Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 07-03-2009, 03:53 PM   #1 (permalink)
ffemt1224's Avatar
lost 3 psi of boost with sp boost fooler.
I just bought the SP Boost fooler and installed it but lost 3 psi of boost. I also bought a boost adjustable elbow and noticed faster spool up. I have the watch dog monitor but still only showing 23 psi of boost with or without the elbow but lost 3 psi of boos with the SP boost fooler. Any suggestions or do you think i just have a bad SP product?
2003 Dodge 3500 Cummins, 6 speed, Bully Dog Tripple Dog, K&N Air Filter, Boost Elbow, Sp boost fooler, 6 inch lift sittin on 22.5 rims.
ffemt1224 is offline   Reply With Quote
Old 07-03-2009, 04:12 PM   #2 (permalink)
Over Fueled and Budget
Magic smoke's Avatar
I think you need a mechanical gauge because along with your ecm it is fooling your monitor.
Early 04 3500 drw quad cab-6speed SBC fast coolers - 4x4 -S&B -fass 150-expandit 5"- FTE resonator -SMARTY-autometer C2 full pillar gauges- di-pricol rpg-Dragonslayer cp3-64/71/14-PDI manifold -Wicked 125's - $2 rail cap.
Magic smoke is offline   Reply With Quote
Old 07-03-2009, 11:46 PM   #3 (permalink)
O no U suck
STOUTE's Avatar
yes it is a Boost fooler it is Made to fool the computer with a Low boost number there for makeing the computer give more boost to try and catch up. there for More boost
TOWPIG06 3500 megacab dually 3inch drop in the rear/15" dropdown screen/7" Jvc 2din nav/1 memphis 12/memphis Bell/24" alco"s/s&b cold air/smarty powerpuck stack/str8piped
03 dodge bagged/20's/Z'ed 2 1/2"/ MMW front A arm Kit /7" flip out/Memphis 500/Memphis 10/
STOUTE is offline   Reply With Quote
Old 07-04-2009, 09:02 AM   #4 (permalink)
MikeyB's Avatar
Need to reverse the connections to the MAP sensor. Plug the BD into the MAP sensor first, and then the boost fooler.
MikeyB
'03 2500 QC SWB 2wd, 305/555, NV5600, 3.73 LS, Airbox mod w/Amsoil Ea, Adjustable boost elbow, PML diff cover, Westach boost/EGT gauge, Line-X, Sirius, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake, Smarty/Van Aaken C3.2
MikeyB is offline   Reply With Quote
Old 07-04-2009, 11:07 AM   #5 (permalink)
Local Rotor Head....
ah64id's Avatar
MikeyB
Yep.. otherwise your reading the fooled number.
Enigne -- MAP Sensor -- BD -- Fooler -- OE Plug
ah64id is offline   Reply With Quote
