Turbo or tuning problem? - Dodge Cummins Diesel Forum
 1Likes
post #1 of 16 (permalink) Old 04-12-2017, 01:11 PM Thread Starter
I have recently added s369 1.0 turbo, 100% nozzles, and PPE dual kit, push rods, valve springs. Had my local diesel shop add the parts and EFI live tuned. Now my cruise and light throttle surges. My cruise is completely useless. And said my truck should be around 750hp mark. When buying all this I was aiming for 900-950 max effort?
Dashz28 is offline
post #2 of 16 (permalink) Old 04-12-2017, 05:50 PM
Dom_c13b's Avatar
Tuning issue's, no doubt.
2006- s369sxe, 188/220, Big valve head, BD100%'s
facebook.com/TenacityTuning
Dom_c13b is offline
post #3 of 16 (permalink) Old 04-12-2017, 05:51 PM
Is boost surging? Is it gated? Is local shop a reputable tuner or a guy that bought a V2 and now he are a tuner?
06 QCSB Laramie 2500 4x4: EFI Live by Anarchy.CSP5 by Anarchy.Edge CTS. H-11 Head Studs. 75% over Injectors Direct Injectors. Sinister Diesel 5" exhaust. Full Billet Trans. FirePunk VB Manton push rods. Hamilton valve springs. Custom 63/75 compounds.....Next???
mellowme is offline
post #4 of 16 (permalink) Old 04-12-2017, 06:35 PM
Eric-07's Avatar
Sounds like tuning to me.
I had something similar in one of the first set of tunes I was sent. Told my tuner about it and the next set of tunes was good to go.
2007 5.9 MC - AIRDOG, AIRLIFT, ARP, AUTOMETER, BANKS IC, BILSTIEN, BMS 100's, CPP 103# SPRINGS, DPS 62/475, EXERGY 10mm, EFI Live by GORDON@INNOVATIVE DIESEL
, POWER DRIVEN DIESEL TRANS
, MBRP, MOTOMETAL, PRO COMP, TOYO R/T, SUPERGLIDE 3600, FUZION 5'R
Eric-07 is offline
post #5 of 16 (permalink) Old 04-12-2017, 07:03 PM Thread Starter
It's a actually shop here that was suggested but I have been unhappy with there costumer service also. Boost dosnt seem to jump. And turbo is ungated.do notice is really smoky but figured that's with the injectors and turbo combo
Dashz28 is offline
The Following User Says Thank You to Dashz28 For This Useful Post:
v10sport (04-15-2017)
post #6 of 16 (permalink) Old 04-12-2017, 07:17 PM
I would have to go with the others and say its your tunes. EFI live should get most of the smoke out if tuned properly. Haze is a different story but a good tuner on a street tune should be low smoke at least after the turbo is lit. So I have to ask how quick can get boost out of that 69? I am running a 63 in compounds and while its not making real power its making boost by 1500 rpms I drug it down to 1400 RPMs in OD the other day and still had 3 PSI boost going up a hill.
mellowme is offline
The Following User Says Thank You to mellowme For This Useful Post:
post #7 of 16 (permalink) Old 04-12-2017, 07:49 PM
Dom_c13b's Avatar
I can be at 15psi by 1600rpm with my 369, I've got a .91 housing though.
Dom_c13b is offline
post #8 of 16 (permalink) Old 04-12-2017, 08:28 PM Thread Starter
My smoke blinds the road on all 5 tunes. And my turbo spools slower than stock but not enough to make me say I need twins. I don't even use o/d. When I tried overdrive and cruise I thought my truck was going to but me in the ditch from the surging lol
Dashz28 is offline
post #9 of 16 (permalink) Old 04-12-2017, 09:29 PM
You said 100% nozzles did you put big nozzles on old bodies? Also what fca are you running in the top pump is it a dmax fca or a cummins fca
06 laramie mega debadged 5'' tbe, s&b cai, gdp 5.9 airboss, ats arcflow, airdogII 165/w beans sump, isspro gauges,arp 625's, firepunk comp2, hamilton 103's,extreme duty push tubes,ED/S&S 100%overs,ats duel pumps, efi by Gordon, SD 5 blade compounds on the way
cux211 is offline
post #10 of 16 (permalink) Old 04-12-2017, 09:40 PM
Dom_c13b's Avatar
huh, my small tune produces about 360hp at the tires and drive pretty clean. Slight haze and will smoke if you get under the turbo and punch it but comes out of it quick. Certainly not stock spool but not bad at all.
Dom_c13b is offline
post #11 of 16 (permalink) Old 04-12-2017, 10:00 PM Thread Starter
No my nozzles are but on 90hp body's
Dashz28 is offline
post #12 of 16 (permalink) Old 04-12-2017, 10:07 PM
That's pretty good. I have the .91 housing on my 63 as well, but I am still on stock air tunes with one CP3 and 75% overs tuned way down and my gate is rough set. I would like duel fuel before I buy new tunes and need gauges to tune the gate, but saving my money for an online business right now. I am also far smokeyer than I would like to be but I know why mine smokes! Drive it easy and all is well.
The idea of compounds is not faster spool its more air on higher RPMs. Spool on the bottom should not change much if at all.
Good catch I totally missed duel fuel!
mellowme is offline
