Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 07-04-2009, 09:08 PM   #13 (permalink)
Cool thanks, TJ
2006 Silverbullet 62, II 80hp stix, Quad X2(pressure only), Smarty(Revo lvl9),ATS ex. manifold,AFE ArcFlow,AFE stage II,Fuel Boss & MK-2,Goerend trans 540hp/1298tq
BigJohnston is offline   Reply With Quote
Old 07-04-2009, 10:41 PM   #14 (permalink)
Danderson's Avatar
My truck has a 4000# rear axle load on it 24/7 due to the camper which isn't all that much. I installed a Mag Hytec@ 9200 miles and Amsoil 75-90 Severe Gear. The stock fluid was jet black and smelled awful. In my case it was worth it.
'07 2500 SLT,5.9,reg.cab.,G-56, 4wd,8' Northstar popup 24/7. Carli,Defiant,Kore,Lorenz and MADS.
Danderson is offline   Reply With Quote
Old 07-05-2009, 04:29 AM   #15 (permalink)
Ok I am getting one for the rear but not sure about the front. I am going to do a suspension system (Core or Carli) with steering stabilizer and Track Bar. Does the front pumpkin spin when in 2wd or does it only spin in 4wd? If it is not constantly turning then I am not putting one on yet. Thanks
2007 Dodge Ram 2500 Quad Cab Laramie 4x4 automatic. No cat w/ 4inch Magnaflow, S&B CAI, S&B Performance Elbow, Smarty POD, Gauges.
Ramming Don is offline   Reply With Quote
Old 07-05-2009, 04:48 AM   #16 (permalink)
BDekle's Avatar
It always spins.
03 3500 4X4 Laramie Quad LWB NV5600. Smarty, TS MP-8, AFE Stage 2 Si, Airdog 150, Arson Kit, Valair 3600 DD, ISSPRO Performax Pyro, Boost, Drive Pressure, Fuel Pressure, Rail Pressure, 7" Black Mitre
BDekle is offline   Reply With Quote
Old 07-05-2009, 04:55 AM   #17 (permalink)
Skrew- EPA CARB OPEC PETA
harvey4804's Avatar
how much of a pain was it to install that front cover?
2004.5, QC, LB, Crapomatic, 4x4 Factory Nav. AirDog 100, Arson Kit, AEM Bruteforce HD, Silverline 5" t409, BMK-11, Mag-Hytec, Bilstein 7100, B&W, Tekonsha P3,DiPricol's
HMX-1 Executive Flight Detachment Avionics Technician
harvey4804 is offline   Reply With Quote
Old 07-05-2009, 08:49 AM   #18 (permalink)
Danderson's Avatar
Front fluid
In contrast to the rear,when installing a Carli diffguard we serviced the front fluid @ 15,000 and it was like new. It spins but unless engaged,it apparently doesn't generate much heat. The diffguard won't fit with a Mag-Hytec.
Old 07-05-2009, 02:28 PM   #19 (permalink)
Ok thanks guys. Did I understand that the PMl clears on the front with a stabilizer? Or is there any aftermartke one for the front that clears?
Old 07-05-2009, 02:47 PM   #20 (permalink)
Smokin5.9L's Avatar
I love my mag-hytec covers front and rear also my front cover doesn't have any clearance issue with my Kore HD leveling kit
05 Dodge Ram 2500
Smarty TNT/R
5-16-2009 618.68hp 1205.06tq
http://s629.photobucket.com/albums/uu16/Smokin59L/
Smokin5.9L is offline   Reply With Quote
Old 07-05-2009, 03:23 PM   #21 (permalink)
I love my Mag-Hytec, I've checked my fluid (royal purple) a few times sence I got it, and it looks perfert every time. Before I get it I checked my fluid a few times and changed it every time, it never looked good.
04.5 1-ton DRW,QC,4x4 Afe stage 2, cfm +, Ats Pulse flow, Mag-Hytec pans, Smarty jr.Revo, Striker1, BD Pressureloc, -6 AN big line, Di/Pricol (egt,boost,FP) ready for 5" exhaust and more. I'll keep my money, my guns and my freedom you can keep the change!
tmshoer is offline   Reply With Quote
Old 07-05-2009, 03:31 PM   #22 (permalink)
I bought my rear Magtec directly from Magtec and the guy told me to not use royal purple bc they were having issues with the Magtec material and RP not getting along. Can't remember the exact reasons but you could give them a call for clarification. Recommended Mobil 1 Synthetic.
2006 Mega SLT - Carli Starter - Carli trackbar - Fox SS - Magnaflow custom dual 4" - K&N Intake - Magtec tran pan rear diff. - PacBrake airbags - Moto Metal w/ 35x12.5x20 Toyo M/T - Smarty Jr.
titan0454 is offline   Reply With Quote
Old 07-05-2009, 04:22 PM   #23 (permalink)
spooled05's Avatar
I've ran royal purple 75-140 for 2 years w/o any problems w/ my mag hytec
05 c/c drw 4x4 full billet DTT,62/71/13ss over s480,PPE duel fueler,hot+2 lite,Flux inj.,studded head,Raptor 150,big line,5"flo pro,mag-hytec dd trans and rear diff,guages
spooled05 is offline   Reply With Quote
Old 07-05-2009, 04:28 PM   #24 (permalink)
spooled05's Avatar
Also has anyone installed a front cover w/ the updated steering?
