turbo lab exhaust housing - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 02-26-2017, 08:05 PM Thread Starter
sven's Avatar
I tried to do a search but came up empty, does anyone have any experience with this upgrade? My biggest question with this housing being they do not say if it's still a 9cm housing or a 12. I am planning on using the he351 in a compound setup with a s475/83/1.1, just second guessing on going with a s300. any help is appreciated.
HE351 Exhaust Housing Upgrade | Turbo Lab
01 Sport QCSB, 55 block, nv5600 w/Fast coolers, valair org dd, fass 150, AFE S2si, CFM+,dap 7x0095 sac, hx40/35, EJWA, Timbo APPS, AFE blade runner, PacBrake PXRB, 5" exh, leveled, 285s, Titan Machine 3rd gen trackbar, 08.5 steering, fox stabilizer, redhead box
sven is online now
post #2 of 13 (permalink) Old 02-26-2017, 11:04 PM
Subscribed.
2007 Ram 2500 crew cab, long bed, 4x4 5.9L, Firepunk EFI live and Towmaster 48re, Straight piped muffler, 2um Cat filter 10um water, separator on frame rail. Steering box brace
BRBurns is offline
post #3 of 13 (permalink) Old 02-26-2017, 11:48 PM
I have been looking at this upgrade also. Anyone?
07 3500 MegaCab 5.9,CAI,BMS 50hp inj,SpoolAid,AFE3.5" intake,AFE SS exh,Snow stage 3,smarty SSR UDC
3"lift,5"dual exhaust,Wicked Wheel,BD Triple disc,Billet shafts,BD stage 4,DNJ,BD VB,DD pan,Fass150,8an line,Twin fuel filters,Traction bars.
Smoksho is offline
post #4 of 13 (permalink) Old 02-27-2017, 12:20 AM
fatgraderman's Avatar
Looks to me like 9cm machined for the larger turbine. That's fairly common. You WILL have to use the 76/67 turbine wheel/ shaft to use that housing though. Stock 351CW is (I think) 65/58.
07 5.9, stock other then EFILive- but just until I win the lottery, THEN LOOKOUT!
Sent from a deserted island via a note in a bottle
fatgraderman is offline
post #5 of 13 (permalink) Old 02-27-2017, 06:45 PM Thread Starter
sven's Avatar
so I talked to turbo lab today and it is still a 9cm housing with an hx40 turbine wheel, so my next question is combine it with some porting have I gained anything? there will be a gain in the ratio size between the turbine and compressor wheels.
sven is online now
post #6 of 13 (permalink) Old 02-28-2017, 09:09 AM
I think so- but I'm guessing here. My only experience with this is a friend of mine got his rebuilt with the 351ve wheel and housing machined to match. It was mentioned to me on here by ah64id so I passed it along and he tried it. He can stay in the throttle a lot longer then I can with my stocker, but his is a DRW w 6 speed, mines 3/4 auto. Not a direct comparison. The 351ve wheel is 70/65 I think.
I didn't know the 76/67 was an HX40 wheel. More common was 76/64. The 76/64 wheel with your compressor would basically be a Super 40 with a quick spooling 9cm housing. THAT I can kind of wrap my head around. I wonder if the 76/67 might be a hair too big. I wonder if guys going with that big of wheel are upgrading the compressor at the same time.
I really don't know the first thing about twins. If you slow spool too much on your stocker, will it still match up with a 475 in a 1.1 housing? It's different when all you are doing is drilling out the wastegate- there no money involved. But this will cost you a bit. And the s300 has a hair bigger shaft to boot. I might lean towards a 360 or 362. But that's all just guessing on my part.
post #7 of 13 (permalink) Old 03-02-2017, 02:50 PM
Ducati M.
DMan1198's Avatar
I measured an he351ve turbine wheel the other day at 70/59, and an h1c turbine wheel at 68/60. I have a couple of hx40's I should take the time to measure.
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
v2 Finally doing stuff
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
Instagram:
DMan1198 is offline
The Following User Says Thank You to DMan1198 For This Useful Post:
fatgraderman (03-02-2017)
post #8 of 13 (permalink) Old 03-02-2017, 03:53 PM
promisedlandorganicfarmer's Avatar
Thanks,
I have the 351ve turbine wheel called 70/60
2004.5 3500 4x4,srw,lb,qc, 3.73-33''tires, 48re-Trans-Go/Goer. 3dTC,3 fuel filters, SmartyTouch w/ UdcPro, BBI-.05, MIT&ProGard7, Arc-Flo, Garrett Powermaxx S2, ATS mani, 4"Flo-Pro t.back exh. 24''muff & 30''Fte res., 4th gen seats! Matthew. JESUS IS LORD!
promisedlandorganicfarmer is offline
post #9 of 13 (permalink) Old 03-04-2017, 04:33 PM
Ducati M.
DMan1198's Avatar
So I took the time to measure my hx40 turbine wheel, and it came out at 76/64.
Instagram:
DMan1198 is offline
fatgraderman (03-04-2017)
post #10 of 13 (permalink) Old 03-04-2017, 05:11 PM
Originally Posted by promisedlandorganicfarmer View Post
Thanks,
I'm probably wrong which one is on Al's truck then. It would likely measure what you guys found. It seems to have cooled it down a bit and if there's any difference in spool, it can't be much.
post #11 of 13 (permalink) Old 03-04-2017, 05:37 PM
Ducati M.
DMan1198's Avatar
I really want to swap my wh1c turbine wheel for my he351ve wheel now on my hybrid to see what difference it makes. Based on my rudimentary testing it'll be a direct swap, and it actually felt slightly lighter than my h1c turbine, and shaft.
Instagram:
DMan1198 is offline
post #12 of 13 (permalink) Old 03-04-2017, 06:03 PM
Seeing as how you chimed in, any of those options make sense being as how he's building compounds? I wondered if a 76/67 might be a little on the slow side when mixed with a primary that's 83/ 1.1. But I'm not versed in twins at all.
