| 3rd Gen. Performance Parts Discussion Discussion of Performance Parts For the 3rd Gen Trucks No Advertising ...NO ADVERTISING |
Am I safe to run Edge Ez on #3 for Daily Driving?
I know this has probably been beat to death, But a quick answer would be greatly appreciated. I have an 06 CRD with the G56. Cat delete, K&n filter and ATS arc flow air ram. I am not a hot rodder but want a little more goose. I have been running #2 except while towing. Are there any adverse effect running #3 to any parts(ie Lift pump, Fuel rail, Injectors)? Thanks so much, and yes I know that Smarty is the answer, just keeping what I have for now. Lusty
2006 Quad Cab 4x4. DRW, 5.9 Cummins, 6 spd. Cat delete, Magnaflow Muff, Baldwin pf7977, Ranchhand. Edge box and ATS Arc Flow. |
#2 (permalink) |
Virginia Chapter VP
![]() Join Date: Nov 2008
yes you will be fine, just dont romp on it all the darn time, just be cautious
04 2500 (Hannah) 4x4 w/ 6 speed manual; silencer ring removed, K&N air filter, smarty level 7, banks gauges, FBD 5" straight pipe exhaust, Airdog 150, Buckstop classic front and back, Warn 16.5ti winch
#3 (permalink) |
I am a pretty easy driver. I shift at 2600 religiously. Every once in a while I shift a little higher. Is that what you meant? I know some guys that drive hard shift at 3k all the time.
#4 (permalink) |
I usually shift at 15-1800 but I guess I'm lame! lol
04.5 2500 QC 4x4 6 Speed Bushwhacker Flares 285 Cooper Discoverer STT's Some sort of black eagle wheels
#5 (permalink) |
Just don't expect your injectors to last as long with the ez up all the time. personally I would get something different that changes timing, fueling rather then pressure. As long as the fuel is clean you should be ok for awhile. If you don't have better filtration I would get it before I turn the ez on at all.
04.5 Crew Cab Dually- Industrial 100 hps injectors, Silver Bullet 66-74-14, AFE horn, AFE Intake, EEP relief kit, Silverline 4", Fass 150, SB 3600 DD, 2nd NV56, PacBrake, TNT-R, Hamilton 110# , ARP studs/ 10-30-09 Mustang dyno 613 hp / 1230 tq |
#6 (permalink) | |
![]() Join Date: Jun 2007
'07 2500 5.9L Mega, Black, Laramie, 4X4, 48re Isspro's, AFE Pro Dry, BMK-11, AMSOIL fluids, Debadged, CFM+ S-06, Mag-Hytec Covers IAFF Local 1159
#7 (permalink) |
Edge recommends level 2 or lower for daily driving. Level 1 for heavy towing.
2004 2500 SLT SWB 4x4,305/555, in-tank lift pump, 48RE, 3.73, westin cps step bars, magnaflow pro 4" TB, 305/65/17 BFG AT KOs,Timbrens, Leer Cap, Firestick CB antenna mounts, Wilson Silverload 5' antenna, Uniden PC78LTW CB |
#8 (permalink) |
Former Staff Member
![]() Join Date: Feb 2006
Just wire it up for incab adjustment
Corey Ritter - Amity, OR '04 Patriot Blue SRW 3500 QC 4X4 Laramie, 6spd, HO, Edge EZ, TST PowerMAXCR, Smarty, SPS 66, Rip's 4", AFE PG7 W/torque tube, FASS 150, Superlift leveling kit, Ride Rite's w/onboard air, Line-X. Torklift camper tie downs, fuel vent mod, CB, GPSmap 168, Buckstop/Warn 12,000 lb, KC Daylighters, MTL w/prolong in trans, Haisley DD, DiPricol gauges and Quad Commander. 77K 513/1043 Fast Specialties DDD 4-15-2006 TST-EZ stack, Quickest 1/4 mile ET 13.949 @ 96 MPH @ PIR Hauls Lance "Lite" 1025 @4klbs Wifes truck '98 Intense Blue 12V QC LB 4X4 Auto |
#10 (permalink) | |
#11 (permalink) |
I keep all my stuff cranked up all the time and no issues...wait mine has been blown up twice and the truck only has 70k so prolly not to smart to take my advice
04.5, Valair Clutch DD 3600, Smarty TNT, Quad X2 w/Race Tune,II BOP,Quad Com., Lazarsmith Traction Bars, Rapter150,Glowshift Fuel Psi, Boost, EGT/ 13.25 @ 103.4. 543.9hp 1080.7 Currently Blown up again getting rebuilt soon |
#12 (permalink) |
Super Administrator
![]() Join Date: Jan 2006
Agreed, I would not DD on level3. Your injectors will hate you for it.
![]() 03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph) July 2009 Cummins Forum ROTM Winner 95 1500 Sport 2wd Cummins Drag Truck under construction. "In search of the Magic Dyno"
