Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-UP Common Rail Forums > 3rd Gen. Performance Parts Discussion
Old 05-09-2007, 03:36 PM   #13 (permalink)
JesseRohr's Avatar
Silicon levels were that of the brute force levels. 7ppm
Jesse Rohr - MBRP Performance Exhaust
email - jrohr@mbrp.com
JesseRohr is offline   Reply With Quote
Old 05-16-2007, 12:35 PM   #14 (permalink)
Cummins - No excuses
CumminAtcha's Avatar
PM Me a price can you Jesse? Thanks
Adam - MySpace
03 3500 QC/SB 48re sold....
03 2500 NV4500 525hp/996tq 4/14/07 Totaled 12/15/07
99 F250 7.3 PSD sold early 06
CumminAtcha is offline   Reply With Quote
Old 05-16-2007, 01:00 PM   #15 (permalink)
JesseRohr's Avatar
PM Sent...
Old 06-27-2007, 11:50 PM   #16 (permalink)
DIESELCONVERT's Avatar
pm me a price please
thanks jesse
2006 SRW MEGALIMO 4X4 3500 5.9CUMMINS, VAN AAKEN C5,COMMANDER GUAGES,MUFFLER DELETE PIPE, ICEBOX WITH NANO 4091:.....................................$: it's only money.......unless you're broke !
DIESELCONVERT is offline   Reply With Quote
Old 06-28-2007, 01:51 AM   #17 (permalink)
Super Moderator
rufushusky's Avatar
WOW that makes my Brute Force look so whimpy......
Dennis
04.5 Ram 2500 Reg Cab 4x4 5.9, 48re, AEM, Smarty, Banks High Ram,FASS HPFP, Boost/pyro/trans/FP/RP gauges, 5" Exhaust, Cat 2 micron fuel filter, Amsoil Bypass, Reese Hitch, Single Disc Converter w/ Strictly Diesel VB
1997 Fleetwood Prowler 26.5"
Check out: Rig of the Month!
http://www.cumminsforum.com/forum/rig-month/
rufushusky is offline   Reply With Quote
Old 06-28-2007, 03:33 PM   #18 (permalink)
"Shake and Bake"
[quote=ramtd02;193288]you say the workharse performs better than the brute force?? I noticed your filterminder had been pulled down.....shouldnt happen with a new filter!! My bruteforce pulls down the filterminder anytime i do a WOT run, and I am extremely dissapointed with the products!!
I have the same problem and i made a call to AEM. One of the techs told me that the filterminder may need to be spaced out a little bit. As it sits on the Brute Force, it is in the direct path of the airflow which causes a vac on the minder. I never did anything with mine, just left it as it is. But if it worries you, ya may want to rig up something to get it to set out from the intake tube a little. Hope that helps. For the record i love mine, but had i known the Workhorse was coming out i would of waited. Kinda sucks that i bought mine and then the announcement was made that AEM was coming out with the Workhorse. Oh well so much for patients.
stinnett25 is offline   Reply With Quote
Old 06-28-2007, 05:37 PM   #19 (permalink)
I bleed diesel
Justice4all's Avatar
Well, I installed the biggest nano I could possibly squeeze into the corner of the engine bay just to experiment, and still pulled the minder down soon after I installed it. That tells me it's definately not filter restriction. The filters flow more than enough air, and the tube is more than sufficient in size, but the filter minder is in the wrong spot.
2006 Mega, Goerend Billet, Flux 3's, S362/S480, Hamilton cam, push rods, springs, Wicked CP3, Smarty, X2, Eliminator Fuel System, HTT intercooler, ARP 625s, Silverline 5", Lorenz leveled
DECEMBER 08 ROTM
Justice4all is offline   Reply With Quote
Old 06-28-2007, 07:40 PM   #20 (permalink)
JesseRohr's Avatar
Guys, those of you looking for pricing on the unit need to direct your attention to any of the guys at Truckaddons or any other vendors, I am no longer working there but I can help point you in the right direction of who to talk to.
Old 06-28-2007, 07:54 PM   #21 (permalink)
Originally Posted by btolenti View Post
anything on your oil analysis yet, Jesse?
What was your iron at? Aluminum?
D-Roc is offline   Reply With Quote
Old 06-28-2007, 07:55 PM   #22 (permalink)
Laramie4x4's Avatar
AEM makes a great product but its metal and well heat dissapation isnt great with metal versus plastic.... but hey it look awsome...
Big Black Monster......
Laramie4x4 is offline   Reply With Quote
Old 07-02-2007, 07:00 PM   #23 (permalink)
B-MAN's Avatar
Just installed mine and removed the black rubber air deflector off of the pass. front of the intercooler,...did a quick run up the hiway and noticed the EGT's were lower...
The only question I have is how does this set up work in the rain with the deflector removed? If I look straight in throught the grill I can see the filter and imagine the rain will also hit it... Anyone running this for a while have any problems with that?
2K6/4X4/3500/SRW/QCSB/48RE/full load Laramie/NAV/VES...
Extra's; SMARTY/Fluidampr/ICEBOX/FASS 150/AFE BladeRunner/Flo-Pro turbo back with 6"tip/Gauges; Boost-EGT-Trans-Fuel Rail-Fuel Pump/PASO/LHV TT/Mag-Hytec diff's & Trans/ARB bumper/WARN 12K winch/BW flares/R.airbags/YAESU 2M/Cobra 75/100gal.aux fuel tank/305-65-18 BFG AT's on black RockStars/35x12.5-17 DC MC's on H2's /leveled and more...
B-MAN is offline   Reply With Quote
Old 07-02-2007, 09:01 PM   #24 (permalink)
Ha, look at it like water injection!! jk...
Adam - MySpace
