Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 11-05-2009, 02:32 PM   #25 (permalink)
MELEX's Avatar
I think it would be nice if a rep from Mads would chime in. I read the instructions and have taken the position that the default settings are just fine because like everyone else I think the instructions are too confusing. It would also be nice if we understood exactly what the settings do. Tell us in real world language. Example: More timing decreases power and lowers egts. Or whatever it does.
04 2500 4X4 Auto w/ BD TC, VB, Torqloc, and Mag Hytech deep pan. FASS 150, BD Super B turbo, Smarty Jr., Dr. P 2018, Green intake, Hushpower muff, Isspro gauges, air bags, leveling kit, BW turn over ball hitch. ARB Front bumper as a result of the accident.
MELEX is offline   Reply With Quote
Old 11-05-2009, 07:26 PM   #26 (permalink)
I agree, I am seriuosly concidering purchasing a JR but now i am pretty confused.
07 2500 5.9L 4x4 QC/SB Auto \\\ AFE Stage 2 W/ Prodry, Silencer Ring MIA, more to come...
RobertEvans is offline   Reply With Quote
Old 11-05-2009, 09:09 PM   #27 (permalink)
2500 Cummins's Avatar
Originally Posted by HOD-ISB View Post
Depends on the version of the software you have:
version 5.07(pre POD)- timing 4, torque 2
version 5.08- timing 4, torque 4
version 5.09- timing 4, torque 2
version 5.10- timing 4, torque 2
This is the most powerful and responsive settings for each version. This is also the most powerful settings for each power level. It is important to note, however, if you have ever had version 5.08 and updated to another version some people (myself included) have found that the truck must be set back to stock and then reprogrammed for the torque management to be "fixed".
Well there you go then. That explains my response of 4 and 4. I have version 5.08......
I knew those settings felt the strongest.
06 Ram Quad Cab 4x4 5.9 48RE w/3.73 and Smarty Jr.
Isspro Gauges-Pyro, Boost & Tranny
06 Keystone Cougar 31' Fiver & 02 Crownline 202BR
2500 Cummins is offline   Reply With Quote
Old 11-06-2009, 12:29 AM   #28 (permalink)
Originally Posted by pluguglyinhere View Post
I am in the confused crowd and do not know who to believe anymore.
I have another question though, I saw there was an update available, 5.10 and I have 5.09. So should I update every time there is a new version or what?
It depends. When you see and update read the reason for the update. 5.10 is for a compatibility issue and has nothing to do with you or I.
Bob has chimed in many times in the past and there are many threads with very informative dialog along with some dyno results. The problem is there is a new thread like this every other day on several forums and Bob is a very busy man. If you will take the information that I gave and combine it with the Mads instructions and do some experimentation you will find the conglomeration very accurate.
Hope this helps ! If not I'll be glad to try and answer any questions that anyone has.
2006 3500 SRW MC g56 4x4 Laramie / Isspros (FP, EGT, Boost) / GDP MK-2 micron fuel filter / severely allergic to cat & EPA / Smarty Jr 5.09 SW2 Tm4 Tq2 POD45
HOD-ISB is offline   Reply With Quote
Old 11-07-2009, 02:31 PM   #29 (permalink)
MELEX's Avatar
Do you know the specific posts that will help? I would like to see them, especially the ones with dyno #'s. I would like to compare my mods and see if I can come up with approx #'s. I looked and I have the 5.8. Do I need to update? If so I assume the update is found at the Mads page. I would also like to figure out why my egt's are higher than most. Especially since I am running a larger turbo.
Old 11-07-2009, 03:30 PM   #30 (permalink)
What is the download site again? I have the very basic version, no timing options. Will the 5.6 allow me to tune in even more timing?
2007 4X4 QCSB 5.9 Gutted intake, Smarty Jr, muff delete, 285's
cattlepuncher is offline   Reply With Quote
Old 11-07-2009, 07:33 PM   #31 (permalink)
You guys answered my question. My 2006 2500 is stock and I see 17.5 city and on highway ive seen 22.3 on last trip and other trips at at 24.4. I guess if you tow it would be woth it to get a smarty jr? I have 295 70/17 tires.
hogrider09 is offline   Reply With Quote
Old 11-07-2009, 09:04 PM   #32 (permalink)
This question on the smarty is what I`ve been looking for too. I have the quad 65hp towing box now. Is the smarty worth the extra $? Is there really a big advantage over other brands?
banyon is offline   Reply With Quote
Old 11-08-2009, 03:57 AM   #33 (permalink)
Smarty Jr Revo Update
http://www.dieseltruckresource.com/d...d-t209011.html
Post 249 has some dyno numbers
Smarty Jr settings help please!
http://www.dieseltruckresource.com/d...ghlight=Smarty
These should be a pretty good start.
I think so. The torque management/timing adjustability is priceless IMO and greatly improves drivability. The smarty offers lower EGTs than anyone else via dynamic timing which you cannot get from a chip. The POD function is the only one on the market that gives total control over the entire power output. Jr does not increase rail pressure which is very detrimental to injector longevity.
The Following User Says Thank You to HOD-ISB For This Useful Post:
MELEX (11-08-2009)
Old 11-08-2009, 02:01 PM   #34 (permalink)
Thanks HOD-ISB. What about smoke? I don`t like my every day work truck to smoke any more than it has to.
Old 11-08-2009, 07:18 PM   #35 (permalink)
With all the adjustability smoke reduction is fairly easy if you don't mind sacrificing a little performance. I don't care for much smoke either cause all it does is soot load the oil.
Old 11-08-2009, 10:01 PM   #36 (permalink)
BACKTOTHEDARKSIDE's Avatar
Timing #4, TM #2, 100hp setting. Version 5.10
18mpg avg in town
21mpg avg highway
Decent power and almost no smoke whatsoever, TC and VB soon to follow should make this a reliable DD.
Question: Will this setting be good for towing 4-5k
2006 MEGA CAB 2500, Smarty Jr, K&N Filter.
BACKTOTHEDARKSIDE is offline   Reply With Quote
