- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 3rd Gen. Performance Parts Discussion Discussion of Performance Parts For the 3rd Gen Trucks No Advertising ...NO ADVERTISING |
#13 (permalink) |
awsome right up i feel a little more confident in doing this new but how do you change the nozzles are they an actual part of the injector if so how do you change them or is there a write up about it like this one because i am seriously considering 40hp nozzles for mine just for fuel economy and a little more power and smoke
2004.5 2500, 2in readylift leveling kit, smarty revo-tnt k&n cold air intake, mia silencer ring, ts mp-8, 100hp schied lighning injectors, fass 150 fuel pump, stacks, 33in courser ct's,and jl audio w7 |
#14 (permalink) | |
GA CUMMINS CREW PREZ
![]() Join Date: Dec 2007
2003 with a few goodies! Engineered by Southern SmokeCLICK -------> GEORGIA CUMMINS CREW |
#15 (permalink) | |
BIG BAD MEGA
![]() Join Date: Nov 2008
Following the prior proceedure, remove the cover ![]() Things are kind of tight in the truck, so take your time especially on #5 and #6, since they are underneath the cowl, tape off the intake hole so no debris fall in the hole ![]() Keep your parts organized and separated per cylinder they came off of ![]() Once you have removed the map sensor and taped off the hole, removed the injector rail lines, removed the connector tube nuts and tube, valve cover gasket and injector wirinng, exhaust rocker and elephants foot, pry the injector out carefully and place the injector in the holding plate that comes in your kit..Clean the injector thouroughly! You cannot afford to have any small debris lingering when you pull the tip off so cleanlyness is a must ![]() Remove the copper gasket that comes out with each injector, make sure you get all 6 so you dont leave one in the head and replace with a new gasket! ![]() Be carefull and take the tip apart. I used a box end wrench since I didnt have a deep socket, plus it gives you a visual on the tip so you dont damage anything, they are torqued to 50ftlbs so it will be kind of a pain to bust apart ![]() The end piece threads off, simply hold your finger on the end of the tip and thread the injector apart and carefully remove the cap. There are 2 little pins on the end that extrude out to line the tip up properly, also there is a little piece in the middle.. dont lose any of these! Your stock tips are going to be dirty so again be giving on the brake cleaner, once you have the tip off, take your finger and hold the little pieces in place and spray around them to clean the area thouroughly...dont let the peices blow out! I lucked out and found a piece that blew out of mine.. im sure they arnt readily available so just take your time and work slow/clean. Mark a special place to put the used tips and install the new ones after confirming that all 6 have the same part # in your new kit, repeat the process in reverse and re-torque the cap to 50ftlbs, some say 55ftlbs.. either will work ![]() Reinstall the injector and re-torque as per the preceedure, reinstall the elephants foot and rocker arm after cleaning and install the rocker bolt and torque up in levels.. I did 10-15-27ftlbs becuase I actually snapped #5 rocker bolt at less then 27ftlbs.. These are grade 12.9 bolts so I cannot explain why it broke but its better that it broke now then once the motor was running. New bolts are available for $3.00 a piece through dodge or you can do like I did and replace it with another 12.9 grade bolt i got from fastenall for $1.99. There isnt a need to set valve lash since the rockers are already adjusted per the adjuster on the arm, just make sure to keep them with the cylender then came off of. Spray out the fuel rail good and clean, and do the same to the injector lines... the smallest bit of debris will cause the injector to fail.. follow the torque specs to a T and just keep clean, work slow and enjoy the fact that you can now do your own injectors without having to go to the dealer! ![]()
GDP | ATS | Industrial Injection | Suncoast | Farmtruck | Wicked | Wal-Mart | Pureflow | TS | Bullydog | KMK Diesel | 303 Diesel ![]() 2006 MegaCab LongBed - 6.2L Cummings
| The Following User Says Thank You to Giddyup5.9 For This Useful Post: | TEX (11-08-2009) |
#16 (permalink) |
This was done by sag2 on TDR!
Injector install procedure with photos - TDR Roundtable
2003 HO 3500 SRW QC, DTT 48RE,BD R700 Twins, Formula 1 Injectors, GDP Fuel/Intake Horn, MBRP 5" T/B EXH, Dipricol Gauges (TST/EZ/Smarty 411) 622.80 hp 1147.98 tq 08/23/09 Spokane Diesel Thunder
#17 (permalink) |
ok 1st thanks
2nd i can understand the bud light and shiner but........ 3rd the right guard?? guess you were tryin to "keep everything clean" and smellin fresh LOL thanks again bud
2006 Mega 3500 DRW 4X4 G-56 SLT Optix EGT,Boost,Trans-4510/Cool hose,Hushpower, BMK-11 Q-Zilla Max Mileage.....2008 Keystone Copper Canyon 298FWBHS W/Pull Rite Super Glide 16K Wake Up America |
#19 (permalink) |
![]() I was thinking the same thing! Plus its half opened. He must of been drinking his soup eating his beer and putting Right Gaurd on his parts.
06 3500 drw 4dr 4x4 auto Laramie, Isspro's, 5'' TBE, Suncoast tripple disc& vb,K&N cai Super B Special, AD 150,TNT POD,Arson III,BD 90's,607.9hp, 1139.6tqhttp://s288.photobucket.com/albums/l...ynoruns002.flv |
#21 (permalink) | |||
BIG BAD MEGA
''Ive noticed a few threads about injector talk/specs/install and removal. I figured I would help everyone out and post this up as a quick guide for everything. This has helped me and hopefully can help you. Enjoy.'' plus not everyone is a member of tdr Quote:
It was a long night lolQuote:
![]() this was an overnight project for me since the #5 bolt broke, it took me about 7 hours to get it out of the head with a long 90 degree drill extension and a left handed bit.. honestly I was ready to pull the head and be in it for the long haul! I actually made a video pulling the injector apart but at that point when i decided to make a video i was a little.. 'happy' lol, i wouldnt dare posting it up after watching it the next day
#23 (permalink) |
BIG BAD MEGA
Oh it was definatly a hell of a night.. I was on the phone with kenny like dude.... wtf lol
how many times in your life are you going to have to use this, a mirror and 3 magnets to work on a cummins ![]() ![]()
