Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 11-06-2009, 06:55 PM   #1 (permalink)
madtrucker66's Avatar
Getting to the 12's ????
OK I have looked on the Fourm for a while about what Hp/Tq you need to Break in to the 12's
I want to build the truck over the winter to get there and need to know what Kinda power Im going to Need.
Im going to Run the 64/71/13,Snow stage 2, 90Hp sticks. and a smarty with what i have in my Sig.
Also a Fass 150, and MAybe a Bag o parts for the Pump. what do I need to Change or add to get there I dont care if its the high 12.99 Just want to get there,
Madtrucker66 2006, 2500,quad.4x4 short box Str-8 with 6" tip. Edge-Att-hotlink.Mp-8,Volant intake, Air Force one Intake Horn.Blacked out lightsSome tranny Modds.
madtrucker66 is offline   Reply With Quote
Old 11-06-2009, 08:00 PM   #2 (permalink)
BDekle's Avatar
I would go with a quick spooling set of twins, ditch the snow, get an 85% pump and 150's.
03 3500 4X4 Laramie Quad LWB NV5600. Smarty, TS MP-8, AFE Stage 2 Si, Airdog 150, Arson Kit, Valair 3600 DD, ISSPRO Performax Pyro, Boost, Drive Pressure, Fuel Pressure, Rail Pressure, 7" Black Mitre
BDekle is offline   Reply With Quote
Old 11-06-2009, 08:22 PM   #3 (permalink)
I'm going to run the 64 I'm getting it from a buddy for a Killer deal. So I dont think I'm Twins on this truck maybe my next... Think i can get there with the 64?
Old 11-06-2009, 08:24 PM   #4 (permalink)
BDekle's Avatar
Maybe with giggle gas..
Old 11-06-2009, 08:24 PM   #5 (permalink)
BDekle's Avatar
You're gonna need more and and more fuel than those mods with provide, IMO.
Old 11-06-2009, 09:06 PM   #6 (permalink)
Sandaholic's Avatar
I think you could do it with the mods you listed Heck if I had a 64 and some 90-120 horse sticks I think I could break into the 12's.
You've got a lighter truck and an auto to boot
05' QCLB 4x4 NV5600,Spec DD clutch,S-06,5" TBE 6" aussie, airdog 150,modded fuel can.,CAI, techni-cooler,mag hytec rear diff. cover,6" lift on truck and fifthwheel,firestone airbags,16gal. of 200 PSI OBA 421HP/1009TQ moves 8000lbs to a 13.88@97.05 SSW
Sandaholic is offline   Reply With Quote
Old 11-06-2009, 09:24 PM   #7 (permalink)
If the rain well let up I get them Installed I have some of the parts just sitting waitting.... The 64 should be here soon....
Old 11-06-2009, 09:33 PM   #8 (permalink)
joelc79's Avatar
your close, do you have a lock up switch? if not get one!
03 1TON currently broken
joelc79 is offline   Reply With Quote
Old 11-06-2009, 09:52 PM   #9 (permalink)
I Dont have one but Im looking to get one later on.. Is Elc or Manual better?
Old 11-06-2009, 09:55 PM   #10 (permalink)
devildogcummins's Avatar
Its not 12s but I ran a 13.01 with smarty, AFE intake, Mbrp 4inch exhaust, Fass, Built tranny, Silver Bullet, had ranch hand bumpers and 35in tires, I think its very possible to get in the 12s with mods u listed
07 5.9 2500 qcsb 4x4, 664.9 hp 1200+tq
devildogcummins is offline   Reply With Quote
The Following User Says Thank You to devildogcummins For This Useful Post:
madtrucker66 (11-07-2009)
Old 11-07-2009, 12:22 AM   #11 (permalink)
NMMEGA's Avatar
you should be there if your tranny mods are up to the task. at 5200ft elevation i am at 13.58 with a smarty TNT, airdog 150, and HTS tranny. stock turbo, stock stix, stock cp3. 100k miles on the ticker. i also agree about the lock up switch. again, if your tranny is up to it.. good luck man. that's where i wanna be next year also.
red 06 mega with some black spray paint and a basketball hoop in the back.
southwestcoalrollers.com
NMMEGA is offline   Reply With Quote
The Following User Says Thank You to NMMEGA For This Useful Post:
Old 11-07-2009, 04:47 AM   #12 (permalink)
fordassassin's Avatar
At 5,500ft. With a 64/71/13 , Flux 3's, stock CP3, Smarty/EZ, Walbro 392 lift pump.
I made 598.71 hp and also did 12.4 @ 107 , 12.5 , 12.6. Smarty was only on level 4 and EZ was turned up to level 3.
Remember, the 03-04 trucks need bigger injectors to compete with you 04.5+ trucks.
Also, I had a lock-up switch. MANUAL SWITCH is way better, since you can control it.
Early 2004 that has a 120 speedo.Not doing anything Dodge didn't want
http://www.youtube.com/user/gooodyboyz559
fordassassin is offline   Reply With Quote
The Following User Says Thank You to fordassassin For This Useful Post:
