HPtuning controllers failure - Dodge Cummins Diesel Forum
 1Likes
post #1 of 62 (permalink) Old 01-05-2017, 10:47 PM Thread Starter
I am trying to program the tunes that I have purchased from Firepunk. And having 1 heck of a time. The computer and controller will erase, load, and then after the program has loaded it gets the final test and gives the failed in red. I have tried more times than I currently have patients for. The truck will run for 1 second after I try and start it. Yes I know the program is loading a failure. But I'm up against a wall. Need the truck to get to work in the AM. Can't load the original program that I saved before I sent the base tune to FP.
What am I doing wrong? is the voltage on the truck that sensitive? It is about 30* outside.
04.5 CC SB 4x4, Garmon stage 2 trans, HPT tuned by Firepunk, GDP walbro pump with 2mic filter set up. BMS 50 injectors.
Home made traction bars that are awesome.
jballou is offline
post #2 of 62 (permalink) Old 01-05-2017, 11:23 PM
TECH SPECIALIST
steve05ram360's Avatar
do you get any message on the download window?
I get a timeout error if the batteries are not 100%... with that said I wont start a download without it being fully warmed up
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP injectors, 328k, HPTuners, G56, mpg threads ->
steve05ram360 is offline
post #3 of 62 (permalink) Old 01-05-2017, 11:36 PM Thread Starter
Thanks Steve! I have the battery charger on the truck now. The time out error happens at the very end of the loading. Hopefully its the batteries. This wan't talked about in all of the forums. Unfortunately the truck won't run now that I can't load a program, so no way to warm it up. Other than make sure the batteries are charged up. Never had this be a problem with the Smarty.
jballou is offline
post #4 of 62 (permalink) Old 01-05-2017, 11:42 PM
TECH SPECIALIST
Yeah, batteries... I had mine happen in the middle of a load 3x, everytime the motor was cold or not run that long. I ether download when I get home from work or take it for a good long spin for coolant temps to reach 190~195 before attempting a download. Last one I did up here was under an overpass and it was 25*f out.
Try the charger for a bit, then re-try. Also, pull the relay for the fuel pump before the download. You'll get a CE light but you can clear that after it's done and re-installed if you have the VCM scanner. Mine is the front left relay in the fuse box
Also, what part of the PNW are you in?
The Following User Says Thank You to steve05ram360 For This Useful Post:
jballou (01-05-2017)
post #5 of 62 (permalink) Old 01-05-2017, 11:46 PM Thread Starter
Yeah, on the charger as I type. Will pull the relay for the fuel pump. It's cold for us up here in Kingston. Never got above freezing here at the house. Thermometer says 26* right now.
jballou is offline
post #6 of 62 (permalink) Old 01-05-2017, 11:48 PM
TECH SPECIALIST
Your not that far... LMK if you want help...
OH and I am not sure I would attempt a download with the charger on there... in case that thought crossed your mind.
post #7 of 62 (permalink) Old 01-06-2017, 12:21 AM Thread Starter
Charger when downloading is a big no no with all of the systems. Thanks for the reminder. Might have to take you up on some help if I can't get it going tonight.
jballou is offline
post #8 of 62 (permalink) Old 01-06-2017, 12:52 AM
TECH SPECIALIST
roger that... pm sent
post #9 of 62 (permalink) Old 01-06-2017, 10:58 AM Thread Starter
Well this am the battery was charged all up. And it does the same thing. Acts like the VATS won't give the proper signal. The file goes to clean up, and then closes. Gives a red failed. Try and start truck runs for 1second and shuts off. So I'm at a loss, and got a ride to work. Will have time to try it again in 2 days.
jballou is offline
post #10 of 62 (permalink) Old 01-06-2017, 11:48 AM
TECH SPECIALIST
Contact HPT plus your tuner and see what they say
post #11 of 62 (permalink) Old 01-06-2017, 07:43 PM
cerberusiam's Avatar
Pull the batteries out and take them inside to warm up over night, cold batteries are not going to hold a charge. The first thing the FSM is going to recommend when flashing is hook up a battery charger, the system requirements will hose a flash if things are not perfect. Flashing thru OBD port is iffy anyway and ANY slight variation in power is going to fubar the checksum. Try warm batteries and chrager hooked up to se eif that helps. If it doesn't you have a bad file, it happens.
cerberusiam is offline
The Following User Says Thank You to cerberusiam For This Useful Post:
jballou (01-06-2017)
post #12 of 62 (permalink) Old 01-06-2017, 08:01 PM Thread Starter
I did talk to the guys at Firepunk, and Lavon has had this happen before. He just kept trying to flash and finally had success. I did it 20 times and the same result. I do wonder if the VATS or SKIM module has forgotten the base program when I have flashed it. It acts just like when I have used a standard key. Stops running after 1 second, it will do it twice and then never again.
Knowing full well that the modules haven't accepted the new program could be why it won't run.
jballou is offline
