to over do things, a properly matched setup will provide better day to day performance to satisfy most of those thinking they need more.
The HE351/S400 compound kit is super nice performing setup. When you match it correctly in a package with our Level 3 CP3 and our 120 nozzles it is a proven combination, that does not break the bank and is a joy to drive. We have done several of these same packages, all the customers were ecstatic with the performance the setup provided. They are reaping the rewards of better fuel mileage and a longer living engine due to reduced egt's as well.
Jesus Saves John 3:16 I once was wicked, but now I am saved
Real common rail goodies that you can't get just anywhere/2200 bar pressure relief valves that flow huge volume/2200 bar rail pressure sensors/ Exergy injector services/ CP3 pumps from daily drivers to single pumps over 1200 hp potential (for real)/ custom high pressure manifolds with multi ports for relief valves and sensors/Engine parts and more
[SIGPIC][/SIGPIC]
Motorsport Diesel is offline
The Following User Says Thank You to Motorsport Diesel For This Useful Post:
GhostRider7 (04-20-2010)
post #52 of 58 (permalink) Old 04-20-2010, 10:52 AM
Shane do I need to send my factory turbo to you before you get done with my set?
Thanks, Randy
99 2500 QCSB
IAFF Local 706
firemanram is offline
post #53 of 58 (permalink) Old 04-20-2010, 10:58 AM
Thanks, Randy
We offer the service that we did to smoke19d's turbo, as we have several others. We remove the covers, clean and coat the turbine housing, slick up the compressor cover and coat it, enlarge the wastegate port and reassemble with the correct clocking position. It takes about 4 hours of shop time to do it all.
[SIGPIC][/SIGPIC]
post #54 of 58 (permalink) Old 04-20-2010, 10:58 AM Thread Starter
The EGT drop is beyond impressive, I don't even need to watch my guage anymore. I'm actually learning how to drive the truck again because I find myself downshifting to keep my EGT's in check whenever I no longer need to do so.
2005 4X4 NV5600
post #55 of 58 (permalink) Old 04-20-2010, 12:30 PM
Oh ok cool that's not bad at all. This is killing me because I'm saving up for a kit right now then tax times comes and kicks me back down.
How much does this cost to do? After doing all this to the turbo is an external gate just a waste of money? I was going to do my kit with a tial 44mm waste gate I talked to you about it before and you said I could send it to you.
04.5 2500 4x4 qcsb sport laramie, built 48re, BD flexplate, Goerend triple disc 900/400, pxrb, fte resonator, hushpower, Optix, Airdog II 165, Smarty tnt, Quad X2, Ride-Rite, Spool aid, S&B elbow & intake box, GDP Air Boss intake plenum, 285s.
PatrickCj is offline
post #56 of 58 (permalink) Old 04-20-2010, 06:31 PM
A Couple Diesels
jsf350's Avatar
I'm so HAPPY for you!!!
I want a ride some time!
8hrs for install -- very good-- pretty much what it took me (esp never doing it before)
Finished Product
looks real good........ SOOOOOOOO how easy is it to roast the tires now? dont even have to think about it- do you? lol
one suggestion(s)- manifold blanket and turbo exhaust blankets and maybe connector pipe blanket
IMHO- while alittle PITA to put on- for under $300 the heat reduction is incredable ! I can race my truck (6 hot laps) and still be able to put my hands on the manifold/ around the exhaust housings without any worries of being burnt.
levi is a good guy- ( get the black colored ones- they hide the oil/dirt better)
Turbo Performance Products
ps- Shane nice work- glad i could steer him in your direction
00 F550 TN BB,
03 2500
06 Dodge 2500 DPC-11, 3rd place
06 2500
04 2500-
jsf350 is offline
post #57 of 58 (permalink) Old 04-21-2010, 07:48 AM Thread Starter
Hey Joel I'll give you a ride sometime only if you give me a ride in your monster some time too By the way congratulations on breaking into the 11's!!
Tires go up in flames at will
I'll check out those blankets, I actually just burnt my hand yesterday while adjusting the wastegate on the secondary
2005 4X4 NV5600
post #58 of 58 (permalink) Old 04-21-2010, 07:52 AM Thread Starter
Nope, it wasn't bad at all. Good luck with saving up the money because you're gonna love them when you finally get them
2005 4X4 NV5600
